Question about Frigidaire ATF6000ES Front Load Washer
I have a frigidair energy star front load washer model GLTF2940E. It was given to me as a gift but I didnt get the manual. I keep getting the error code E70 and it will not complete the wash cycle. What does the error code mean and how do I fix it.
  • 1,531 Answers
If it stops in towards the end of the cycle or around the the rinse cycle then you need to replace the door lock mechanism
Posted on Jul 05, 2010
How to replace frigidaire gallery washer knob?
Good afternoon friend, that's a great question!
I understand that you are trying to replace the selector knob on your Frigidaire washer, GLTF2940E. Normally this is not a DIY job and we would recommend having a technician come out to the home in order to properly disassemble your front panel and replace the selector knob as needed. Hope this is helpful. -Matt
Jul 29, 2014 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
I can't get my front loading washer to reset
How are you trying to reset the unit, and why? Did you see any error code? You can unplug the unit or simply turn the circuit breaker off for 3-5 minutes. This should do the trick, unless there is another root problem.
Dec 22, 2012 | Frigidaire FTF2140E King-Size ENERGY STAR
My frigidaire front load washer Model #GLTF2940E will not spin out
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 30, 2011 | Frigidaire GLTF2940ES Front Load Washer
I have a frigidaire gallery series front loader washer model gltf2940e it keeps giving error e10 what do i do
E10 means that your cold water is coming in too slow, disconnect the cold water hose and check to see if the screen on your washing machine is clogged. If the screen is clean and the hose has good pressure then you will need to replace the water valve on your machine--- this is the piece that the hoses directly connect to.
Sep 15, 2010 | Frigidaire ATF6000ES Front Load Washer
GE Energy Star WCVH6260F Front Load Washer washer wont fill with water and does the error beeping after about a minute and continually says door is locked when it isn't
Sounds like the door sensor has become faulty. Unfortunately this is only a vague symptom,of the actual Root cause Are there any other error codes?.
Mar 14, 2010 | GE Energy Star WCVH6260F Front Load Washer
Door will not unlock, cycle did not finish.
Unplug the power cord let it reset..It should unlock
May 21, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Dryer wont stop. Keeps spinning and heating
repairclinic.com is a great site to buy parts from.
May 16, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
E10 error code
1 beep and E10 is listed as the dispenser door is open. Try reclosing your soap dispenser door tight.
Jan 18, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
No spin cycle
Yes, it is the door latch assembly. replace this and you should be good to go. You can get it from an appliance parts supplier.
Dec 20, 2008 | Frigidaire GLTF2940E Front Load Washer
Frigidaire front load washer displays E20 what does that mean?
E59 code means you need a new circuit board and Frigidaire knows it's a problem, but will only step up to repair if you demand it. we're on our second circuit board in 2 years!
Aug 09, 2007 | Frigidaire GLTF2940E Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
175 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
