Question about HP PSC 1210 All-In-One InkJet Printer
Error light stays on won't print. ink catridge only one month old
    Scholar:
  • 102 Answers
You haven't given enough of a description. However, I can tell you that HP has a list on their site of what exactly the error lights mean. You can do a search for it on HP's website.
Posted on Jul 05, 2010
My black ink button on my pixma mp495 printer is blinking. Why?
A B LED light denotes that the black ink cartridge is running low.
A C LED light denotes that the colour ink cartridge is running low.
If the alarm light is on (lightning bolt in a triangle) it should be accompanied by an error code.
Canon MP495 - Error Codes If the printer displays an error message, the following information should help to diagnose the problem.
The led screen on the printer will flash a letter E and will then be followed by two numbers:
Error Description More Info Error E02 The machine is out of paper or will not feed. Error E03 Paper jam or output tray is closed. More Info Error E04 The Cartridge cannot be recognised. More Info Error E05 The Cartridge cannot be recognised. More Info Error E07 Cartridge is not installed in the correct position. More Info Error E08 Ink absorber is almost full. More Info Error E13 The remaining ink level cannot be detected. More Info Error E14 The Cartridge cannot be recognised. More Info Error E15 The Cartridge cannot be recognised. More Info Error E16 The ink has run out. More Info Error P02 Carriage encoder error. More Info Error P03 Line feed error. More Info Error P07 The waste ink absorber is full. More Info Error P08 Print head fault. More Info Error P10 Print head fault. More Info Error 5100 Carriage Encoder error. More Info Error 5200 Print head fault. More Info Error 6000 Line feed error. More Info Error B200 Print head fault. More Info Error 5B00 The waste ink absorber is full.
Feb 24, 2015 | Canon PIXMA MP495 InkJet Printer
We have HP3210 all-in-one printer. It went unused for two months and during this time, I knew the black cartridge was out, so I finally bought one. Now - it doesn't print anything but a very light...
Cartrideges might be dried up.. how ever you have to replace the catridges... Try try do this tip..Take cup of little bit warm water(not too hot).. Dip catridge nozzles(take care water should not touch the contacts) up to one minute, shake the catridge, place on tissue paper verify weather ink spreading in tissue? repeat this process twice clean the cartride, place in printer then try... ensure that it's only tip...
Sep 12, 2011 | HP Photosmart 3210 Printer
I keep getting a error code 1203 what does that mean
Hello
It means your catridges overflow even from brand new catridges after several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge
use a klennex with a few drops of water to dampen and clean off those contact on the holder and your printer should work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned catridges a couple times then run clean catridges a couple times.
Print the test page to see how it looks .
Be sure not to leave any debris of klennex on those holder contact panel.
Jun 10, 2011 | Dell 926 All-In-One InkJet Printer
I cant print and get error message 1203 on my lexmark p315 model:any idea wat that error message is?
t's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge. I have the same problem which I think lexmark have a proble and overlook.
Solution:
I use the klennex with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Print the test page to see how it's look and way you go.
Too bad that I also cound not find out how to reset the ink indicator. It's annoying to hit the OK button every time you want to print.
Try and see if it's work for you. Good luck......
Dec 22, 2010 | Office Equipment & Supplies
The answer to my error 5100 question was replace pinhead and clean. where is the "pinhead"??
You need to open the top cover, access the ink catridge case(Where catridges hung), then look for other objects that look like ink catridges but smaller, that's where the catridges feed ink (into the print heads) usually separate by colors cyan, magenta and yellow Usually Black is a lone. Replace the print Heads and clean where the dirty ink drops.
Dec 03, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Red light stays on and printer won't print
My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
Jan 16, 2010 | Epson Stylus C60 InkJet Printer
Error 1203.
It's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge. I have the same problem which I think lexmark have a proble and overlook.
Solution:
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 5 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
regards
iversh
A very helpful rating is appreciated for answering your query...
Aug 22, 2009 | Dell 924 All-in-One InkJet Printer
Error 1203 how do I fix it?
try this solution:
Solution:
Jun 10, 2009 | Lexmark X4250 All-In-One InkJet Printer
All lights stay lit when try to print. All the lights along with both ink lights. Have to press the paper feed button, it will shoot out a blank page then print the document. This is becoming very...
hi you can easily solve this problem
the printer lights are blinking it is a catridge problem
please use orginal priter Hp catridge or use any other catridge.
i hope you will solve ur problem
May 13, 2009 | HP DeskJet 9800 InkJet Printer
Printer will not start after changing ink cart.
u better remove both catridges ,switch on the printer ,after that the print catridges lights will blink ,open the cover the catridge holder will come at the centre,put the catidges n perform the catridge alignement,n complete it
Dec 19, 2007 | HP Photosmart C3180 All-In-One InkJet...
HP PSC 1210 All-In-One InkJet Printer Logo
156 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
