Question about Toshiba Satellite A100-S8111TD Notebook
I have a Toshiba A205/S5000 laptop and it fell from my coffee table. When I powered it back on,it showed nothing but a completely white screen and I bought another LCD and installed it and the screen is still completely white. However, I can attach an external monitor and it shows everything just fine. What do I need to do next to fix my problem?
YourTech
  • 63 Answers
SOURCE: Data Shows up only on External Monitor, not on Laptop Screen
If your system won't display anything w/o the external monitor. there's something wrong with the LCD's backlight. you may have to contact your laptop's manufacturer and check if this laptop is still under warranty. you may have to get the lcd replaced.
thanks.
Posted on Aug 26, 2008
  • 104 Answers
SOURCE: Toshiba Satellite A205-S5814 laptop will not power on
clear the bios by removing the small battery on the mainboard for 10 hours.the power on
Posted on Aug 01, 2009
bob_computer
  • 3153 Answers
SOURCE: toshiba satellite a205-s4629 15.4'' Notebook
Try Here
And for help with the process take a look at this site
Posted on Aug 30, 2009
budmrtn
  • 11361 Answers
SOURCE: Toshiba A205 S5804 no backlight
You need to check and see if you have 12vdc feedind the inverter board, there is a very small surface mounted fuse (Fx) ion the inverter board, just put one of the meter lead to metal part of the laptop, and anothe lead on the fuse (check both side of the fuse). Is the inverter board new or used?
Posted on Mar 05, 2010
  • 11800 Answers
SOURCE: Laptop Monitor shows balck and white stripes
From what i can barely see it your photo it looks like your video chip  (which is part of the motherboard's chipset) has died. It will be expensive to replace the motherboard.
To recover all your data is easy - just remove the hard disk from the laptop, put it in a case like one of these
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010010092%201053807124%201054107131&name=SATA
then connect the case to another pc.
Posted on Mar 26, 2010
My Toshiba Satellite A205 S5000 came with 2 Ram memory chips of 1GB each. The OS is Windows 7 with 32-bits. Can I upgrade the memory to 4 GB by inserting 2 memory chips of 2GB each?
Hi Lewis
yes you can
here is the link but is cheaper if you just write down the exact numbers from the website and buy in computer warehouse or shop.
http://www.crucial.com/uk/upgrade/Toshiba-memory/Satellite+A205+Series/Satellite+A205-S5000-upgrades.html
but don't forgot to clean your laptop airflow with air duster every month with this you prevent the dust clogging up.
blocked airflow lead to owerheating
and heat differential is not good especially on lead free compound because the composite of welding material contain
silver and aluminium these metals hate each other both has different friction and heat transfer.
lead is more efficient but by eu law is not permitted any more.
if you want to run fast tasks you should go for pc laptop has modified core voltage is slower than computer
and all the high spec numbers are to attract customers to spend money.
Oct 23, 2013 | Toshiba Satellite A205-S5000
I have a Toshiba Satellite a205-s5000 that I replaced the power jack in. They sent me the wrong plug, mine was hard wired into the board so I cut and spliced the new plug to the wires coming out of th
Looking up the DC Power jack for this model, shows me a Center Pin, and cylindrical metal shell; inside the jack.
Center pin is Positive, cylindrical metal shell is Negative.
Also shows it to be a DC Power Harness. Wires connected to the jack, and end in a white plug; that plugs into the motherboard,
http://www.laptopjacks.com/view_part/Toshiba-Laptop-DC-Power-Jack-TS462625.html
http://www.youtube.com/watch?v=lLPlSsEx5F4
Granted, the above is a A205-S4000 series.
(A205-S4577)
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-3.htm
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-17.jpg
So...................
1) Am I to assume someone broke the female connector on the motherboard, that the DC Power Harness used to plug into?
Hard wired in this statement would reflect there was a DC Power Harness, soldered directly to the motherboard?
2) Or is your statement that the DC Power Jack itself, for your model; is soldered directly to the motherboard; and you hard wired the new jack in place; after cutting the plug off of the end of the new DC Power Harness? (And removing defunct DC Power Jack)
Plus; Is this an A205-s5000, or one of the A205-s5000 model series?
A205-s5800, A205-s5801, A205-s5803, A205-S5843, etc.
Yes.
Trying to figure out why this A205, has a DC Power Jack soldered directly to the motherboard, and is not using a DC Power Harness.
Why?
Have to make sure you are soldering to the right area, yet alone the correct contact points.
Don't know what I'm talking about? You unsoldered the DC Power Jack FROM the motherboard? Or the jack was soldered to wires, and wired to the motherboard.
Hardwired. The term can be used for either scenario.
That's the way it was originally?
K
Let's go on.
The DC Power Jack is connected to the DC to DC power circuit; on the motherboard. (Power/Charging circuit)
This circuit is near where the DC Power Jack is mounted, or where the DC Power Harness plugs in.
In the circuit are Surface Mount Devices that are prone to go bad.
One is the Power MOSFET's, the second are MLCC's.
(Multi-Layer Ceramic Capacitor.
They, and the P.MOSFET's, are SMD/SMT
Surface Mount Device/ Surface Mount Technology)
http://en.wikipedia.org/wiki/MOSFET
http://en.wikipedia.org/wiki/Power_MOSFET
Let's use the HP Pavilion dv6000 series, and Pavilion dv9000 series Notebook PC's, for an example,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
These series of Notebook PC's use the;
Fairchild Semiconductor International - FDS6679 - Power MOSFET, and the,
Alpha & Omega Semiconductor Limited - AO4407 - Power MOSFET.
