Question about KitchenAid 24 in. KUDI01IL - Multiple Color Free-Standing Dishwasher
Items in top shelf do not clean fully.
The glasses and other items placed in the top shelf are not cleaned fully during the normal cleaning cycle. Can this be repaired easily or do I need to contact a service technician?
  • KitchenAid Master
  • 43,501 Answers
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
sytrswgh
Posted on Sep 29, 2010
My dishwasher wont clean on the right side
i had same problem until I learned to place certain items on that side. if I put anything on the bottom that blocks the right side it will not clean. I can only place cups and glasses on the right side. plates on the bottom right side also. now if yours has a top arm and is not cleaning then you might need a tech. but i regret purchasing this machine. i hate doing it this way. maybe yours cleans like mine.
Jan 31, 2015 | Dishwashers
My maytag W10199645 is leaving gritty residue on my mugs & glasses. how can i troubleshoot this?
Try using a dishwasher cleaner. You can get it at any supermarket that sells dishwasher soap.
Nov 06, 2014 | Maytag Dishwashers
Clean glass door
  1. Clean the area as normal to remove any superficial dirt and dust.
  2. Next, apply the chosen cleaner using a sponge or soft cloth.
  3. Allow it set for a few minutes. (if applicable)
  4. Use the hot water to gently scrub the area and remove the cleaner.
  5. Repeat until it is cleaned completely.
  6. Rinse with clean water.
Mercedes wheels
May 31, 2012 | Stoves Kitchen Ranges
Glasses and frying pans not clean at end of cycle. Residue on glasses and cups,food particles on frying pans.
it's generally not a good idea to put really greasy items in a dishwasher along with relatively clean items such as glassware and plates and cutlery, as most recent good quality dishwashers come with a soil sensor that ends the wash cycle once the dishes appear clean, and all the grease from your frying pan will cause the soil sensor to take longer to detect clean water.
Jun 29, 2011 | Dishwashers
An error F34 how can i solve this problem
Hi and welcome to FixYa, I am Kelly
Somehow you selected a clean cycle.
http://maytag.custhelp.com/app/answers/detail/a_id/2892/~/display-shows-rl-or-f34---front-load-washer
This error code indicates that items were detected in the washer during the Clean Washer cycle.
The Clean Washer cycle is used to keep the washer fresh and clean. Do not place garments or other items in the washer during the Clean Washer cycle. Use this cycle with an empty washer basket.
If you have a Maytag.... (no model number given so I chose one)
See the Use and Care Guide for details; find it by entering your model number in the search tool below.
Remove the items from the washer.
To remove the error display, press Pause/Off or Pause/Cancel or Power once.
Thanks for choosing FixYa,
Kelly
Mar 21, 2011 | Washing Machines
Why doesn't clothes dry during normal dryer settings? Its suppose to be extra large capacity but only 10 items can dry fully during one dryer cycle at more dry setting.
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Oct 14, 2010 | General Electric DBXR463GGCC Gas Dryer
I have a built in Electrolux ESL624 in the house I've just moved in to. I have noticed that items placed on the top shelf like glasses and cups are not always cleaning properly. Black deposits are being...
Check the spray arms are not clogged as well as the top one take off the bottom one clear a hole underneath the arm. make sure the arms can turn freely. dishwasher fresheners hanging on the basket can stop the arm turning. clean the filter in the bottom. Is the machine heating it should be hot at the prog end.
Aug 04, 2010 | Electrolux 23 in. ESL624 Built-in...
Items on top shelf are not getting clean whereas bottom shelf dishes are clean
I had this problem, and on mine it was because when I pushed the top shelf in , the little sleeve for the spinning nozzle wasn't fitting over the coupling that supplies water to it. Try checking the alignment when you push in the top shelf.
Hope this Helps,
RSMITH972278
P.S. PLEASE RATE ME
Oct 19, 2009 | Dishwashers
My dishwasher will not clean on the top shelf
cheap trick...take a glass and put it on the top rack...right side up run dishwasher for about 4 mins is the glass full with water,no ok than check your drain hose the water is sphion out during wash,,lift it the height of unit..keep me posted
Oct 09, 2009 | Dishwashers
Top shelf items dirtier after cleaning
After some experience with our own fdw60 with the same problem, we now put all pots and pans on the top rack. Putting them on the bottm appears to stop the clean water rinse reaching the top rack. All washes since have been ok.
Sep 23, 2008 | Hotpoint 24 in. FDW60 Free-standing...
KitchenAid 24 in. KUDI01IL - Multiple Color Free-Standing Dishwasher Logo
116 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
