Question about JVC AL A158BK Turntable
When plugged in the table does not spin. - JVC AL A158BK Turntable
  • JVC Master
  • 5,444 Answers
Sounds like the belt has come off. Lift the turntable matt it should show you the access hole.
Posted on Jul 06, 2010
HELP: Stopped spinning
It's likely the belt has slipped of and probably needs replacing. You can do this yourself. It will be found under the turntable matt. The trick though is fitting it back on. But you might find the instructions on-line (enter the model number into google search). Some people have even put YouTube video's on how to replace the belt on popular turntables.
Jun 11, 2014 | Crosley CR74 Turntable
Comfort zone fan- CZ161 won't turn on
Remove front grill cover and spin the fan, if it spins the problem is most likely the on? off switch or the cord may be frayed, at the plug end usually.
Nov 26, 2013 | Comfort Zone 16" 3 Speed Oscillating Table...
Powermatic 66 wiring problem
Simple solution: switch two of the wires. Doing so will reverse the direction of the motor. You can switch it at the motor or on the electrical plug end.
Mar 28, 2013 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
Einhell table saw 1500 watt is smoking
Maybe you have a 220V saw that you are running on 110V? It would spin, but would have little power and would quickly overheat due to too much current through the windings. The motor could well be toasted already.
Aug 08, 2012 | Dewalt DW744X 10" Portable Table Saw
The turntable is not working but when i plug it into the computer they table lights up but the buttons are not working
i need a license key for mine and i only have the disc without the sleeve, and the tables. im not good at spinning but im trying and i dont plan on sharing the key with anyone else please? my email is specopsmerc347@aol.com plz email as a yes or no
Feb 12, 2011 | ION Audio Discover Dj Turntable
The motor sometimes starts right away and at other times I have to use a wood stick to spin the blade and it starts
the brushes in a dw744 have a ledge when they get too short that hangs up. replace the brushes and you should have no problem. the brush holder comes right out with a little coaxing with a screwdriver after the end cap is removed. it just plugs right in.
Dec 22, 2010 | Dewalt DW744S 10" Portable Table Saw with...
Skil saw motor runs but blade won't spin
you have a loose nut.  Let me explain...the nut and washer that holds the blade to the motor has worked loose.  You need to remove the plate around the blade to acess it and on the end of the blade is a large nut.  Tighten it with the power off.  Sometime there is a grove on the motor shaft to hold the motor or sometimes you need to put a screwdriver into the teeth of the blade to hold in place to tighten.
Apr 04, 2009 | Skil 10" Table Saw
JVC L T11 turntable spins to fast jerry, rigged adapter
where can I get an 11V -13V DC adaptor to power JVC turntable AL-E300?
Feb 02, 2009 | JVC Audio Players & Recorders
Technics Table spins left and right in the on position
You have an issue with your drive circuits. Only a service tech can diagnose and repair this. It's not easy.
- OPTiC
The 1200s Expert
www.1200s.com
Aug 25, 2008 | Technics SL-1200MK5 Turntable
JVC AL A158BK Turntable Logo
131 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
