Question about Refrigerators
Freezer won't defrost - Refrigerators
  • Anonymous Jul 26, 2008
    I have a kitchenaid superba side by side model. It is quickly gathering ice and won't defrost. What do I do? What does it need?
  • James Davis May 11, 2010
    Do you have a model number?
Go to partselect.com follow their troubleshooting links and they sell the repair parts also (cheap)
Posted on Apr 18, 2008
Defrosted my Frigidaire freezer plugged it back in but it won't turn on
Give it a while it might be in defrost mode. If it does not cone on after an hour I would check the defrost timer. Most of these are on the base of the freezer in front behind the kick panel. You can manually advance the timer like I did in this video:
Sep 23, 2012 | Frigidaire Freezers
My true freezer won't defrost?
Check the defrost timer (in the base, circular knob you can turn till it clicks) If it doesn't heat up rapidly in the evaporator, there is a safety overheat device (thermistor) that may be cutting power to the heater, or there may be a fault with the heater itself. Are you sure the fans are working, and the condenser grill is nice and clean?
May 14, 2012 | True 72 cu. ft. / 2039 liter Commercial...
Help, i turned by Bosch Logixx GSL 14424 GB freezer off to defrost and it now won't turn on...
Turn it round and check the electrics for the compressor are dry. You probably flooded them when defrosting and may have shorted something. If it still won't start with everything dried out, call a fridge technician
May 02, 2012 | Freezers
Fridge won't cool but freezer working fine
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 31, 2011 | Refrigerators
Kenmore refrigerator won't cool
Oct 27, 2011 | Kenmore Refrigerators
This is for a kenmore top mount Refrigerator/Freezer Model Number 25363712302. Refrigerator was not cooling properly - was warm. Freezer was working, but after a couple of days, freezer also started to...
Since you say that is isn't cooling properly, I would first start off by cleaning the condenser grill that is located under the cabinet. While this won't correct your problem entirely, it will help!
Most likely you have a defrost system malfuntion. The defrost system consists of the defrost heater (p/n: 5303918208) which is the long tube like thing that sits directly below your evaporator behind the panel in the back of the freezer (inside the freezer). It also consists of the defrost thermostat (p/n: 5303918202), which is located next to the evaporator. Both the defrost heater and defrost thermostat can be checked with an ohm meter - a non-open/infinity reading is good. If both of those check out and are good then it has to be the defrost timer (p/n: 215846602) which is located behind the plastic shield (with the light bulb).
Suggest you defrost the unit (making sure no ice or frost is behind the freezer panel then plug the refrigerator back in. If everything cools down then my diagnosis is correct and one of the components of the defrost system is bad.
Oct 03, 2011 | Kenmore Top Freezer Refrigerator
My freezer works fine but the refrigerator part won't cool. What can I do?
The leading cause of the refrig.not working while the freezer does is because the freezer is not automatically defrosting as its supposed to,do you see frost build up on the back wall inside the freezer?? if yes their is frost build up in=side of the freezer its not defrosting.
This tip i wrote covers what to check to see why its not defrosting.
http://www1.fixya.com/support/r10097882-wrong_when_freezer_frosted_refrig_warm
GENE
Sep 26, 2011 | Frigidaire Refrigerators
Frigidaire Refrigerator FFTR1814LW bottom fridge not cooling properly 50 degrees. The top freezer is rock soild Thx
That is the classic symptoms of a defrost system failure. Suggest you look behind the rear panel on the inside of your freezer and see if it is iced up. If it is then it is a defrost problem which could be the defrost heater, defrost thermostat or defrost timer. If it isn't iced up, then check to make sure the fan is operating. If it isn't then it won't push cold air out of the freezer into the refrigerator section.
Sep 14, 2011 | Refrigerators
Appliance is running but won't get cold. Freezer won't freeze either
I'm Leo
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Jul 27, 2011 | Maytag MSD2756G Side by Side Refrigerator
3 year old kenmore top freezer, won t defrost ''no ice'' buildup behind the freezer panel I removed. no clicks on the defrost test, same result for method #2. The ice maker works ok when freezer is at...
your freezer had a heater and a bi metal behind its pannel. if they won't work properly than you would face problem like this.......contact your service authority. it cannot be solved by your own
May 14, 2009 | Kenmore Refrigerators
Refrigerators Logo
432 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
