Question about Acomdata PHD060U2E-54 60 GB USB 2.0 Hard Drive
When i plug it in it makes the connecting sound then the disconnecting sound and it doesnt appear on my computer how do i fix it????
I have the same problem, did you solve this??
Posted on Nov 20, 2010
Internet will loose connection frequently but without error msgs.if i try to refresh it will bring up the page but theres not any transfer of data. The only way is to disconnect then reconnect. i checked...
ok, first, see if the connection is a problem with the modem or the router.
1) find the average time in between disconnects.
2) disconnect the cord plugged into the "internet" port on the router.
3) plug that end of the cord into your computer.
4) now power off the computer and press the reset button on the modem (the box that your computer is now connetced to)
4a) if there is no reset button, unplug the modem for 30 seconds.
5) start up the computer and have wait for the computer to disconnect.
if it does, the problem is with the modem.
if it do not, its your router.
now to fixing it.
the easyest thing would be to buy a new roter or call your isp to bring you a new modem.
although, if you want to do it yourself (which may be a bad idea if your bad with tech.) then keep reading.
modem: find the defult ip for the modem, this will be on a sticker. if it is not, just google the model number, and you should be able to find this. check your signal strength as well as signal to noise ratio, call your isp and make sure this is normal. if it is not, they will have to replace your router... if they say its abnormal, make sure your not connecting through a split cable (as in you have a 'Y' split in the cable). your isp should do all this for free though.
router: periodic connection drop is rare for routers. it could be caused by a new ip address connctiong that has a conflict with a previous one. make sure you have DHCP turned on, and set your computers to automatically assign ip addresses. if that doesnt fix it, update your firmware (or if you have a linksys, do your self a favor and flash it with DD-WRT) if that doesnt work, its a hardware problem, and you should replace the router.
May 04, 2011 | Computers & Internet
When i plug in my camera my computer doesnt do anything and when i play back videos the volume doesnt work
  • Consider NOT connecting the camera to the computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
    Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive.
  • The ViviCam does not record any sound to go with its videos.
Sep 25, 2010 | Vivitar ViviCam 8025 Digital Camera
My USB 2.0 super-talent 4GB doesnt work,I plug it in my computer and his red light is off and nothing appear in my computer screen.i have some pics storaged.how can I fix this problem?
The first thing you should do is plug your USB drive into another computer to see if it works on that computer. If not, the drive may be bad. Does the USB connector end look bent at all? If so it may not be making the connections, and straightening it out should fix the problem.
Aug 29, 2010 | Super Talent: USB 2.0 3.5" HDD Enclosure...
Kodak easyshare m340 problems
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Mar 25, 2010 | Cameras
Ipod nano 4gb will not connect to my pc
I found the solution to this problem:
To get your iPod Nano 3rd Generation (4GB video) to be recognized by your computer, you will need to manually get it into "Disk Mode" here's how:
  1. Verify that it has a full charge, if not, you need to either charge the iPod before continuing or connect it to a high-powered USB port, or simply connect it to the Power Adapter that plugs into an electrical outlet. (just not connected to your computer)
  2. Toggle the Hold switch on and off once. (Set it to Hold, and then turn it off again. Just slide back and forth.)
  3. Press and hold the Menu and Select (center) buttons at the same time for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select (center) buttons and immediately press and hold the Select (center) and the Play/Pause buttons until the ‘Disk Mode’ screen appears.
  5. Disconnect your iPod from the power adapter and connect it to your computer;
  6. Now the screen on the iPod will change and say "Do not disconnect" and should be recognized by your computer.
I hope this helps you; I had a hard time finding a solution and thought I'd share the wealth once my stress was relieved.
Jul 11, 2009 | Apple iPod nano
My Creative Zen 4GB MP3 Player is just not turning On
I had the exact same issue and this is how i fixed it.
go to the zen website and download the latest drivers.
  1. Turn off your player.
  2. Disconnect your player from your computer.
  3. Press and hold the Play/Pause button. Continue to hold the button while you perform steps 4 and 5. If you accidentally release the button, start the procedure again.
  4. Gently push a straightened paper clip into the Reset hole.
  5. Slide the On/Off switch towards the USB port and hold until the display lights up. The Recovery Mode screen appears with four options: Clean Up, Format All, Reload Firmware, and Reboot.
  6. Select Reload Firmware, followed by Yes.
  7. Connect your player to your computer.
  8. Double-click the downloaded file and follow the instructions on the screen.
May 31, 2008 | Creative Labs Zen Micro MP3 Player
Lacie hard drive nonfunctional
You can try buying a new HD enclosure, then removing the HD from inside the one you got and mounting it inside the new one. Try also disconnecting completely the power cable from your computer for five minutes and then plug it back to the power and restart it. I know it sounds weird, but sometimes usb mass storage devices suffer troubles caused by electrostatic charges.
Hope
Feb 13, 2008 | LaCie Design by F. A. Porsche 160 GB Hard...
Speaker doesnt give sound
Based on the fact that you have put a headset in and another speaker system and it is working properly there is nothing wrong with your windows settings. I would leave them alone. The issue appears to be with the hardware. Have you attempted to plug the speakers into another source (ie. cd player, ipod, etc)? If you plug them in there and they don't work, take the speakers back and have them exchanged. If they're not under warranty you're going to have to either get them fixed or replace them. Good luck on this one! JC
Sep 30, 2006 | HP P5302M Computer Speakers
Acomdata PHD060U2E-54 60 GB USB 2.0 Hard Drive Logo
75 people viewed this question
Top Acomdata Computers & Internet Experts
Jerry Umali
Joe Goldman
Joe Goldman
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
