Question about Crosley CR248 Turntable
Phono only outputs in mono - Crosley CR248 Turntable
  • Crosley Master
  • 5,113 Answers
Check the wiring to the cartridge.
Posted on Jul 06, 2010
How do I connect my roland piano 5500 to an amp
On the rear of the piano there will be two 1/4" jacks labeled Output Left and Right. One will be labled Mono as well. If you are using a stereo amp, use both, and if a mono amp use just the mono output. If your amp is a guitar type, connect a shielded cable with 1/4" phone jacks such as you'd use with an electric guitar from these jacks to your amplifier. If you are useing a home stereo amp, you will need a cable with 1/4" phone jacks from the piano to RCA phono jacks on the amp end.
Oct 08, 2014 | Roland HPI-7F 88-Key Digital Piano -...
Can I use a JX-S900 Y/C separated I/O to run two subwoofers out of same reciever??
Yes, on two conditions:
1) the JX-S900 needs to be a proper matrix switcher. It has to have the ability to route 1 input to more than one output.
2) the sub signals need to be low level RCA/phono, and not high level speaker wire connections. That's not just about the type of connector. It's about the signal going through those wires. A low level RCA/phono sub connection conducts a maximum 0.7 Volt. A speaker wire connection can transmit 30 Volts! If you put 30 Volts in to a line level switching device such as the JX0S900 you'll fry it.
Provided that the above two criteriia are both met, then yes it will work.
  • Connect the AV receiver's sub out to Source 1 - white RCA phono.
  • Connect the two subs mono LFE Left input (white RCA) or the single black RCA/phono inputs to the JVC's outputs 1 and 2 - white RCA/phono.
  • Set the source routing: input 1 goes to output 1 and 2
Sep 17, 2014 | Audio Players & Recorders
Can you plug a stereo headphone (for on stage monitor) to aux 1 on a Soundcraft fx12? This output seems to be only mono...
Generally mono outputs on this kind of mixer are usually balanced. This means all three poles of the connector are connected. The hot or plus signal (tip) will go to the left of your phones, the cold or minus (ring) will go to the right. This will be ok from a sound point of view But it may not have enough drive to make the phones loud enough.
If you only hear a signal in the left then the output is unbalanced.
A simple fix is a cheap headphone amp (less than 20 pounds) and a simple jack to two phono lead (wired as a split). There is a ton of old audio equipment about for very little money including some very small mixers, that have headphone outputs, that is what I have done a lot in the past.
Oct 31, 2013 | Soundcraft Music
Im trying to hook up a paradigm pdr-12 to my tv and xbox 360 and need an idea of how to do this the right way so it only plays the bass and nothing else
Hello there this subwoofer has a built in crossover variable from 50hz to 150hz which means that any signal you feed it the sub it will ignore anything but bass anyway.
As for the connection it is made quite difficult if you don't already have an amplifier powering your other speakers, usually home cinema amplifiers have a low level pre out for subwoofers, for which you would just need a phono to phono cable.
However if it doesn't and you have any type of amplifier with at least 2 separate left and right speakers you can connect the wires from these into the subwoofer and it will output the bass from these 2 channels.
Another option is to use a mono to stereo (2 to 1) phono cable where the 2 connectors at one end connect to a tape or record output on your amplifier and the single phono at the other connects to the subwoofer, the same would go if you have a red & white phono (RCA) output on your TV you could also use this to power the sub, in the worst case scenario you could use a single to single phono or rca cable to connect one of the output channels (left or right) on your TV to the subwoofer however this would mean that the subwoofer would only output bass from either the left or right channel.
Hope this helps
Kind Regards
Ant
Aug 26, 2011 | Audio Players & Recorders
When I plug in stereo headphones in the casio wk 210, the sound only comes out of one ear. I didn't really care about that before, but now when I connect a line out from the piano to my computer to...
The output of the casio may only be mono, you can buy splitters to create a 2x channel output. Is there any other outputs from the casio other than headphones, usually there are red/white RCA outputs (Phono's) which would be better for connecting to your soundcard.
Hope I was of use to you, good luck.
Aug 04, 2011 | Casio WK-210 PACKAGE 76 Keys Electronic...
Have a stanton STR8 60 turntable that I forgot about. Hooking up it only has one output. Where do you put it?
turntables have very low output signal need a phono input to amplify it more than cd,cass. if has mono output use rca conn 2 to 1
Jun 10, 2010 | Stanton STR8-60 Turntable
Emu1616m can one output 6 mono tracks at once to a mixing desk?
sound did not provide inspite of installing motherboard softwear,my sound card is buildin,,plz solve this problem
Apr 23, 2009 | E-Mu 1616M Sound Card
Two Subs And Monoamp
You can buy splitters from radio shack or many other electronic/sound shops which split a male or female phono jack to separate stereo or mono output jacks. The most common is a phono jack to two separate mono 1/8" plugs. One way would be to purchase one of these, cut the ends off the outputs and strip the insulation, then use those to wire your amp. "Monster" brand puts out some of these splitters as well which use heavier gauge wire which would probably be most suitable for the task.
Feb 06, 2009 | Kicker ZX300.1 Car Audio Amplifier
Trying to hook new amp to old jukebox??? 1963 Rockola
Hi Randy,
I take it that the output from the jukebox is mono (only a signal and screen cable) and the connection to the amplifier is a phono plug. You could make up a cable by using a phono inline socket and two phono plugs. I would think that you could purchase one from your local electronic store. If you make one up it should be made using a screened cable.
Regards
Alan Hood
ami-man
UK
Jan 02, 2009 | Vintage Jukebox External Speakers Shelf...
Crosley CR248 Turntable Logo
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
