Question about Bosch SHU9915UC Dishwasher
My Bosh DLX dishwasher frequently leaves the dishes cloudy. This happens periodically. We have checked to make sure there are no food particles in the resevoir on the bottom. Sometimes after we've cleared out the resevoir/ filters on the bottom, it seems to correct the problem but not this time. Please help. Thanks, Deana
  • dslater285 Jul 13, 2010
    Hi Rylee,
    We have checked everything you said, i.e. water temp is ok, there are no cracks on spray arm and pump cover. We pulled the dishwasher out and all the hoses leading to the sink are fine, dispenser unit and all seems fine. There are no food particles in the resevoir.
    We are still getting cloudy glasses. It's as though the rinse agent is not working properly.
    Can you give more advise please?
    Thanks,
    Deana
  • dslater285 Jul 15, 2010
    Rylee,
    We are
    working properly.
    Thanks,
    Deana
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Check the water temperature inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. This would have happened as the dishwasher was overloaded with more than prescribed number of dishes. Check the spray arm and pump cover for splits or leaks. As the dishwasher is not draining properly, this issue is related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 05, 2010
Food remnants left on top rack of glasses and ceramic mugs.
Before loading into the machine clean the particles that are sticking to the dishes.
Check the drain filter at the bottom rack and clean. It is user cleanable
Apr 06, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishes are not getting clean, leaves food particles
may be problem in final rinse not happening.
1)check the final rinse happening at end of the cycle
2)if not happens clean the solenoid filter.
3)clean the boiler tank.
Jan 06, 2010 | Bosch Integra 800 SHX98M05UC Built-in...
Dishwasher leaves food particles on dishes
You are not getting enough water in the machine. The inlet valve is probably plugged with sand or something of the sort. You will need to replace the inlet valve.
Jan 02, 2010 | GE Dishwashers
I have a adb2200awb amana dishwasher which leaving glasses with a cloudy plus grid stuff on the glass and on the dishes. i use jet dry stuff plus the talbets with jet dry in them also i put them on a 2hr...
This is a classic sign of too much detergent. Are you only using one tablet? Too low of a washing temperature could also be your culprit. Dishwasher detergent needs to be washed with at least 120 degree water. Check to make sure your supply is hot (if it's plumbed to intersect with your faucet, just check faucet hot water supply temp). I'm not sure why you're running it on a two hour cycle, dishwashers can generally do the job in about 40 minutes. The grit is probably because there are food particles in your food trap. Make sure the food filter beneath the spray arm (if equipped) is clean and check the lowest areas for food scraps.
Jul 08, 2009 | Amana 24 in. ADB2200AW Built-In Dishwasher
Kenmore elite dishwasher leaves food particles on dishes
If someone is putting dishes in the washer and obstructing the spray ams that would cause food to stay on dishes. After loading dishwasher and pushing in baskets make sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
May 12, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Dwc7400aaw maytag -glass are cloudy,groundup food particles drying to dishes & glasses,when filling makes loud high pitched sound-generally not cleaning well.
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Apr 06, 2009 | Maytag MDB9600A Jetclean II Built-in...
Cloudy glasses and dirty dishes
There are no filters in the dishwasher. However, you may have filters under your sink or near your hot water tank for whole house filtering.
Mar 11, 2009 | Maytag 24 in. DWD1500A Built-in Dishwasher
Dishwasher is leaving food particles everywhere
Clean the filter screen at the bottom of the washer basin.
Apr 14, 2017 | Dishwashers
Bosch SHU9915UC Dishwasher Logo
61 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