Look at the second photo down, with the AO4407 circled in Yellow.
Immediately below it, (Right corner), and immediately to the right of the AO4407; are MLCC's.
Smaller rectangular object with a dark wide band in the middle of it.
There is one above the one, to the immediate right of the AO4407; one above it, one to the Right of the top one; and one to the right of it.
There are also 4 smaller examples to the bottom/left corner of the AO4407.
Look to see if any are burned/blackened.
Example of availability, and cost of FDS6679, and AO4407,
http://www.mouser.com/Search/Refine.aspx?Keyword=FDS6679
Scroll down. One Dollar and one Cent, USD.
http://www.mouser.com/Search/Refine.aspx?Keyword=AO4407
Here we see the AO4407 is phased out.
Using one of the cross-reference examples given,
http://www.mouser.com/ProductDetail/Diodes-Inc/DMP3020LSS-13/?qs=%2fha2pyFadujguNNSgppBRqXbOxXLwzGsZm9SWxz1EqWpzoSJOpHpWA%3d%3d
78 Cents USD.
Just to show examples of MLCC's that are SMD/SMT.
The examples I chose are 4.7uf (MicroFarad), and 16 Volts. (DC)
http://www.mouser.com/Passive-Components/Capacitors/Ceramic-Capacitors/Multilayer-Ceramic-Capacitors-MLCC-SMD-SMT/_/N-b2cj?P=1z0wrjcZ1z0x565
Scroll down.
http://www.youtube.com/watch?v=5uiroWBkdFY
You can use a 25 Watt soldering iron, instead of a Soldering Station.
[ Plus Rosin core solder, rosin solder flux paste, flux paste brush, and Desoldering Braid. (Solder Wick ]
http://www.youtube.com/watch?v=b9FC9fAlfQE
Can things be worse? Yes,
http://koti.kapsi.fi/jpa/stuff/pix/travelmate_6292/
For additional questions please post in a Comment.
Regards,
joecoolvette
Dec 22, 2012 | Toshiba Computers & Internet
Toshiba satellite CD door will not open
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
1) ALL power removed. Remove the AC adapter (Charger), and Battery.
2) Turn the laptop over bottom side up, Battery Compartment facing AWAY from you, down on a table.
You may wish to lay a soft Static free cloth on the table, to prevent scratching the table, or laptop.
3) Take this cover off,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-02.jpg
Remove the Ram Memory module/s. ('Stick')
Lay them/it carefully aside. Handle by the BODY. The Body is everywhere on the Ram Memory module, EXCEPT the gold plated contact pins at the bottom.
The Body is coated with a see-through protective plastic.
4) Remove this Philips head screw, and push the optical drive out,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-03.jpg
The top of the optical drive will have small Philips head screws, or Torx screws. They sell Torx screwdrivers real cheap,
http://en.wikipedia.org/wiki/Torx
Remove the screws, remove the cover, remove the disk.
Regards,
joecoolvette
[Sounds like you may need a replacement optical drive ]
Oct 31, 2012 | Toshiba Satellite Computers & Internet
Can the memory be expanded?
Your Satellite A205-S5000 System Specs Memory:DDR2 PC2-6400, DDR2 PC2-5300icon_detail.gifMemory Type: DDR2 PC2-6400, DDR2 PC2-5300, DDR2 (non-ECC)
Maximum Memory: 2GB
Slots: 2
Each memory slot can hold DDR2 PC2-6400, DDR2 PC2-5300 with a maximum of 1GB per slot.
Sep 12, 2012 | Toshiba Satellite A205-S5000
How do I purchase a Disk Drive for my Toshiba A205-S5000
from this website:
http://www.sparepartswarehouse.com/Toshiba,Satellite,A205,PSAE3U-07Y023,Laptop,Parts.aspx
Dec 30, 2010 | Toshiba MK1637GSX 160 GB IDE Hard Drive
I dont know the password to the toshiba a205-s5000
hello sir u didnot mession the password for the windows or password for the bios...
if bios password ...
1- remove memory cover
2-remove ram
3-remove striker
4-find the very small jumper GOLD color
5-just short for 2 or 3 time together
and return everything back..
if password for windows...
download hiren cd image .. u r find from google.. Thanks
Oct 22, 2010 | Toshiba Satellite A205-S4617 Notebook
Toshiba Satellite A205-S5000 i changed a broken screen and now computer does not start, it seems like is a power problem, the power lid turns red as soon the computer starts
Sounds like while replacing it you may have clipped or forgotten to attach a cord when putting it back together. I'd open her up, and look at everything you touched, and see what isn't hooked up or what cable is broken. If you find none, it's very possible you gave your computer a static shock and fried your motherboard. If that's the case, get a new PC.
Mar 16, 2010 | Toshiba Satellite A100-S8111TD Notebook
A205 s5000 motherboard. Where can i get one?
Google is your friend
http://www.sparepartswarehouse.com/Toshiba,Satellite,A205,Laptop,System-Boards.aspx
Sep 17, 2009 | Toshiba Satellite A205-S4617 Notebook
Dual Processors for Toshiba Satellite A205-S5000 533Mhz FSB
you got a cheap laptop. maybe from walmart or some other store that was selling it for about $400. It doesn't have a processor that you can switch out. I'm sure it's horribly slow for Visa, so my advise would be to sell it and get something with a dual core.
Feb 26, 2009 | Toshiba Satellite A205-S4607 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
181 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
