Question about GE DSKP233EWWH Electric Portable Dryer
Dryer doesnt turn on
Buzzes when turn to start doesnt start
  • eric bosman
    eric bosman May 11, 2010
    you can call GE directly with this question 800 626 2000.
    let me know what they say and i can help you further
I had the same issue. Just open the dryer door you don not need to unplug the unit. Then manually turn the dryer tumbler clock wise 3 times. Close door and turn on your dryer. That should fix your issue.
Posted on Jan 02, 2010
  • Cain C. Jan 02, 2010
    Open dryer door, manually rotate the tumbler clock wise 3 times. Close door and turn on dryer.
    Problem Solver:
Take the top of your dry off and look by the buzzes to see there fuse there it could need new one
Posted on Sep 30, 2008
My dryer doesnt go on. The front panel still clicks and when i push start button it buzzes but doesnt go
Belt, fuse, door switch, timer switch, something caught on the drum (all sorts of things get caught back there), heat sensor (depending on the age, had one that had a heat sensor would turn the dryer off, if told the computer dryer was overheating even though had not been running), bad motor, bad motherboard for dryer (again depending on age of dryer)
Jan 06, 2015 | Dryers
Why it doesnt start and make a long noise
Grandson just had this problem with our dryer. he was setting the timer by turning it counter clock wise, all he got was a buzz. When it set it clock wise it worked find.
I know this is a simple fit but worked or him
Randy
Apr 29, 2014 | Siemens WFXD5200UC Front Load Washer
Door is ajar message when shut light comes on but doesnt run
That's because the door switch isn't getting pushed when you're closing the dryer door for some reason or another. Its located at the top of the door. Try pushing the switch by hand and seeing if the light shuts off when you manually push it.
Nov 27, 2013 | Samsung DV337 Electric Dryer
Drum doesnt turn dryer makes buzzing noise
Just fixed one with same problem for customer. Sorry to say but most likely faulty motor. One test you might perform, and this isn't full proof but, is to bypass door switch and attempt to turn drum by hand whilst engaging starter switch. If dryer starts it is most probably motor. Also If this usually occur after heavy usage, or has in the past, it's almost surely faulty motor.
Aug 20, 2013 | Dryers
Maytag Performa dryer blows fuse after clothes get hot. I cleaned a large buildup of lint from inside the dryer all the way to my roof. I then replaced the hi limit thermostat, thermal fuse and dryer...
their are two possiblities causing that
1) while cleaning the lint from the motor a wire accidently got pulled of of the motor switch
2) to me the buzzing when start button is pushed and may or may not start,the motor is bad
When trying the trick to start the motor by hand the door switch also must be pressed in
Gene
Aug 05, 2011 | Maytag PYE2200 Dryer
When I push the "Start" button there is a buzzing
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 15, 2011 | Fisher and Paykel DE06 Electric Dryer
Dryer buzzes when you push start button but doesnt start
heatman101
Oct 27, 2010 | Kenmore 600 7962 Dryer
Dryer will not start when I push the start button. All I get is a loud buzzing.
The buzzing is a good sign that the motor is bad...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Oct 11, 2010 | Maytag MDE9700AYM Electric Dryer
Dryer doesnt go on
I opened up the lower panel of my kenmore 90 and then removed the blower cover. I found two hair pins lodged in the blower and removed them. I tested the dryer with it open and the blower and drum began to turn again. I buttoned everything back up, and it is running fine now.
Jul 21, 2009 | Kenmore 73952 Gas Dryer
Hello jslovik,
Welcome
You said, When you turn the knob a buzzing sound starts but that's it. The Buzzing continues as long as the start button is turned. Dryer is only 2 years old. Any help is very appreciated.
It sounds like the starting switch is bad!
10 134398300 Switch,start ,turn type In-Stock $ 11.29It appears in the diagram at the page below in diagram # 10
http://www.pcappliancerepair.com/model-display.php
If you do not know to diagnose this or repair it, please call an authorized tech.
Let me know what you do and how it goes for you?
Huuum
Believed I solved your question.Happy to have been of assistance.
Please remember to leave a rating.
Sep 19, 2008 | Frigidaire FGQ332ES Gas Dryer
GE DSKP233EWWH Electric Portable Dryer Logo
284 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Are you a GE Dryer Expert? Answer questions, earn points and help others
