Question about Car Audio & Video
Yellow wire goes to...? blue wire goes to...? red wire goes to...?
  • 17,130 Answers
You have not mentioned the make /model of the changer. Univerrsally the Red is the main power, so connect to the main positive. the blue will be the relay power on trigger from the main set. the yellow can be sub supply or illumination. Please take care as you have not mentioned the model. connect the red, blue and ground and test. Good day
Posted on Jul 06, 2010
Can not figure out how to wire it so ac works i have only 4 wires coming out of wall blue red white and yellow
Here is a general wiring solution:
Red is hot on a 24 v system, Red goes to "r" on thermostat
White is heat, goes to "w" on the thermostat
Yellow is aircond and goes to "y" on thermostat
Blue is fan and goes to "g" on thermostat
* note: this is typical and could not be 100% sure without pictures of the unit
Apr 11, 2011 | Heating & Cooling
I have red, yellow, green, blue wires. How do I wire to a RTH2310?
red is hot 24v goes to r terminal, yellow is for ac and goes to y terminal green is for the blower motor and goes to green terminal, blue can be a common or 2nd stage heat or 2nd stage cool or humidifier is blue connected on the furnace? If so what terminal?
Dec 14, 2010 | Honeywell Electronic Programmable...
I need to know which wires are what on a Clarion TVX5653 for the main(power) harness. There are 7 wires colored as follows red, yellow, black, blue, blue/yellow stripe,orange, orange/white stripe. Thank...
red is for pawer that goes to the fuse panel
black is for the ground
yellow is a hot wire that goes to the main power or battery it should have a fuse in the line
blue is for power antenna if u need
blue and blue yellow speakers same with orange ,orange/white
Dec 13, 2010 | Car Audio & Video
Yellow, red, and blue wires. Where does each go? Kenwood KDC-322
yellow wire is memory wire goes to 12 v source that is always on red wire is the ingtion wire so when u turn on key its turns on that goes to a ingtion source the blue wire is ethier amp or ant wire
May 22, 2010 | Kenwood KDC-322 CD Player
Cooktop - maytag cse9000 - wiring
white goes to neutral, bare copper to ground, red and yellow to one phase ( red L1 wire) and the black and blue to the other phase ( black L2 wire)
Dec 20, 2009 | Maytag 30 in. CSE9000 Electric Cooktop
I need wiring manual for goodman mini split.
outside unit L1 and L2 are load (input 240vac)
then you have control voltage, usually yellow and blue (24vac) this connects to some 18/2 thermostat wire which goes inside as white and red.
note: this unit may only need 24v control which is 2 wires from the inside unit and also 3 wires 2 hot 1 ground for line voltage.
STANDARD WIRING
on the inside unit you have green, white, blue and red control wires.
on your thermostat you have white, red, yellow and green
you run the wire from the outside unit to the inside unit. then run a 18/4 wire to the thermostat if wired and join the following wires.
inside unit thermostat outside unit
green------------------------green
white-------------------------white
red----------------------------red
blue-------------------------------------------------------blue
yellow--------------------yellow
Oct 08, 2009 | Heating & Cooling
What are the colors of the speaker wires in a dodge stratus 1997 coming from the wire harness of the car itself
The easiest way is to check the speakers themselves as manufacturers tend to change colors of speakers at a whim. Usualy though you will have 8 wires (4 front & 4 rear) paired in colours (white goes with white+black stripe(stripe is possative on speaker))etc.
Not knowing the cars electrics I can't be more specific.(I live in UK so don't know that much about U.S. cars)
Jun 27, 2009 | 1997 Dodge Stratus
Wiring confusion
yellow constant
red switch
black is ground
blue power antenna if any
dimmer i/illumination is optional
front- right-red/green-+
front-left-blue/green-+
rear-right-red/yellow-+
rear-left-blue/yellow-+
these are all the positive side wire for all your spkr
Jun 25, 2009 | Clarion DXZ945MP CD Player
Red wire missing
the power wire goes above a blue wire or next to (white/orange) and (green) in top row if there is a space there
yellow should be above black
(white/orange) should be above (blue/yellow) i think
than red over blue
hope this helps
Jan 11, 2009 | Pioneer AVH-P6400CD Car DVD Player
Deh-1950
yellow 12v + constant blue power antenna red accessories
Dec 15, 2007 | Pioneer DEH-P430 CD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
