Question about Garden
My Powerex Model CS5106H air compressor is spraying oil out the air intake. I assume this means the rings are probably bad. The unit is probably 15 years old. Can you direct me to instructions on how to replace the rings? Or would it be better to replace the compressor with an equivalent Ingersoll Rand which is what my other compressors are. I am wondering if a new IR would fit on the same base.
  • 553 Answers
I don't know the size of your compressor but I'm assuming it's fair sized since it's not oil less. To change the rings would require dismantling the whole compressor. As old as your compress is you'll most likely need to have the cylinder bored or sleeved. You would need to have a few special tools as well; ridge reamer, ring compressor, fly wheel puller, torque wrench plus maybe a few others that I missed. You should rebuild the whole compressor assembly if you decide to repair the compressor.You may be able to get part at: www.powerex.com or a local industrial tool supply.
I can't tell you if rebuilding or replacing is the best option for you but if it's going to cost you more than 75% of new to rebuild then your probably better off replacing the compressor. I don't know if an IR would fit but if you measure the mounting you should be able find out at: www.ingersollrandproducts.com You should measure diagonally as well.
Posted on Jul 06, 2010
  • jonesspammai Jul 14, 2010
    If you found my solution helpful please rate it or it could be awarded to someone else, Thank you
    jonesspammai
  • 8,197 Answers
Sorry there is no parts available for the compressor.
I would recommend replacing the compressor with a new one. As for it fitting on the base that I could not tell you.
Good Luck
Posted on Jul 05, 2010
My compressor is not buildngup air pessure
Most compressors that come into the shop are not reaching cut off pressure. Here are a few tips on determining the problem /s. Three problem areas. Leaks,valves/head gaskets or worn cylinder/rings. Leaks on small compressors are easy to find by spraying soapy water on all connections and drain valves. Also spray on head gaskets. Repair as needed. No joy? Continue with checking valves. Most small compressors have reeds for valves and fail quite easily. There should be good suction at intake opening. Run compressor till no more gain in pressure. With air filter removed and pump running feel for suction at intake. If you feel very little suction or air blowing out of intake , most likely bad reeds or gaskets. If you feel good suction however no gain in pressure then likely worn cylinder. Good luck with repair.
Feb 03, 2017 | Air Tools & Compressors
I have a craftsman air compressor model number 921.153101 that won't pump-up over 40 pounds
Its probably a oil less compressor so it could be the reed valves are bad or the piston rings are bad.
Feb 01, 2014 | Craftsman Air Tools & Compressors
I need a new piston ring for a 6 HP Porter Cable air complrssor. It is made of some sort of fiber or perhaps teflon like material. I made a leather one but it just did not last very long. the model...
The part number is DAC-308 and you can order the part from www.msservice.net or you can also try www.allpartsinc.com
You wont need new o-rings for the head just put a little grease on the o-rings and install them again.
Nov 06, 2010 | Porter Cable Cable 135 PSI, 15 Gal. Oil -...
I have the pro source air compressor, 10 gallon, 2 HP brand new. It will not build up any pressure what so ever! Tried everything... found no leaks, sprayed it down with soap and water.. but in the top...
First if it's brand new I'd take it back to where you bought it. They have to sell you a product that works and anything you do to it will either void their responsibility or the company warranty. That said; if you have no leaks and assuming the hole you're talking about is the input side for the air filter and not the output side of the pump that should have a tube running into the tank stand pipe, it sounds like you may have one or more broken reed valves or bad ring(s) on the piston. Oil-less air pumps have one ring or wiper that does fail, oil-splash pumps have pistons like small engines with compression rings and an oil wiper. If they are run without oil the damage can be catastrophic. Not hard to fix but if you break the paint on the head bolts you void any warranty you have on the unit.
Nov 03, 2010 | Coleman Proforce 6 Gallon Air Compressor
My compressor hose is running extremely hot...any reason why and do i have anything to worry about
Assuming that it's used in an open-air spot so that the intake air is cool, hot compressed air means the head is running hot.
Most small-to-mid sized compressors run warm after a few minutes, and some run fairly hot after 10 minutes.
If the hose is too hot to hold after 20 minutes, the first suspect is friction within the compressor's head.
This could be caused by poor circulation due to a low-quality oil.
It could also mean a blockage in the air-delivery system (ie: oil-dust gunk at a fitting causing restriction, making the motor work harder than normal.
Flush the oil reservoir, pull the feed lines one-at-a-time and flush out. Pull the intake filter and blow out the head & valves.
Refill the reservoir with Craftsman compressor oil.
Sep 08, 2010 | Porter Cable C2002 150 Psi 6 Gal...
Portable Compressor Model # P175 WD runs fine builds air pressure but when turned off it belches pump oil out air intake.
your ring on the piston or your cylinder is scored. you'll need to have or do it your self and have the cylender hone and new rings installed. check to make sure your cylinder is not to Far damaged. good luck
Oct 15, 2009 | Ingersoll Air Tools & Compressors
I have a 3hp 15gal air compressor that i bought used, when i plug it in it seems to run just fine but it don't seem to build air pressure, it stops building around 15lbs but the compressor keeps running...
I am assuming that your compressor is oilfree type. Lets go over some basics to determine where fault is located. You will need to do some simple tests. If there are leaks the compressor may not reach set pressure. I use soapy water on all connections and on the head/headvalve (remove plastic covers to get to all parts that may leak) while compressor is running. Make repairs as necessary. If still low pressure, while compressor is running and has reached max obtainable pressure (in your case 15 lbs), carefully place finger over intake port hole (remove filter). If the compressor is pumping normally but leaking there will be ample suction at intake and cause the compressor to speed-up when intake is obstructed with finger. If you feel plenty of suction and no visible (soapy water) leaks, then the problem is probably the cylinder /ring is not correctly seating /scratched and air is leaking past cylinder. Make sure that the cylinder /piston ring is properly aligned and that the lip on the vinyl ring is up toward the head. On oilfree compressors you can examine the cylinder by pushing the piston all the way up, then look for scratches neer top of cylinder. If scratched install cylinder kit. If you do not feel suction but rather air blowing out of the intake, then the problem is the headvalve plate/reed valves are leaking. The reeds must seal perfectly on their seats and not be bent or have obstruction. Replace as necessary. Only one other thing to check and that is the intank check valve. Easy to check. Run compressor till you have about 15 + lbs in the tank then unplug compressor. Carefully loosen the inlet hose at checkvalve and listen for air leaking out of tank. If leaking replace checkvalve. Use caution when removing head to try and save the gaskets. If you see any model numbers on your compressor beginning with WL, you probably have a unit built by Campbell Hausfeld and can find parts at www.chpower.com
Good luck on your repair and email if you have other question.
May 09, 2009 | Craftsman Air Tools & Compressors
Air compressor/ alot of air is coming out of the oil cap vent.
this could be blow back possibly bad piston rings you may need new rings oil chamber is usually at intake pressure unit may need rebuild
Jan 13, 2009 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
WILL NOT BUILD PRESSURE
Many craftsman compressor are built by champbell hausfeld using a dry type of cylinder and piston (no oil, no crankcase). If dry type, check for worn cylinder and piston ring. Pieces of the vinyl ring can jamb between the reed valves in the head causing air to escape from the intake. If your compressor has a crankcase and oil, check for broken reed valves in head. Spray soap solution on hoses, checkvalve, drainvalve, and fittings to check for leaks. Most likely problem is reed valves broken or open. Parts are available from sears or match parts to chpower.com. enjoy
Nov 26, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Garden Logo
129 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
