Frigidaire Washer HELP
I have a Frigidaire washer,front load Model FTF2140ES0 Serial #XC52410387 .. iT WILL START TO FILL THEN STOP,THIS GOES ON FOR 4/5 TIMES AND NOTHING ELSE HAPPENS. i HAVE REPLACED THE CONTROL BOARD,DIDNT HELP AND i CHECKED THE WATER VALVE ITS OK, wHAT AM i MISSING
Thanks Marvin
  • Anonymous Apr 19, 2008
    I have a Frigidaire FTF2140ES - front load 2 years old. Worked great until past 2 months. Mid-cycle (no rhyme or reason) all sensor lights flash and beep beep beep. I can sometimes rearrange clothes to get it to move on, but often times need to reset 4-5 times to get thru an entire cycle.
  • 975 Answers
Check for a sensor switch located underneath the door , its a safety device to ensure that door is tightly closed . hope it helps
Posted on Apr 18, 2008
I have a Frigidaire front load washer model number Ftf2140es0 it will not fill with water. You can hear it click like its trying to fill but there's no water coming in
Here is checklist.
Start with the faucet that supplies the water to the machine.
It is flowing freely?
You will need to detach the washer hose to check that (and put a garden hose to the outside).
If the water is flowing freely from the faucet, then detach the hose to the washer and carefully inspect the filter screen inside the coupling on the back of the washer. The tiny (about 1/2 inch diameter) screen may be plugged up.
If the faucet, hose, and filter screen are good, the water flow solenoid could be defective.
That is the plastic piece where the 2 hoses attach from the outside. It has a wire connector as well.
God bless your efforts.
Oct 12, 2015 | Frigidaire Washing Machines
Frigidaire FTF2140ES0 Front Load Washer lock indicator light goes off, but will not spin.
Sounds like the electronic locking mechanism is malfunctioning. It is supposed to enguage before the high spin cycle. It is about a $20 part.
Sep 20, 2011 | Frigidaire GLTF2940ES Front Load Washer
I have a mo# FTF2140ES0 front loader washer that won't spin
check the pump for a blockage,if the water cantget out of the wash tub,the machine senses this and wont spin out the load,also make sure to check both sides of the pump from the tub to pump and pump to house drain sides
Mar 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
My frigidaire washer FTF2140ES0 won't spin on the spin cycle
Hi there, the same thing is happening with our washer. Did you find a solution to the problem? We found a coin the the black tube, but it still doesn't do the final spin. I can hear the motor trying to do something, but it just won't do the final spin. If anyone has any idea or suggestions it would be greatly appreciated. In the meantime, I have a load of slopping wet laundry to deal with. :(
Jan 04, 2010 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
FTF2140ES0 Bellows Kit replacement
remove and install a new bellows kit for a Fridgidaire front-loading washer model ftf2140es0
Nov 09, 2009 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
Does the model FTF2140ES0 washer has a water filter
Yes , it is situated just inside the fitting on the back panel where you attach the fill hose from the mains
Jul 29, 2009 | Maytag EPIC MFW9700S Front Load Washer
Need a restart code
Press & hold down the 'options' & 'select' buttons for over 3 seconds. And let me know. These are the buttons, but how long?
Mar 19, 2009 | Frigidaire Affinity ATF7000E Front Load...
Washer not spinning
You're problem is probably the door latch assembly. This is a common problem on Frigidaire front load washers. You can find the part at your local appliance parts suppliers. If the door latch assembly is faulty, the washer will run through all of its normal cycles, but will not spin. Hope this fixes the problem for you.
Jan 01, 2009 | Frigidaire ATF6000ES Front Load Washer
Fridgidaire FTF2140ES0 Front Load Washing Machine Vibration
Try going to GVIINC.net - there product definately works.
Nov 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
Washing Machines Logo
228 people viewed this question
Top Washing Machines Experts
