Question about Panasonic NN-C994S Convection/Microwave Oven
No power Hi I relpaced the power inverter and the oven ran great for about 10 min then shut off and now there is no power to the display panel, and if I open the door the fan comes on and the turntable turns
  • barntgr Apr 18, 2008
    The oven was shutting down after about 10 sec with smoke comming from the inverter, and the inverter smelt burnt
No display microwave not working
Posted on Sep 05, 2008
  • 975 Answers
What was the problem in the beginning before replacing the power inverter ?? most of the main problem is the DISPLAY PANEL that needs to be replaced ( membrane circuit ) and to be honest with you , is not worth it to replace it cause the price you going to pay , you better off purchasing a new one . now days we call it THE DISPOSABLES MICROWAVES . hope this helps
Posted on Apr 18, 2008
  • ALBERT GARCIA
    ALBERT GARCIA Apr 18, 2008
    ok !! then we need to look at a VOLTAGE REGULATOR in the POWER SUPPLY section , and to check on a big capacitor for a shortage .
Panasonic 1250w genius senor inverter less then a year old. Control panel lights up, works.microwave itself does not, control panel shuts off in a few seconds
When a Panasonic Inverter Microwave shuts off after a feew seconds, it is either a bad inverter which is the quite expensive circuit board that powers the magnetron that puts out the microwave energy, or a bad magnetron, Or BOTH typically this would be a costly repair, But since it is still under warranty. You need to find a Panasonic warranty service provider in your area. If it is a counter top unit, you may have to take it to them for repair.
Jul 05, 2017 | Panasonic Microwave Ovens
Model 72180883400 Microwave Oven F-9 Failure Code
If the unit is less then 5 years old i believe it is still covered it may be the inverter board or a grounded Magnetron tube. If you need any further assistance let me know. I would contact kenmore directly.
Thanks,
Lee
Sep 01, 2008 | Kenmore 62702 Microwave Oven
My sharp R409Y*A microwave overheats after 4 min every time and shuts itself off for a few min. It will turn itself back on, but if I use it right away, it will shut itself off again quicker.
I would say your cooling ran is not running, or your vent holes are blocked, or (if equipped) a filter is blocked.
Without the cooling fan, the magnetron overheats and its TCO (thermostat) shuts down all power to the oven until it cools back down to a safe temperature, then power is restored.
Feel free to e-Mail me at pupista@gmail.com if you need more free advice.
Sep 19, 2016 | Sharp Microwave Ovens
Trouble code H98
H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
R
Oct 03, 2014 | Panasonic NN-H765BF 1250 Watt Microwave...
Shuts off after approx 5 - 7 sec. some smoke
If it stops after 7 seconds, it has a problem with the inverter.
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
If you prefer to replace the inverter yourself, you can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
May 15, 2010 | Panasonic NN-S954WF Microwave Oven
Microwave was ran for 5 minutes with nothin in it now no display
most have an internal fuse check it first if that is not it check the thermal fuse both parts run 10-15 dollars
Jun 30, 2009 | Maytag MMV4205 Microwave Oven
Split system not starting up for about 10 mins after turning on
Hi Wendy,
The manual for the unit is at this link. This should answer all your questions. http://panasonic.com.au/products/details.cfm?objectID=4601 then go to the bottom of the page and click on CS/CU-E18_21_24_28HKR Operation Manual
I take the time to answer you questions so please rate me
Thankyou
Mat
Jun 10, 2009 | Panasonic MCM INVERTER
Model 72180883400
F-9 error code indicates a defective control board, inverter or line voltage too high. f the microwave runs for about 7 seconds with a ticking sound..then stops and shows "F-9", it is the magnetron that has failed. The fact that the unit starts and runs with the TICKING SOUND means the control board is sending signal to inverter board and the inverter board is sending signal to magnetron. Magnetron is covered by full 5 year warranty, inverter board is only 3 years.
Microwave F-7 Code
F7 is q Power to magnetron
interrupted
1. Unplug microwave oven or disconnect power.
2. After 40 seconds, check to see whether this solves the problem.
3. Unplug microwave oven or disconnect power.
4. Check cooling fan operation
5. Check resistance of the magnetron thermostat.
6. Check the magnetron.
7. Check P2, P4 and P27 connections.
8. Check wiring to the 1100W inverters and control system. See
“Checking Inverters.”
9. Check operation of all interlock switches.
10. Replace inverter, if defective.
11. Replace all parts and panels before operating.
12. Plug in microwave oven or reconnect power.
13. If problem persists, unplug microwave oven or disconnect power.
14. Replace electronic control.
15. Replace all parts and panels before operating.
16. Plug in microwave oven or reconnect power.
17. If problem persists, unplug microwave oven or disconnect power.
18. Check for reversed plug connection on controls or loose wiring.
19. Replace all parts and panels before operating.
20. Plug in microwave oven or reconnect power.
Aug 08, 2008 | Whirlpool GH6177XP Microwave Oven
Panasonic NN-C994S Convection/Microwave Oven Logo
152 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
