Question about Sony Playstation 3 (PS3) Console
My ps3 wont go online when i scan it picks up my router signel 100% but the test fails
  • bloodshot4u2 Jul 05, 2010
    fogot my wep password
Hmmmmmm/????????????? r u sure u entered the code rite and if not try on a different router signal! :D:D :D :D:D:D:D:D im to smexy for a PC so i have a laptop
Posted on Jul 05, 2010
It stopped connecting to wireless!
Myra, The PS3 internal antenna when connected to the board, is only a thin protected wire, so it is not the greatest system for range for wifi. However, it would seem the issue you are having is not connecting to the wireless router, but the router to the internet. The PS3 asks after you enter a new connection, if you want to test it. I always do this test and it is valuable. At the top of the test screen, you will see "connection to router"-Pass/fail, then connecting to internet-Pass/fail, then connecting to PSN-pass/fail. Do you have other devices connected to the router you are using? If yes, then you have a more serious problem. If no, then you just have to access the router via PC and set up the correct settings to allow your PS3 to connect to the internet. There are several different routers out there, so you will have to consult the manufacturer to set it up. Just a few key notes here. If you are ok with anyone accessing your internet, simply don't password protect it. And also, make sure that the router is transmitting by making sure it is in"air"mode. If it's not airing the SSID, then no device will pick it up. ^^ I hope this helps, and good luck.
Feb 19, 2016 | Sony Playstation 3 (PS3) Console
I have a ps3 ip's adress problem i have a belkin wireless router and when i turn on my ps3 it wont sign in so i go to test conection and it waits and then it says id's adress failed
Once you have all the wireless settings of the router, you are ready to connect the play station or the x-box to the wireless network.
Play Station
Now go to the settings page of the PLAY STATION
NETWORK SETTINGS ==>
INTERNET CONNECTION SETTINGS ==>
WIRELESS SETTINGS ==>
If you get confirmation screen displayed stating that you will be disconnected from the Internet. click YES ==>
select EASY ==>
select WIRELESS ==>
SCAN ==>
you will see your SSID ( wireless network name)==>
select the security settings ( router wireless settings)==>
enter the KEY ==>
select the IP address settings EASY ==>
save your settings ==>
Test the connection .
Jan 25, 2011 | Sony Playstation 3 (PS3) Console
For some reason my router is unable to be picked up by anything as an access point. It's a WRT160n V.3 Linksys router so it has an access point built in. However when I go to scan for a access point on my...
I believe you will need to upgrade the firmware of the router. This model has issues with the firmware. Download the firmware of the router from the www.linksys.com/download on the main computer. the computer should be connected to the router with the cable. Do not upgrade the firmware on a wireless computer.
open the set up page of the router and upgrade the firmware.
After upgrading the firmware, it is recommended that you should reset and reconfigure the router.
Click Here for more information about router and network
Feb 24, 2010 | Linksys WRT160N Wireless Router
Ps3 wont connect to wireless
Reset your router, then give your PS3 a static IP address and go into your router interface, find the DMZ feature and put in the IP address that you gave the PS3, just make sure the IP you give it is within the DHCP pool of IP addresses.
The PS3 will now be sat outside the routers firewall giving you FULL access to internet content and gaming online.
Now test connection settings and you will notice you will now have an open connection to the internet.
Thanks
Sep 02, 2009 | Sony PlayStation® 3 (60 GB) Console
Router wont let ps3 have ip adress
you need to open a incoming port for the ps3 on your router all you have to do is use the computer to go to your router settings then use whatever ip the ps3 is using and open a port for that ip address that should work but i dont have a ps3 so i dont know you could try that
May 09, 2009 | Computers & Internet
Can't connect wirelessly to my ps3
ps3 wireless card works with g and b mode only, sounds like your router is in n mode. you'll have to change it to mixed mode. to do that refer to your router manual or pdf manual in the cd.
Jul 30, 2008 | D-Link DGL-4500 Wireless Router
Ps3 issues
ok so for the ps3 you should select the option to scan for your wireless network instead of manually configuring it. if it asks for your wep key, you could find it under your modem. just look for the 10 digit key inside the brackets
Dec 10, 2007 | 2wire 2700HG-B Router (2700HGB)
Connecting PS3 via Belkin router to internet, wirelessly
I HV COMCAST AND THE BELKIN ROUTER AND I WANTED TO NO HOW CAN I CONNECT MY PS3 TO THE ROUTER.
Oct 28, 2007 | Computers & Internet
How do I get my PS3 Online?
right fist of go on settings on the ps3 menu then go to network setting then click onsettings and connection status list take a note of all the ip addresses and servers then go to internet connection on the same menu and click on scan then click on your router name and then lick onenter ur wep key if u av 1m but if u dnt then cck on none then press right then go o custom on the address setting then manual on ip adress settings type in all ip address and servers and stuff then click on auto on the mtu dont use proxy server enable unpn click right then press x to save ur settings then test connection thn hopefully this works for u m8 cheers arsenal_07
Mar 24, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
89 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
