Question about Canon PowerShot SD960 IS Digital Camera
I dropped my camera and it now says lens error restart camera when I try to turn it on, how do I restart my camera? I have a canon powershot SD960 IS.
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jul 06, 2010
I've dropped my Canon Power Shot SD960 IS with the lens out, and now the outer lens is tilted at an angle and wedged tight and the barrel of the zoom will not retract. I've tried turning it off and on,...
Try this first, power off and gently push the lens barrel sideways - not back in!, If the barrel and the lens move slightly, you will get it working after some more manipulation in the same way. If it does not budge, sorry to mention this but your camera sustained more damage and you cannot do do much on your own.
Aug 14, 2013 | Canon PowerShot SD960 IS Digital Camera
Camera will not "close"
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 17, 2011 | Canon PowerShot SD960 IS Digital Camera
How do I reset. I have pressed a button and I now have a grid, which I dont want. I only use the tulip sign and the x1 Help. Many thanks.
Issue: How do I reset the camera to its default settings?
Solution: Procedure for resetting the camera to its default settings PowerShot SD960 IS.
Resetting Settings to Their Default Values - PowerShot SD960 IS. 1. Turn on the camera and press the <MENU> button to open the menu. 2. Using the arrowrightbutton.gifbutton, highlight the yellow setup_icon.gif(Set up) tab. sd960menupress.jpg 3. Using the arrowdownbutton.gifbutton, select [Reset All..] and press funcseticon.gif. sd970reset.jpg 4. Select [OK] and press funcseticon.gif. sd970resetall.jpg
  • Settings cannot be reset when the camera is connected to a computer or to a printer.
  • The following cannot be reset:
    • Shooting mode
    • The [Date/Time], [Language], [Video System], and [Time Zone] options in the setup_icon.gif(Set up) menu
    • White balance data recorded with the custom white balance function
    • Colors specified in the [Color Accent] or [Color Swap] modes of My Colors
    • The image registered as [Start-up Image]
Aug 02, 2010 | Canon IXUS 960 IS Digital Camera
Lens error. Restart camera.
this is very common has the camera been near the ocean??? it does not have to be dropped to give you this error. repair on you lens runs 85.00 for repair. or a new lens for 125.00
Jun 25, 2009 | Canon PowerShot SD1100 IS Digital Camera
Lens error restart camera
same thing just happened to me today. the little girl that I babysit dropped it about 1 foot to the rug on the ground, not a hard drop at all. so i tried taking out the batteries and hit it on the table (read on other sites) then i gently turned the end of the lens (my lens was stuck out) counter clock wise and it clicked and then worked.
Apr 20, 2009 | Canon PowerShot SD1100 IS Digital Camera
"Lens Error, Restart Camera" Lens stuck open, completely disfunctional! /sadface :(
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 17, 2009 | Canon PowerShot A630 Digital Camera
Canon PowerShot SD600 Digital Camera
Manually rotating sensor rotor inside camera and cleaning gear fixed the Canon "lens error" for me.
I placed instructions with photo's here: http://www.avh.dds.nl/Fix-Canon-SD600-Lens-Error/
Nov 03, 2007 | Canon PowerShot SD600 Digital Camera
Canon powershot sd900
I have the same problem, but i didnt drop mind. The lens where out when i put on da pack and now it won't start.
Apr 09, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Canon PowerShot SD960 IS Digital Camera Logo
1,143 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
