Question about Kenmore Vacuums
My vacuum (Kenmore model 16.25512506)won't start. It sparked/shorted out at the 180 deg swivel. Is there an electrical reset button??
5 Suggested Answers
  • 1462 Answers
SOURCE: kenmore canister vacuum #116 5521290
im not familiar with kenwood vacs (i'm in uk not us) but usual cause of this type of fault is a fracture in the power cord where it enters the appliance or at the cable clamp. cut 6ins of the power cord and remake the connection
Posted on Sep 02, 2008
SOURCE: Assemble Swivel Assembly onto Kenmore Canister vac
Got this post off this web site...I just replaced my swivel and it worked:
http://www.managemyhome.com/mmh/answers/Answers.action#l4q110567
To install a new swivel assembly, you will need 2 small, flat tip screw drivers. Unplug the vacuum. Push the screw drivers in between the hose and the collar where you see the seams in the plastic collar on the end where the hose enters the collar. This will release tabs that hold the collar to the swivel. Pry and pull the collar back over the hose and then pull the small screwdrivers out of the collar. Slide the collar back along the hose. Unplug the wiring connections from the hose. Pull the hose wires up and out of the holder on the swivel assembly. Lift the tabs on the side of the hose and pull it off of the swivel. Push the new swivel onto the hose. Align the hose wires and secure them in the holder. Plug the wires from the swivel into the hose wires (blue to blue, white to white). Secure the swivel wires into the wire holder on the swivel assembly. Push the collar back up the hose and onto the swivel with the plastic seams aligned with the tabs on each side of the hose. Snap the collar securely into place.
Posted on Dec 10, 2008
ltldab
  • 152 Answers
SOURCE: the vacuum is a Kenmore Whispertone model 116
CHECK PARTS SITES AS THERE ARE NUMEROUS ONES ONLINE.
Posted on Feb 26, 2010
  • 823 Answers
SOURCE: kenmore canister vacuum model 116-25512506.
Try to find the reset button. It should be somwhere near the bottom area. It looks like a red dot that you can push inward. If you can press and hold the reset button, it will restart your suction and solve your problem.
Posted on May 12, 2011
Kenmore vacuum just died
Sorry about that . Before you bury it see if there is a reset button you can push to reset it. Most Vacs have reset buttons. Check electrical wires and plugs to make sure they are ok. Is the plug outlet you plug it into working. These are things that you can check. did it die or did you break a belt. Does it try to start but won't.If I could see it it would be easier to know but these are just ideas. Good Luck.
Feb 04, 2017 | Kenmore Vacuums
Beater bar turning on and off. Why doesn't the vacuum?
Try wiggling the wire and where the hose swivels to attempt to determine where it may be shorting out. It could be the wire or the plugs where the wires connect if your model has them. Inspect these areas closely to find your short.
Apr 08, 2016 | Kenmore Vacuums
My 360 swivel vacuum does not start
Reset button? Fuse blown?
Apr 28, 2014 | Vacuums
I have to replace the power head swivel. I have the part. I can't quite figure out how to swap out the broken with new.
I just shot a short video explaining how to replace your swivel neck. I hope this was helpful to you.
Also, here's another repair I wrote showing how to replace the belt, which will help you "crack" the two housings apart on the Kenmore Canisters.
http://www.fixya.com/support/t4499227-need_replace_belt_in_kenmore_vacuum
Jan 06, 2011 | Kenmore 25512/ 25513 Progressive Canister...
Power nozzle shuts on and off
HI There, When a Kenmore power nozzle cuts on and off, this usually indicates that your electrical hose has gone bad and has a short circuit somewhere. You can try and troubleshoot the hose to find out where the short is by trying to determine what position the hose is in when it cuts on and off, and try to isolate the short circuit by spinning the hose on both the end that plugs into the canister, as well as the end that plugs into the wand. Sometimes the short is in the wands, or even the swivel neck assembly on the power nozzle where the wands connect. I would say 9 times out of 10 though on Kenmore canisters, the problem is in the hose. Kenmore is actually manufactured by Panasonic, and the two brands use a lot of the same identical parts, including the electrical hose (most cases). If your Kenmore has a two position switch, with a setting for floors and carpets, then here's a link to the corresponding Panasonic hose that you can buy. The Panasonic hoses are a little more expensive then Kenmore, but the huge benefit is that they come 100% completely assembled, where as the Kenmore hose has to be assembled (which is extremely difficult even for me to do). Panasonic 3 Wire Electrical Suction Hose To Fit Kenmore Canisters On just a handful of Kenmore models, an additional modification has to be done with the internal switch. Kenmore must have had the hose modified so you'd have to buy the genuine Kenmore part, but luckily simply switching two wires on the switch will allow the Panasonic hose to work. Try just plugging in the hose into the vacuum first, and if it still doesn't work properly, then you can modify the switch. If you find that the short is in the wand or swivel neck, just use the comment field on this repair page and let me know, I'll be happy to follow up and walk you through either of these repairs as well. If this was helpful to you, please be so kind and rate the repair, or leave some feedback for me. This is greatly appreciated. Chris Jones GoVacuum.com
Jun 15, 2010 | Kenmore 22612 Bagged Canister Vacuum
Need to find specs to test hose and electrical connections
There are no hose specs. You have continuity or you don't. These are very problematic canisters as they age.
Kenmore canisters are very subject to dirt build up on internal contact rings where they swivel at the elbow adjoining the vac.
They are also prone to intermittent connections at the handle/wand junction and at the wand/power head connection.
Due to the weight of the head there is a lot of strain on those connections.
You never fix half the connection, always both, male and female components in pairs for best results.
Oct 04, 2009 | Vacuums
Vacuum will not turn on
Kenmore Model 116, behind the Vacuum cleaner there is a Motor Reset switch which you need to press.
1. Make sure the Vacuum Cleaner is unplugged.
2. Press the reset button gently in with a pen.
3. Plug back the Vacuum cleaner and it should work.
Jan 31, 2009 | Vacuums
Nov 12, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Vacuums Logo
29 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
