Question about Canon PIXMA MX310 All-In-One Printer
How do u use the scanner on the canon pixma mx310 all in one printer?
    President:
  • 1,961 Answers
If you load the documents and press the SCAN button, the file will be save directly to the pc as pdf file.
You can use the scanner option on the control panel to scan the documents and save as jpeg file. How? Go on Start...click Control Panel...then select Scanners/Cameras..click next and follow instructions..
Just post back if you still have question
Posted on Nov 22, 2010
SOURCE: canon pixma MX310 scanner not working
I read somewhere that the printer/scanner must be plugged directly into the computer in order to scan.  I tried it, and it works.  Printing can be done wirelessly, but apparently not scanning!
Posted on Feb 25, 2009
IB4G2008
  • 3587 Answers
SOURCE: canon pixma mx310 printer
try this link, to see if your driver is still avail...
Posted on Mar 12, 2008
SOURCE: Scan problems with Canon MX310
I had the same problem. After replacing the USB cable with a good one the scanner came back to life.
I suspect scanner has a higher requirement for USB data transmission thats why printing and copying work but scanning does not.
Posted on Sep 20, 2008
SOURCE: where is the serial number on canon pixma mx310?
The serial number is located inside the maching, behind the tape attached to the cartridge carrier. When the cartridges are all the way to the left side (position for changing cartridges), the serial number is visible at the center-right position. Open the maching as if you were going to change cartridges.
Posted on Mar 11, 2009
efs_perpends
  • 1996 Answers
SOURCE: Posted already but it seems to have vanished. I
The response from Canon for your error code, 5B00, is as follows:
1. Press ON/OFF switch to reset the multifunction device 2. The MX310 may require repair You can access Canon's support site with specific solutions to any error message you get for that machine by clicking here.
I hope this information allows you to resolve this issue.
Posted on Apr 10, 2009
How to scan negatives?
You will need to check your Canon software that came with your Pixma MX310. I have a stand alone Canon Canoscan 8800F scanner that have the capability to scan 35mm film strip and 35mm mounted slide, the software included the feature for it.
Nov 07, 2013 | Canon PIXMA MX310 All-In-One Printer
HOW TO USE SCANNER
i have found the way to scan items from a Canon MX310 (on windows)
1.On windows go to control panel
2. click hardware and sounds
3. then hit devices and printers
4. then click on the Canon Inkjet MX310 seriers
5. then you will see scanner management click on scan Photos or docs
6.then place the photo or doc under the scanner and hit scan!
That is all the steps you will need.
17 years old computer tech.
Dec 15, 2011 | Canon PIXMA MX310 All-In-One Printer
Trying to scan something to the pc and the printer says pc standby. I do not have any software.
If you have a Windows or Mac OS X PC, go to Canon.com and download the TWAIN (scanner) driver for the Pixma MX310 printer; and of course install it, so you can scan. Otherwise, try both FOSS scanner backends.
Aug 11, 2011 | Canon PIXMA MX310 All-In-One Printer
Hallo! i have a canon mx310 printer. can i use scanner without ink crtridges?
Yes you can.
You can download an user manual from this WEB site.
http://www.retrevo.com/support/Canon-MX310-Multifunction-Printers-manual/id/3376ci866/t/2/
Jun 20, 2011 | Canon PIXMA MX310 All-In-One Printer
How can i fax and scan on canon mx310
for scan, in windows go to accessories
click on scanner and camera wizard
select your pixma mx310
click on next
click on preview for preview you document or photo click next
click next
now it show your scan document
enjoy
M. Zahid click next
click finish
May 14, 2011 | Canon PIXMA MX310 All-In-One Printer
I have a Canon PIXMA MX310 All-In-One Printer but i cannot use one of the function , the scanner . What should i do ?
Since you can print, its confirmed that you have installed the printer driver.
If you have not installed the Canon scanner driver then
Please click on the following link and confirm if you have installed the Scanner driver
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx310#DriversAndSoftware
Select the Operating System (OS - Windows ) you have.
post which you should be able to use the scanner.
Dec 05, 2010 | Canon PIXMA MX310 All-In-One Printer
Canon mx310 all in one printer-scanner will not work with my mac
Have you installed related software and/or update from Mac ? You need to control the scanner from Mac thru related program not thru the scanner....I have same printer-scanner and MAc ,all work perfectly..Please be more spesific on the problem..
Dec 09, 2009 | Canon PIXMA MX310 All-In-One Printer
How do i use the scanner on my Canon MX310 ?
You need to control the scanner thru your PC with canon software that came with your printer/scanner otherwise you cant scan anything..
First open the printer/scanner software on PC,select scanner,then place your document and command "scan" on your PC..On this window you can also alter the scanner preferences..thats it..
Nov 13, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon MX310 sacnner not working (mac)
Use Spotlight and search for MP Navigator or look in Applications>>Canon Utilities>>MP Navigator
Sep 30, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MX310 All-In-One Printer Logo
364 people viewed this question
old marine
old marine
