Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
I have a d link wbr 2310 router which is on the lower level of my house. I have very poor wireless signal strength to my laptop when I use it on the first floor and the second floor. Any suggestions on how to boost the signal strength?
  • 8,404 Answers
Move the router to the first floor ... out of the lower level ...
Posted on Jul 05, 2010
  • 2 more comments
  • sec Jul 09, 2010
    With all due respect, I am surprised you gave such a simple answer without any consideration of how that can practically be done. I get my internet service through my cable company and my modem is on the lower level. With the router hard wired to the modem, I don't see how I just move the router to the first floor. Without a lot more discussion, you really have not offered much of a solution.
  • A Miller Jul 09, 2010
    Oh con'trair ... I move cables all the time, I don't see improving my system as a burden ... Running a cable (from one level to another to connect your cable to your modem) up a air return or through a closet or around the edge of the carpet or along a pipe chase is no big deal ... and you can run it probably up to 200 feet or more if you wanted to ... Your wireless should be good for up to 250 - 300 feet in good circumstances ... Do you only have cable in the lower level? No other cable outlets in your home? The modem doesn't really care where it is attached to the system (with come constraints). No TV outlets on the first or second level ... no crawl space ... no garage? Run the cable on the outside wall ... that is how many homes get cable ... running down the outside wall into the home. How did the cable get in to your house to start with?
    I thought you were interested in a simple, easy answer. The simple easy answer is move the router. Want complicated? We can talk about bridges and amplifiers and any of the 11 different layers of the 802.11b/g standard if you want. There are alternatives to moving the router including installing Cat 5-e wire (which will give lots better security and much faster speed), plug in adapters that use your house wire as network connections ... where do you want to go?
    Why is your signal poor? Poor location? Low power in to your device? Is there a problem with the device you aren't revealing? Do you have foil based wall paper on your walls ... or do you have foil water vapor barrier on your insulation? Is there foil under your floor coverings? Anything else you have not considered or revealed? You only need more creativity.
    I have multiple operating computer (3), telephone (2) and TV networks in my home --- wire and wireless and all of the things I have encountered and over come all or the issues I mentioned above ... and more. And mine work. Though I don't use nearly all of it ... I have more than 1000 feet of RG 6 installed at 40 + locations around my home and grounds.
    I'm sticking by my guns ... the simple thing is to move the router. Next simple thing is use a wired network. Of course you coule move your computer closer to the router ...
    As a volunteer here at FixYa.com (like all the others), I was only trying to help you with a simple solution.
    Thanks for your interest in FixYa.com
  • sec Jul 10, 2010
    I really appreciate your response. The additional information sheds a lot more light on the situation and I understand why you gave the answer you did. I am not all that computer literate, so I thought moving the router was not really an option. With the comments you proved, I will give it some more thoughts. Moving it may just be the answer.
    Thank you.
  • A Miller Jul 10, 2010
    Thank you for the feed back ..
    Moving your router is not a big deal at all ... You can run a new cable to the spot where you want to place your router (more centrally) or you can just move the router to a existing cable outlet, and ust that outlet or split it off ... If you install cable ... use RG-6 not RG-59
    This is an over simplification ... but it may work with no further modification required.
    Thanks for the 4 thumbs up ... We volunteer's appreciate all the points we can get.
Win7 & vista keeps losing connection with WBR-2310 router
Signal strength drop or fluctuation are common causes of RF interference.
Try these basic troubleshooting steps:
• Change the channel on your access point or wireless router.
• Change the location of your wireless products. Subtle changes (2-3 feet) can make a big difference. Do not put the access point or wireless router in a cabinet or enclosure.
• 2.4GHz phones, X-10, and bluetooth devices will interfere with your wireless network. Change the location of the base for your phone, or downgrade to 900Mhz phones, or upgrade to 5.8GHz phones.
• The wireless signal will degrade (or die completely) when going through brick (fireplace), metal (file cabinet), steel, lead, mirrors, water (fish tank), large appliances, glass, etc.
If your wireless connection is only dropping during large file transfers or when a large number of wireless clients are connecting, change the preamble on all wireless devices to short.
Nov 11, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
I have a D link router a outdoor antenna which isadvertised for a 3 mile range. I am about 2oo yards from the antenna. My computer indicates a the signal strenth as good but i keep dropping off the net....
please observe signal strength as when you are connected to network and till you drop off, there may be distraction in signal strength while you are connected and when you check it again, it comes to good again.
Jun 27, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Low wireless signal wbr 2310 on signal strength
Hi Thanks for your question.
My advice would be to consider moving your router to different place. Put it a bit higher. There's also a lot of products like bigger antennas and wireless range expanders that you could consider buying. Here's link to some of the products so you can have a look what I mean---> click hear You could also try low cost home ways to boost your signal like- Attach a bit of aluminum foil to the router antenna. Position the foil so that the signal bounces off the foil in the direction of your computer. I hope this was helpful. Good Luck
May 08, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Low wireless signal WBR 2310 on signal strength
when a wireless router has signal strength issues, there usually is a firmware upgrade, which you can find on the manufacturer's website, that may solve this problem by upping the db of the wireless transmitter.
Apr 20, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Wireless signal stops working after some period of time
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
Sep 26, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Dlink wbr-2310 router no wireless working
you have to change your channelk type in your wi fi router.
For that access your router with following link
http://192.168.1.1 or
http://192.168.0.1
if you have belkin router
http://192.168.2.1
type user name as "admin" and password is "admin" or blank or "password"
then go to wi fi ->advanced setup chang channel type 4 ,6 ,11
change chanel type 1 by 1 and check signal strength.
everyt time save settings and restart both computer and router after save settings.
Thanks for using fixya.
Please rate this solution if it helps.
Jul 23, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
D-link WBR-2310 has serious drop out problems
I'm pretty sure that downgrading the firmware to 1.0.3 will work. I had been running at this level for quite some time and for some reason I decided to upgrade to the latest version which started the problems for me. I am downgrading to this now and I expect better results. All of the firmware versions are available at http://www.dlink.com/products/support.asp?pid=470&sec=0. You pick the right hardware revision. PLEASE NOTE: Save off/remember your settings as when you change the firmware it resets all of them back to system defaults.
Dec 12, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
We just bought the d-lin wbr-2310....
there is no any other special settings if u keep the laptop very far it will not receive the signals >try this login to ur router and change the wireless channels use 1>or 11>it may help to improve the signal strength>and check with antena on the router weather its straight>rate me solved if its help full
Nov 04, 2007 | D-Link RangeBooster G WBR-2310 Wireless...
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
51 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
