Question about Kenmore Refrigerators
Kenmore side by side refrigerator. Model 106.56569400 Strip inside the refrigerator between the freezer and refrigerator is hot to touch. Freezer and refrigerator are cooling fine, but if you reach inside the refrigerator and your arm touches the side, you will **** it away because it is hot -- not warm, hot.
  • 2,272 Answers
Make sure the condenser fan is working all the time and make sure the condenser coils are clean. Also the fan and coils are running OK and coils are clean not too much frost build up on freezer coils.
If the refrigerator and freezer are both cooling properly then a warm (even to borderline hot) mullion is normal for this type of refrigerator. The mullion is the strip between the refrigerator and freezer compartments that you are describing. There are some reasons that it can be warmer than normal. The longer that the compressor runs, the warmer (or hotter) the mullion will be. If you just added new food to the refrigerator or freezer, this could cause the compressor to run longer. Opening the doors frequently can also cause the compressor to run longer. An air leak through the door seals on the refrigerator or freezer could also cause the long compressor run time. Check the door seals for cracks or loose spots.A failed condenser fan or extremely dirty condenser coils could cause the mullion to be warmer than normal. You can clean the condenser coils by unplugging the refrigerator and removing the bottom front grill. Clean any dust off of the grill. Clean the front of the condenser with a soft brush and a vacuum cleaner. Replace the grill when you are finished. Plug the refrigerator back in. You can check the condenser fan by removing the bottom service panel on the outside back panel of the refrigerator. If the fan is not running then this will definitely cause a hot mullion. This type of problem will normally need to be repaired by a service technician. Here is a link for the Sears Service website in case you need it: Sears Home Services . Be sure that you replace the bottom service panel on the back of the refrigerator once you determine whether the condenser fan is running. This panel needs to remain in place for proper air flow through the machine compartment at the bottom of the refrigerator.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Posted on Jul 05, 2010
Freezer has warm spots. All around freezer is hot to the touch. Compressor is hot, coils are clean, condensor fan is running.
Thats normal.
The condenser coils are located just inside of your exterior cabinet walls on the sides and top.
So the freezer gets cold inside and heat has to be released from the condenser coils.
If this is something new, you may have a problem with the defrost timer
Sep 11, 2011 | Kenmore Side by Side Refrigerator
My Kenmore side by side freezer is so hot on both sides I can hardly touch it.What can i do?
Here is a tip that I wrote about the reasons why the sides and/or seals couldbe getting hot on your refrigerator.
RefrigeratorTrouble The Outside of Refrigerator Hot
heatman101
Jul 24, 2011 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Inside refrigerator strip between the freezer and refrigerator
The condenser fan motor at the back near the compressor is either dirty or not running at proper speeds. Clean the coils for air flow over compressor and if the fan is not running replace the fan.
Jul 05, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The divider between the freezer and refrig is very hot to touch.
Normal for that strip to be warm since the cooling system is routed right behind it for heat transfer and to eliminate condensation. Will be warmer with increase in room temp, but if it is a significant change you should inspect/clean the coils behind the panel in the rear of the unit.
Jun 24, 2009 | Kenmore 57029 Side by Side Refrigerator
Refrig is hot to touch
Hi, Have you checked to see if there is a frost build up in the freezer? How are the temperatures in the fresh food side or the freezer side? Check and make sure the evaporator motor is running in the freezer. Please let me know if you find any of these issues. When that area is hot, usually there is more going on and the temps are not right. Let me know so I can assist you further.
Thanks
Vic
May 10, 2009 | Kenmore 53542 / 53544 Side by Side...
Hot to touch
there is another fan at the bottom, rear, of the refigerator. remove the bootom panel and look at the cooling fins to make sure they are not bent into the fan blades. Caefully bend the fins away from the fan. this should improve the cooling of the refrigerator and get rid of the hot spot on the rail between the refrigerator and freezer.
Apr 26, 2009 | Kenmore 53542 / 53544 Side by Side...
Samsung model # rs2630sh side by side fridge. center strip is hot
I had the same problem, and it was the condenser fan motor. I ordered mine from www.partstore.com. It was half the price of sears.
I would suggest ordering the 2 "plastic bushings" for front and back of motor. I was able to reuse mine, but for a few dollars more it's worth it.
Jan 20, 2009 | Samsung RS2630SH Side by Side Refrigerator
Front metal piece that the seal goes against - between freezer and fridge
ED5VHGXMQ10 Whirlpool Fridge
I have the same problem. Too hot to touch between the freezer and refrigerator door. Is
this normal?
Jul 07, 2008 | Whirlpool GS6NBEXR Side by Side...
Panel between fridge and freezer extremely hot
this is happening because company used pipes inside refrigerator body, as you mentioned now its heating more than normal,. need some technician to check if there any blockage etc. otherwise less heating of body is normal.
Nov 30, 2017 | Kenmore 44103 Side by Side Refrigerator
Outside surfaces of freezer very hot to touch
it should be warm to the touch but not so hot you cant. and also depending on how long the freezer is running and how warm it is where the freezer is will effect how hot the outside is. the reason the outside of the freezer is hot is because thats how the freezer releses its heat from the refrigerant. the longer it runs or the harder it has to work the more heat it has to hive off. so unless the freezer is not cooling there is nothing to worry about.
Aug 07, 2007 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Refrigerators Logo
43 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
