Question about AlloBaby Marbella 12 Jogger
Tire tube flat
Were can i purchase a tube for my stroller for the back tire wheel
    President:
  • 2,702 Answers
Have you tryed a bike shop?? or a car tyer shop??,,they may get one for you,,if that fales try that tyer fix it stops leaks in tubless tyers
Posted on Jul 05, 2010
I need replacement wheels for a Bertini TS Shuttle Sport Chrome, purchased in 2001
I can only find Australian Repair Shops for this brand. You can contact PramFix in Australia at +61 2 9526 8005 and they should be able to assist you.
Oct 08, 2014 | Bertini Shuttle TS Sport Standard Stroller
I need a new wheel for my quinny freestyle, it keeps going flat and now i have a thorn in it. i need it asap
Most strollers use the same tires and tubes as kiddy bikes. 10" or 12" your local bike shop could help. I buy spare tubes and tires from Kmart.
Jun 03, 2011 | Quinny Freestyle 3 XL Stroller
Baby stroller needs back wheel removed and tire replaced
look and see if there is a lil rubber plastic cover in the middle of the tire and press on it might be a release button to unlock and pull off the tire / thats how mine works. if that dont help u can just take the whole stroller to a bike shop and they will fix it for u
Mar 11, 2010 | Valco Twin Runabout ATS Jogger
I have pram quinny buz 3 (second hand) but the back tires are flat. How to fix them since they won't fit in with my bike tire pump . many thanks
Hi you can purchase the correct pump on ebay, if they are punctured they also sell new inner tubes very cheap they also have a bent valve which makes them easier to pump up.
Mar 08, 2010 | Quinny Buzz Three Wheel Stroller
One of the back tires on my baby trend columbia stroller is flat. I cant find a hole anywhere. It seems like it may be a problem around the thing that you put air in....any suggestions??
If you pump the tire again with enough air and put your ear against the tire you may be able to hear the air escaping.
If it's a slow leak you may not be able to hear it but any bicycle tire levers will allow you to take off the tire. More than likely you pinched the tube or punctured with a sharp object in use.
I usually recommend replacing the tube completely, the cost & ease of replacing the tube is better than using the patches which I find it a headache to deal with smaller wheels especially for any jogging strollers.
Nov 03, 2009 | Baby Gear
One of my tire is usually flat and since I bought stroller I can't pump just this one tire because I like this stroller tell me how I can sole this problem? It's like impposible for pump it.
You need to either have a new inner tube put in it or you can try adding a flat repair gel in the tube to fix the leak. You can get what they call "Green Slime" their are other brands also available under different names but this is most common. It can be purchased at Walmart, Home Depot, Ace Hardware and Auto Parts Stores. This is easy to pump into the tube valve stem without removing the tube or wheel and should fix any holes or leaks on it. Then just pump it up and you should be ready to go.
Nov 02, 2009 | Quinny Buzz Jogger
My jeep jogging stroller has a flat. Do I need to
Replacement tube may be more beneficial even though the fix/patch may be cheaper. If you live in an area that have varying climate, the patch along with the repaired tube can expand and contract and may cause small leak if not repaired properly.
Otherwise I would get the right size tube, most jogging strollers are either 12" or 16" tube inside and can be bought from your local bicycle store. With that, you'll need bicycle tire levers which can also be bought at the bike shop. Just about any type of tire levers will do. Of course I'm sure your bike shop can do this for you to possibly for free with a purchase of replacement tube!
Oct 27, 2009 | Jeep Liberty Limited XT Urban Earth Jogger
New wheel in instep duo stroller needed (BACK WHEEL)
I should go to he Pram Shop where you bought it from, if it has closed down go to a Mothercare Shop or similar Pram Shop. They will be able to get you the information you need.
Apr 08, 2009 | InSTEP 10K Single KA106 Jogger
Jeep stroller wheels
yes u cxan order a new one go to any stroller shop or outlet they have them there or can help you
Sep 03, 2008 | Jeep Liberty Limited XT Urban Earth Jogger
Fixing a flat tire
Any bike shop will have patch equipment. You need to deflate the tire and remove it from the wheel. See if there is a tube inside the tire. If so, the fix is easy: either purchase a new tube for the tire, or get a patch. Use modelling glue on the patch then press it continually on the hole on the tire for about five minutes until it is dry. Afterwards, re-insert the tube into the tire, reattach the tire to the rim and pump it back up
Jul 13, 2007 | Kolcraft Jeep Liberty Limited Urban...
AlloBaby Marbella 12 Jogger Logo
Top AlloBaby Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you an AlloBaby Baby Gear Expert? Answer questions, earn points and help others
