Question about Crosley CW5000 Front Load Washer
High pitch squeak when on spin cycle
Then a burning smell??? any idea what to do? is there any way to get them fixed cheap?
  • Tia West
    Tia West Apr 18, 2008
    its more like a very loud clicking and vibrations while agitating and in the spin cycle at one point it locked up then smelt the burning
  • 975 Answers
Looks like you need to replace the main DRIVE BELT , first open the panel to access inside the washer , give it a test wash and look at the bottom where the belt is , check if belt is tight , if you still hear the squeak try lubricate spray to the pulleys and avoid spaying the MAIN BELT . hope this info works
Posted on Apr 18, 2008
During spin cycle it makes a high pitch whining sound and sounds like a button is loose in the tub
does it have a burning smell? is it belt driven? rather than direct drive. belt are known to emit a whinning pitch sound at times. could be bearings going out. and sometimes a pc of metal opr material can get stuck between hub and shell and make weird sounds?
Nov 08, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
I have an ASKO T700 dryer. When I turn it on, it makes a high pitched squeak. If it's on for longer than a minute, I can smell a burning smell. Any suggestions?
you got a roller or belt idler not turning and burning the drum belt. you have to take the dryer apart and find the problem. if you need to lubricate a roller or idler use mineral oil or roller oil, do not use wd-40 or 3 in one.
Feb 12, 2011 | Asko T700 Electric Commercial Dryer
Washer makes a squeel and burning smell
belt which operates pump/motor/transmission pulleys
Apr 10, 2009 | Washing Machines
Frigidaire ultra quiet I dishwasher
Sounds like the water may not be turned on to the dish washer.
The arm spins with water pressure
Oct 16, 2008 | Frigidaire 24 in. FDB510LC Free-standing...
Very loud final spin cycle with burning rubber smell
Hi Mcbride2
It could be one of 2 things. 1 the belt. or 2 the main seal and bearing. i recomnd to get a tech just to make suer.
brent
Sep 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag machine not spinning
You have a stuck brake.My advice is leaving this one alone and lrt a tech. fix it.HINT:99% of this same problems your having I have fixed without replacing 1 part,so see if your repairman can do the same.This is a PERFORMA and is know way Maytags design.Except one thing ,the name on the front panel.
May 31, 2008 | Maytag Performa PAV2200
Burning smell + Screeching sound but Belt is not the cause, then WHAT is?
A lot of people may be searching for help with horrible sounds and burned belts for Maytag and Admiral washers only a few years old from Home Depot etc. They used a cheap pump that has a corrugated sheetmetal ring that holds the bearings. Well as it runs the vibration and friction cause it to slip down and grind on the pulley as well as not turn easily. If you put the washer on it's back and turn the small pulley and it turns with a gritty feel or you can actually see a loose metal collar type ring thing that looks like a cookie cutte; then you have a bad pump.
There is a small access panel on the back of the washer. Three screws and two spring clips on the hoses and you're done (use big pliers on the hoses). Put the belt back on (just push motor to one side, it's not tight), then check for leaks and reinstall the cover. VOILA! You can find the pump on ebay for $25 or your local GE parts dealers for $50.
Sep 11, 2007 | Maytag SAV5710 Top Load Washer
Washing machine squeak
Same squeak on spin -LW8203 shortly before that she ran an off balance load and now wonders why it squeaks..
Jan 06, 2007 | Amana ALW895 Top Load Washer
Crosley CW5000 Front Load Washer Logo
700 people viewed this question
Top Crosley Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Karl H
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
