Question about Pride Celebrity X 4-Wheel Electric Scooter
I HAVE A CELEBRITY DX SCOOTER, IT IS 4 YEARS OLD. I HAVE HAD NEW BATTERIES FITTED, BUT THIS LAST 3 MONTHS THE SCOOTER RUNS FROM NORMAL SPEED TO SLOW AND SLUGGISH THEN BACK TO NORMAL EVERY FEW MINUTES.CAN YOU HELP ME PLEASE. JOHN . THE 2 BRUSHES ARE LOOKING OK
  • 177 Answers
Hi John.
The problem could be a worn throttle pot ( wig wag ). Next time you are driving the scooter, try moving the ends of the speed lever slowly up and down, instead of in or out as you normally use it. If the throttle pot is worn, moving the lever this way will make the machine speed up or slow down.
Another cause might be a faulty battery lead connector or a faulty motor connector.
Good luck. Neil.
Posted on Jul 07, 2010
  • albertblythe Jul 18, 2010
    HELLO SCOOTERWORKS,
    SORRY FOR THE LATE REPLY, I HAVE BEEN ILL.
    I HAVE TRIED THE LEVERS BUT IT WAS JUST THE SAME.
    MY SON IS GOING TO LOOK AT THE CONTROLLER,
    BUT AT THE MOMENT HE CANNOT SPLIT THE TILLER CONSULE TO LOOK AT IT.
    KIND REGARDS
    JOHN
2 Suggested Answers
  • 16 Answers
SOURCE: PRIDE CELEBRITY DX RUNNING SLOW
Hi
Please Check your Potientiometer also known as a Pot, This is your Speed Control and it may be on the way out after 4 Years ,
My Own Pot Packed up after 11 Months, Try to get a Second hand one as they are Expensive to buy,
Good Luck, Gerry.
Posted on Aug 01, 2010
More on Celebrity X motor overheating. Brushes look good. Brake does not seem to be dragging, Batteries are about 5 years old but hold a good charge when not in use for months,
If the motor is overheating, it is drawing far more current out of
the batteries than it is supposed to. Assuming it is 2 x 13v x 33ah
batteries, these are good for about 2 to 3 years on my scooter and 'wheelchair. AGM (absorbent glass mat) lead acid batteries do deteriorate over time due to battery chemistry.
Although the batteries may appear to take a charge
and the voltage 12.6volt x 2 = 25.2 volts nominal, with no load
on them, the motor controller takes a whack of current to get you going.
I have an digital voltmeter/ammeter installed on my Pride XL scooter and I was amazed how much current the motor/motor controller takes from the batteries. 50 to 80amps on startup.
If the battery voltage drops due to the age of the batteries, as the
energy is being used up from them, the current required by the
motor for rotation has to go up, and that will cause overheating of the controller and the motor. It is Ohms law plain and simple
the less voltage available-the more current required to do the
work and current creates the heating effect.
I replace my batteries every two years. Can't take a chance on
being stuck with discharged batteries.
Feb 20, 2015 | Pride Celebrity X 3-Wheel Electric Scooter...
Tim, the batteries on my Legend XL gave out last Fall, so I replaced them with two new recommended batteries, and now it will only run in top speed for the first hundred feet, then it slows down to a
If it is actually speed pot related, then removing the speed pot
and spraying down the shaft of the speed pot (from the top)
with electronic contact cleaner, may help to make clean
the pot resistive element and that should fix that. If it's
not a speed pot issue and happened after replacement of
the batteries, assuming they are 35/37 AH AGM batteries,
check the batteries for current delivery at the rated current.
It could be just a battery that is not providing the rated current
to the motor after 50 feet.
May 02, 2014 | Pride Legend XL Heavy-Duty 4 Wheel Scooter...
Throttle pot not working but no code light
It could also be the speed pot or a battery low voltage cut out indicating failing batteries.
Apr 14, 2013 | Pride Celebrity X 4-Wheel Electric Scooter...
My dad's pride celebrity scooter has new batteries. the status led flashes once, pauses, and then flashes twice and then repeats. it was not used for several months, but was operating fine the last...
Hi. The batteries for these things seem to go bad rather quickly when they are not used, but here is something to try..... So called "smart chargers" are what everything is going to. They analyze the condition of the battery and if everything is good, charge it. If everything is not good, according to the parameters of that charger, they don't. My suggestion is to take the battery out of the unit and try an old-fashioned analog battery charger for a little while, set to the proper voltage for the battery, of course, and monitored closely to measure the effects. If the batteries seem to take a charge, put them back in and run it a bit, then try the on-board charger again, just don't wait until the batteries are completely drained this time.
Sep 09, 2011 | Pride Celebrity Xl 4 Wheel Scooter
My scooter will slow down and come to a complete stop & then may take off at regular speed. This is with till lever pushed in as far as it is suppose to go. Battery is up where it should be. What...
Hi tandseaster,
I have owned my own business for 3 years and have been working on scooters and powerchairs for 15 years. In the future give as much info about the scooter as possible.
Several problems: Make ablsoutly sure the batteries are at full charge and have been load tested. Sometimes even a new battery can be bad. If the batteries are good then here are some sugesstions.
1.The throttle pot or somtimes called the engager can be bad.
2. Speed pot (most likely the problem) could be bad.
3. The motor brushes may be too small to run the motor armature
4. You may also have a bad motor
5. I have also seen this problem and had to replace the transaxle.
.Good Luck
Tim
May 01, 2011 | Electric Mobility 4 Wheel Power Electric...
My scooter is too slow,the battery charges,but only drives at a very slow speed.While going backwards drives at a good speed.Can you tell what to do??Many thanks Diana Donald
Hi dianaidonald
I have owned my own business for 3 years and have been working on scooters and powerchairs for 15 years. I know exactly what the problem is. Your problem is the throttle pot or somtime called the engager. or the speed pot.
1.. Replace the throttle pot and or (speed pot most likely the problem).
Good Luck
Tim
Apr 30, 2011 | Drive Medical Drive Phoenix 4 wheel...
Hi
Good Luck, Gerry.
Jul 19, 2010 | Pride Celebrity X 4-Wheel Electric Scooter...
I have a Pride Legnd..the scooter started loseing speed, I would adj the speed pot and the unit would stop, adjust back down and unit would run, but slow. I left the speed speed controller alone and unit...
hi, first you need to check the connections to the batteries then to the motor controller, and don't dismiss the speed pot, disconnect the speed pot and try a normal 5K pot inplace of it, if the scooters responds you find the problem just a case of getting the right speed pot. Check the freewheel switch, normally it located on the motor side.
Regards
GeWiz.
Dec 15, 2009 | Pride Mobility Victory 3 Wheel Electric...
Pride Celebrity X 4-Wheel Electric Scooter  Logo
620 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
