Question about Kitchen Ranges
I have an electric range the glass top and all of a sudden the cook top light indicator is on without the burners being on. Can you tell me the problem with the light indicator?
  • Kitchen Ranges Master
  • 3,361 Answers
One of your surface switches has shorted out and needs replacing.
It is not a dangerous situation,just a nuisance to have the light on all the time.
Posted on Jul 05, 2010
The burner indicator light on my GE profile glass cook top stays on when the stove is turned off. Any thoughts?
mine does the same thing, in my case it is just indicating the burner is still hot after being turned off.. it goes off after awhile, which is normal.
Oct 09, 2010 | Kitchen Ranges
Tip
How to change the cooktop on a GE Profile Electric Kitchen Range
After 6 years of luck a candlestick fell on our glass cook top and shattered it. We ordered the replacement part in sale from Sears (about $300) and set out to change it. Most web entries I found indicated that screws to release the top were in the oven, this was not the case. It took my wife and I two hours to replace the cook top, most of the time was figuring how because we could find no manual or instructions. This is why I want to share what we learned. I probably could do that now in 30 minutes, provided I have someone to help me with holding the cook top while detaching and then re-attaching the burners. Turns out the cook top is held in place by five screws that can be found under the control panel of the profile range. To remove the control panel you first remove the knobs, then the big plastic nuts that are under the knobs and then pull it out gently. You need to disconnect a long ribbon cable and before you do that it is a good reminder to switch the breaker for the range (typically a dual switch) off. Do not continue without switching the power off, you will be pulling many cables and there are many open connections under the cook top. Having removed the control panel, four more screws remove a second panel and allow access to a front row of five screws that hold directly the cook top. Essentially all the screws are hex screws and having a nice drill with controllable speed and clutch to control torque makes the job much easier. Remove all of them. I recommend documenting where every screw goes on a pad and keeping the screws separately in cups. Taking pictures is also helpful. Once the front screws are removed you still have two more screws that can be found in the side panels of the cook top about 2 inches from the back of the appliance. You will have to slide the appliance 6-8 inches forward and tilt it so that you can access those screws (one on each side). You are ready to hinge the entire cook top open. Keep the front down and lift from the back. You will find tons of cables that you should not disturb too much. Keep all cables connected; and I recommend you take a picture of how it looks. The goal is to detach the burners without disconnecting them from their cables. You need to remove a pair of metal clips that holds each burner in place using a Phillips screw driver. Notice that there is a specified position for each burner and for each clip. If you change the angle for any burner the cables will not reach. Gently remove the four little lights that indicate the cook top is hot, it hinges from one side and then disconnects. Once all burners are detached the entire glass cook top pulls out. Now the trick is to reverse the process as accurately as possible. I recommend using a soft towel where you rest the new cook top while you are attaching the burners to prevent a scratch or even worse a break. Lining up the clips that hold the burners is a bit tricky. I found that the screw driver helped me coax them to twist until I could align the holes properly. Check that each burner matches each socket and is attached flush. When it is time to lower the cook top back in place make sure that all cables are out of the way and that it fits flush against the range. Screw the side panels and then replace the screws in the front. Return the second panel and finally reconnect the ribbon cable. Before you push on the connector make sure that all pins align perfectly, a little patience can save you weeks for a replacement part. Return the control panel and attach knobs. Clean the glass before you heat it up. Return the power and enjoy your new glass cook top!
If for some reason something doesn't look right, review every step, your pictures and notes.
on Aug 18, 2012 | GE Profile JD966 Electric Kitchen Range
Stove top want heat up
the bulb i am sure is ok . but you have had a power failure to the burner . it could be the burner itself . if all the burners do not work the power to the range may be the problem .. ck the main fuse and make sure the 220 power is ok mm
Jul 12, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Butter knife chipped burner - Amana black glass cook top
if it didnt crack or chip os not a hole it can be safe to use
Nov 08, 2017 | Amana AER5844VAS Stainless Steel Electric...
I have a Kitchenaid electric range Architect Series II. Seems every time I use the large burner on the right side there is some sort of residue left that is very hard to get off. I have already made a...
What are you using to clean the stove? Only cleaners made for ceran type tops should be used according to directions. Do not use enamel coated pans or glass pans on your cooktop.If you have a boil over, turn off the burner and change to a different burner immediately. Clean up the spill completely before cooking on that burner again. Use a flat edge razor to clean tough residue. Your cooktop will look new for years to come, even with heavy use.
As far as the scratch, don't use abrasive cleaners on the top and only use pots and pans with flat bottoms. If you do use cast iron pans, never scoot them around on the top.
Nov 30, 2009 | KitchenAid KESC307 Electric Kitchen Range
I have a GE glass cook-top electric range. burner stays on.
You need to replace the switch which controls the burner.
Apr 07, 2009 | Kitchen Ranges
Kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Jan 29, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
REPLACE CRACKED GLASS COOK TOP
First of all, if the cook-top broke as a result of a manufacturer defect, the repairs should be covered under the manufacturer's warranty. In this case, the repairs would be done at no cost to you. If, however, the glass top was broken as a result of the consumer, the repair will not be covered (even if it is still under warranty). If this is the case, it does not require an engineer to replace a glass cook-top. It can be time consuming, though. If you are somewhat savvy with fixing things, it can be accomplished by the average do-it-yourselfer. The following link explains how to replace most glass cooktops:
http://www.fixya.com/support/r391448-replacing_glass_cook_top
The tedious part of replacing the cook-top is carefully removing and handling each burner element. These are usually ceramic and are very fragile. You must be handled with care. If there is no common disconnect, you also will be required to unplug each burner assembly one at a time and label the wires. A digital camera can come in very handy for this as well. The easiest way to do this is to remove the old shattered cook-top, first and lay it side by side with the new one. Remove and install one burner element at a time.
If you wish to pursue this and require additional assistance, please let me know before you rate the solution. I hope this helps you.
Jan 28, 2009 | Whirlpool GR773LXSS - Stainless Steel...
Kenmore ultra bake cook top indicator light
is there multiple lights(one for each burner?) of so thers an issue with the sensor on the element and the element would need to be replaced, check your manual generally a loner possibly 5 year warr on elemnts
Apr 09, 2008 | Kenmore 92022 / 92024 / 92025 / 92029...
Burner on range will not turn off
Look at the back of your range there should be schemetic for your power control board. look for defective burner wire going into relay. There should be 5 relays in rows. Realy is the problem. I had the same problem with my front left burner stuck on high.
After replacing everything works okay.
Apr 07, 2008 | LG LRE30755 Electric Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
