Question about Amana ACS7270AS Electric Kitchen Range
My stove has F1 on the screen,and i beeping. I
My stove has F1 on the screen,and it keep beeping. I can't find the book to reset it.
  • tootsie79 Jul 05, 2010
    HOW MUCH DO THEY RUN
  • Amana Master
  • 3,361 Answers
Sorry it can not be reset.
The F1 code is a failed electronic control. The clock/oven control must be replaced.
Posted on Jul 05, 2010
  • steve
    steve Jul 05, 2010
    http://www.repairclinic.com/0078.asp
    AMANA CODES
  • steve
    steve Jul 06, 2010
    About $75 at this site:
    http://www.repairclinic.com/Appliance-Pa...
    You can try unplugging the range,then open the control panel and unplug the electronic control ribbon connector. Plug the range back in for 1 minute. Then unplug it again and reconnect the ribbon connector.
    Then plug the range in again.
    If that does not correct the problem you will have to replace the control.
I cant get my stove to stop beeping. f1 error
You need to get the exact model number and make of this stove. Get ready for a bad circuit board to be the culprit, because electronic stoves are pretty much unfixable by mechanical means and the problem usually comes from a bad capacitor, corroded or overheated circuit board.
When you get your model number and make, go to YouTube and just type in your model stove and ask "how to repair a F1 error code on a blah blah stove". There are so many video's there on how to repair things with actual instructions and pictures. It's great.
Use this link to close in:
https://www.youtube.com/results?search_query=repairs+to+appliances+or+stoves
Jan 27, 2015 | Kitchen Ranges
Frigidaire stove(smooth top -electric) all of sudden started to beep' constantly w/F1 flashing.Tried to reset - unsuccessful. Unplugged & waited an hour to plug back in & still beeping...
The F1 error code means a button on the touchpad is stuck,usually pushing clear/off will clear it. Since you have done that and it returns the touchpad needs to be replaced
Gene
Aug 11, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
I have a 19 year od kenmore electric stove and it keeps beeping F1. I can hit cancel and it will be od for alittle while then goes back to beeping. Any ideas?
You have either a bad ERC (clock) or a bad touch pad.
Disconnect power to stove
Gain access to the back of the clock (electronic range control or ERC).
Unplug the touch pad ribbon connector from the ERC. This will be a flat wire apx. 1 1/2" to 2" wide.
Make sure everything is clear and will not short out when power is turned back on.
Turn power back on to stove.
Watch for the F1 and listen for the beep.
If you get the F1 and beep, replace the ERC.
If after apx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
NOTE: Some models incorporate the touch pad and the clock as one part.
Hope helps.
May 22, 2011 | Kenmore Kitchen Ranges
My amana gas stove keeps beeping and the code F1 is flashing?
Hi!
The F1 code means that the Key Pad is defective, the book says that if pressing CANCEL for 10 seconds don't stop the beeping and resets, the Pad should be replaced. I have learned that if you unplug the unit from the wall outlet for a couple of minutes, most of the time the pad will reset by itself.
Good Luck!! Don't forget to rate this post!!
Sep 27, 2010 | Amana ACS7270AS Electric Kitchen Range
The stove just says F1 and beeps won't let me do
Hello with the limited information and no make or model I can only give a generic response to this one. Most manufacturers F1 code indicates a bad control board (EOC) and or a bad touch-pad. If you have any other questions please feel free to comment. Mike
Nov 03, 2009 | Ovens
Oven beeps and displays ''F1''
Un plug the stove from the outlet. Give it time to reset itself, 24 hours if possible. Replug the stove, and you should be able to reset the clock and the beeping should have stopped also.
Aug 17, 2009 | Kitchen Ranges
The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Self cleaning ovens
i have the same problem. the burners work and f1 is flashing and the oven wont work. i turned the breakers off but it does not reset. i just want my oven back and i will clean it myself.
Sep 05, 2008 | Kitchen Ranges
Stove reads "F1" on the display and beeps
Go to www.applianceaid.com/images/ge-built-in-oven-faultcodes
Jun 14, 2008 | Frigidaire FGF326AS Gas Kitchen Range
Magic chef stove
F1 means the computer has corrupted....... Part is probably around $150-200 Please rate my help solved as I solved your question.
Oct 04, 2007 | Magic Chef CGS3760 Gas Kitchen Range
Amana ACS7270AS Electric Kitchen Range Logo
327 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
