Question about Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM, 60 PSI, 12 Volt
I have a 15 gallon Fimco trailer sprayer. Last
I have a 15 gallon Fimco trailer sprayer. Last year I used bleach/water in it to clean my vinly siding 2 story house. I left a small amount of bleach/water inside last fall. Now, I can't get it to turn on. I bought a new switch today. I still can't get it on. What else can I try? Thanks!
Carole
    Novelist:
  • 146 Answers
Bleach gives off corrosive vapors, so the internal parts of the pump may have corroded over time. Least expensive fix is to disassemble the pump, find and replace any corroded parts, but you'll be tinkering for a day and it may not be repairable anyway. More expensive but faster is to replace the pump - check the GPM rating and find it here for about $60 - $100. Good luck!
Posted on Jul 06, 2010
Sprayer looses pressure pump issue ?
You can take the intake part of the pump apart and clean/lube the diaphragm of the pump. If you didn't clean it out last time it was used there will be residual or cake built up. Make sure the down snorkel is clear and doesn't have any contamination in the tube. Check the screen/filter also.
Jul 03, 2014 | Fimco 25 Gallon Trailer Sprayer with a 12...
Pump sprayer has no suction
We have the exact same sprayer 2.1 GPM for our FIMCO and the engine runs but it will not suction. This happened once before last year and because it was under warranty they replaced it. Now it is happening again but FIMCO will not stand by this part because they don't "Warranty their warrenties.". What a bunch of ****! Stand by your products for pete's sake!!! If anyone has any solutions or ideas it would help us out a lot!
Apr 14, 2012 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Not much pressure on fimco 15 gallon sprayer - purchased new 2.1 gpm motor - it sprays but not a lot comes out - seems not much pressure - Thanks.
Is it possible that the pick-up tube inside the sprayer is clogged up, or the hose it damaged? Maybe dirt in the spray handle/wand?
Oct 26, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Fimco 15 gal Sprayer, 12 volt, No power
cross the wires on the pressure switch, if it runs then, replace that switch is all!
Jul 02, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Pump has no pressure
scrub up the check valve within the pump really well, that should help restore the prime! use dish soap and a toothbrush!
Jun 30, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
I also have a FIMCO 15 gallon 12 v spot sprayer, won't prime
I use an emulsifier with Round-up to make it stick better to the weeds (Sticky Spreader). The emulsifier had made the solution less viscous and was not moving through the wire mesh filter that comes out of the bottom of the tank. I removed the filter and it works fine. I have a filter in the handle anyway so there is no need for two filters for my application.
Jun 05, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
LAWN SPRAYER PUMP WILL NOT SUCTION
Disconnect the sprayer boom hose from Y splitter, and dd another Y splitter, then reconnect the boom hose to one side of the added splitter. Add a washing machine supply (female/female) to the other side of new Y. now attach garden hose to washing machine line and turn on the water faucet with pump running. This will charge and/or backwash the pump. Once pressure is achieved, turn on the boom and check for fluid movement, then turn the washer supply valve on Y to off, and disconnect. The pump should be primed and be cycling fluid from tank and back to tank. Ready to shift to boom for use. I leave the washer hose and assembly zip-tied onto sprayer for easy future priming, and pump wash between uses.
May 02, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
I have a fimco pump on a 25 gallon sprayer. It is a 2.1 gallon per min. pump. I took it out yesterday to use and it would not pump up, no pressure. Worked fine last year. I checked and the motor is...
open up the pump, take out the check valve. wash in dish soap/hot water solution, scrub with old toothbrush, rinse off, reinstall & see if that makes a difference...
Apr 29, 2009 | Fimco Spot Sprayer, 25 Gallon, 3.8 GPM, 45...
Fimco Sprayer , 25 gallon, 2.1 gpm, 12 Volts - Blowing fuses
Soiunds like you either have one of two things. Either the pump motor is bad or you have a wire that is shorted out. look for chaffed or bare wires or burnt spots on the sprayer and the machine towing it. one of the two is your issue. Hope this helps!
Sep 19, 2008 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM, 60 PSI, 12 Volt Logo
954 people viewed this question
Top Fimco Garden Experts
lnbn1975
Jay Finke
Jay Finke
ray gallant
Are you a Fimco Garden Expert? Answer questions, earn points and help others
