Question about Goldstar KG6000R Window Air Conditioner
Where is the drain plug on this unit goldstar 6500 airconditione
I have a gwh 6500r goldstar air conditioner. I have lost the manual. I need to know how the airconditioner drains the water. I can't find a drain plug on the unit
  • 6,927 Answers
There is no drain plug,if it is not draining,then the drain holes are stopped up with trash and debris,remove the unit from the window,and take it out side,use a water hose to clean it out,and you will be fine,if this was at all helpful,please rate,thank you.
Posted on Jul 05, 2010
Does goldstar still make parts for the GoldStar R5000 particularly the fans
It depends on which parts you're looking for. Some are interchangeable from other Goldstar units.
Here is a link to where you can probably find what you need..
http://www.appliancefactoryparts.com/airconditioners/goldstar/
Hope this helps you & thanks for choosing FixYa.
Aug 19, 2011 | Goldstar Heating & Cooling
I need another remote, I've lost mine
Hello, here Is a link for parts to your AC. http://www.appliancefactoryparts.com/airconditioners/goldstar/m1003r.html
Jul 12, 2011 | Goldstar M1003R Air Conditioner
NEED A KNOG FOR GOLDSTAR AC PART # 4949AR7281 ABS DO YOU SELL THESE?
Hello, here is a limk for parts for you ac http://www.appliancefactoryparts.com/airconditioners/goldstar/wg5000.html#Knobs
Jun 08, 2011 | Goldstar WG5000 Air Conditioner
Water got into the plug. Unscrewed, drained as much as I could and set down on paper towels for a few days. Plugged back in & worked. Moved the cord while plugged in & the ac blew out and will...
Hello, most likly you will have to replace the whole cord assembly, here is a link to parts for you AC http://www.appliancefactoryparts.com/airconditioners/goldstar/m1003r.html
Jun 08, 2011 | Goldstar M1003R Air Conditioner
I've had my unit for about 3 years and it does not get cold enought . what cani do to fix my problem
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Apr 01, 2011 | Goldstar KG6000R Window Air Conditioner
Unit overheating and blowing fuses
Low gas pressur causing the unit to overwork/heat, water trap coolant service port blocked. Some machines need 1/2 liter of water pouerd into a reservoir on the rear to aid cooling the heat exchanger, if this is dry it will overheat. cheakc the filters if it has any.
Jul 28, 2009 | Goldstar GW-HD5000 Window Air Conditioner
I have a Goldstar model-GP120CE and it has stoped working and P2 appears on the display. I know the collection tank is full and im supposed to drain it but what and where is the collection tank??
There is two drain plugs on the back of the unit, you will need to drain the the bottom black plug, you need something to catch the water. hope this helps
Jul 11, 2009 | Goldstar Heating & Cooling
Goldstar KG6000R Window Air Conditioner Logo
597 people viewed this question
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Dan Webster
Dan Webster
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
