Question about Amana ABB1927DE Bottom Freezer Refrigerator
Freezer lower basket: how to get a replacement part not available in Canada
I have an Amana fridge model ARB2217CW, bottom freezer, and can't find (here in Canada) replacement for the freezer lower basket (no longer manufactured); what other model uses the same or compatible basket, so I can try and order the part? Thanks.
  • 145 Answers
I can't find a cross reference that shows avalible. The lower basket part number is 67001240. I would try a web search for that number some still has it in stock somewhere.
Posted on Apr 18, 2008
The refrigerator portion of my Amana ARB2217CW stopped cooling (the fan is still running), but the freezer drawer portion still works fine. What can
most likely you have a bad damper,go here to see it
http://www.repairclinic.com/PartDetail/Damper/67003410/1025326
all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air to the fridge section and it goes through the damper,when it gets cold enough in the fridge section the thermostat on the damper closes the damper door,your damper broke in the closed position,this is as long as the door wasn't left open or anything like that,if it was the air ducts could have froze up but most likely it will be the damper.go here and it will show you where it is up near the light in the back and it's part number 18.hope this helps
http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-ARB2217CWPARB2217CW1/1268/0161000/M0403273/00003?blt=06&prst=&shdMod=
Sep 04, 2012 | Amana Refrigerators
ATTEMPTING TO LOCATE DEFROST TIMER. DO U KNOW LOCATION ON MODEL # ARB2217CW
Up in the console with the light bulb and cold control is that there defrost timer. Number 12
Jan 01, 2011 | Amana ABB1927DE Bottom Freezer...
After a bottle of gin broke spilling it's contents in the upper portion of our bottom freezer Amana Model BRD18V2S, The refrigerator no longer gets cold, we have aired out the liquor fumes and although the...
My wife posted the information below and I would like to add more to the story: We have two identical Amana Bottom Freezer Refrigerators, Model:BRD18V2S installed in our Kitchen. Both fridges are in an alcove and stand next to each other. One fridge is used as the beverage fridge and othe other is used as a food fridge. At about 10pm she noticed that an entire bottle (600ml) of Gin had cracked and emptied into the refrigerator section of the fridge used for beverages. We do not know how long the spilled gin was in the fridge. She mopped it up and we went to bed. At 7am the next morning, the beverage fridge and its freezer were showing 71 Degrees F. and everythind including the ice had melted. (We have aftermarket external temperature gages that show the fridge/freesor temperatures) The food fridge uninvolved with the gin spill was reading 68 Degrees F
Sep 17, 2010 | Amana Refrigerators
I have a hotpoint fridge freezer model ff92ys the freezer is running ok but the fridge isnt cold enough i try to set it at +4 but it just sets itself back to +20 please help
The thermistor has probably failed. I had the same problem with my FF92s fridge/freezer. I replaced the thermistor and hey presto it works again.
The thermistor is loacted behind a removable panel inside the freezer section of the fridge/freezer. You also have to remove a polystyrene cover and a further metal cover to get tp the thermistor. Pull the metal cover from the left as it has wires attached to it on the right hand side. The thermistor is available to buy online, just google it.
Feb 05, 2010 | Amana ABB2227DE Bottom Freezer...
Model number ARB2217CW Amana Refrigerator Bottom Freezer. The freezer is working fine but the fridge has stopped cooling. No strange noises, no frost, no water leaking--just not cooling at all.
I would check the circulating fan. This problem is very hard to diagnose because the fan spins but not fast enough to circulate the chilled air thru the freezer and the frig.
Aug 01, 2009 | Refrigerators
Amana ARB2117BW - Bottom Freezer Door Won't Stay Sealed
This problem was posted in the wrong section. My model didn't have it's own, so its in ABB1927DE Bottom Freezer Refrigerator - perhaps you could create a section for it.
As it turns out, I looked more closely at the baskets inside. We had noticed that if the top basket was slid all the way forward when we closed the door that it would close better. So I looked to see if they or the slides were out of alignment. They seemed ok, but then I saw that the way the bottom basket was hanging didn't seem right - it was not quite nestled into it's retainer slot. I took the baskets out and turned the bottom one around. It fit perfectly into it's retainer slot. I then replaced the top one (it was already in correctly) and closed the door. It sealed correctly the first time. I tested it several times after that and it sealed tightly. Closing the top door did not make it unseal as it had done before.
Jan 23, 2009 | Amana ABB1927DE Bottom Freezer...
Freezer Not Defrosting
Hi Rusty...
There are 3 componants to most defrosting systems. The defrost heater, the defrost thermostat, and the defrost relay. First you must remove and store your perishables safely. Then remove the panels in the freezer compartment to expose the evaporator. The defrost heaters will be attached to the evaporator and will have wires extending from them. Using an ohmmeter, see if there is continuity across the heater. If not replace it. Find the wiring diagram on the back of the unit and check for voltage into and out of the defrost relay. All of these items should be availible from a local refrigeration supply facilitiy.
Ray
Nov 12, 2008 | Amana ABB1927DE Bottom Freezer...
My amana bottom freezer won't cool both the fridge and freezer are warm
Ice build-up inside refrigerator and cycling switch not functioning. Requires technician to take apart inside of refrigerator, clear ice and replace switch. Took my repair man about half hour to fix.
Nov 04, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
Have Amana refrig with bottom mounted freezer Model ARB2217CW. Noticed the last day or so it makes a buzzing noise--almost like an electric shaver then it shuts off with a click. Today items in freezer...
See the post by lola77 with the same complaint. We have an Amana top/bottom freezer and are having the same problem and we've only had it 4 1/2 years. First service call available that the 1-800 number gave me was 3 days from now, which is ridiculous.
Aug 27, 2008 | Amana Refrigerators
Amana ABB1927DE Bottom Freezer Refrigerator Logo
163 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
