Question about Yamaha HTR-6030 Receiver
No sound at all
I have had my Yamaha HTR-6030 for about 6months. A few days ago the sound completely stopped. My 6yr old son said he pushed a bunch of buttons on the remotes of our cable box and the stereo, but we can't seem to figure out what he did. If I crank the volume all the way I hear the static sound but thats it. If I play a DVD I can hear a muffled base sound only if I turn the volume all the way up. I have gone through the manual for the reciever and did all of the troubleshooting and it still won't work. We have called the cable company and he tried to help but couldn't figure it out either. Was hoping it was the cable and not the receiver. Any suggestions would be great.
Thanks
  • 975 Answers
I suggest if your handy , to open the receiver and look for a circuit breaker or a fuse that protects unit of being damage , replace it and turn it on , hopefully it will work .
Posted on Apr 18, 2008
Using Bose 901 Equalizer on Yamaha HTR-5840 Reciever
The manual is linked below. Page 19 advises you to use the "MD/CDR" - "IN (PLAY)" and "OUT (REC)" analog audio jacks.
http://data.manualslib.com/pdf/20/1975/197493-yamaha/htr5840.pdf?ace7c7b79ec34305a811125fb9ef1160&take=binary
Jan 27, 2014 | Yamaha HTR-5840 Receiver
The son froom my speackers stop
my best guess on this one is probably not the speakers but the sound system or device sending the signal to the speakers or the wiring to the speakers is shot if you are sure that all of this is fine then the problem is the speakers do not have enough power to play and it might be the psu that is shot.
Aug 22, 2009 | Yamaha HTR-6030 Receiver
Random Shutoff of Yamaha HTR-5240 When Playing Movie DVDs
I found this answer up above and it working. I check my speaker wires and fixed some and it has been working since then. I copied the answer below.
ce3810b.jpg barbu51
Rank: Guru
Rating: 91%, 206 votes
First i would strongly suggest that you review your wiring, since the problem occurred after those change , It might also be just coincidence. When you are playing something(music) go around and listen carefully to each of the speakers, check for muffled or distorted sound, that could indicate a speaker or wiring problem. Of course the problem could also be in the receiver. The protection circuit in your amplifier could be acting up(too sensitive), in that case you might need the help from a local repair tech.
Hope this will help Good luck
Dec 29, 2008 | Yamaha HTR-5240 Receiver
Yamaha HTR-6130 Front right and left speakers with no sound
As simple as this sounds, try hitting the speaker a/b button on the front of the unit, next to the headphone jack. I had the same problem, and was about to package the whole thing back up and go back to Best Buy when I hit this button and then the audio test worked.
Nov 23, 2008 | Yamaha HTR-6130 Receiver
Yamaha HTR-6030, Sound only from Front Speakers
u could have it cross wired some systems wire in sequence not always pos and neg
Aug 23, 2008 | Yamaha HTR-6030 Receiver
My yamaha htr 6050
Make sure you speakers are turned on on the receiver,
Jan 23, 2008 | Yamaha HTR-6030 Receiver
No sound in rear and center speaker
Check to see if you have sound by selecting 5 chnl speaker setting buy pushing the program button on the amp. you should have sound comming through all speakers.
Oct 10, 2006 | Yamaha HTR-5440 Receiver
Not powering on
1. The power cord is not completely insered. 2. the impedance selector switch on the rear panel is not fully set to the upper or lower end - (set it when the unit is in the standby mode) other then that, you will have to call for a service.
Nov 26, 2005 | Yamaha HTR-5150
Yamaha HTR-6030 Receiver Logo
114 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
