Question about LG Heating & Cooling
LG AC MODEL#LWHD1006RY8 IS NOT GENERATING COOL AIR WHAT SHOULD I DO?ONLY THE FAN IS WORKING
4 Suggested Answers
  • 68 Answers
SOURCE: Goodman AC fan working but not cool air.
0204 built the second week of 2004 sound like you have a loose or burnt wire in the a-c and arcing when the unit comes on. turn the breaker off next time you fix an outlet
Posted on Aug 03, 2009
motor1258
  • 6674 Answers
SOURCE: My Duo-therm Brisk-Air by Dometic rv ac wont cool.(The fan runs )
Usually just listening closely will give you a rough idea where to look for problem. When you have the fan on and switch to cool, (with temperature turned down low obviously) do you hear any type of "moaning" sounds from AC unit, or see lights in RV dim slightly indicating that compressor is trying to engage? Is the breaker tripping when compressor tries to engage? Do you hear a "click" from AC unit when switched to cool? If none of that happens, then I'd start thinking thermostat, or compressor relay. Normally if it's a faulty capacitor, the compressor will try to engage but will make a "moaning sound" and usually trip the breaker due to excess current draw. Someone experience in electrical should be able to test relays etc, but whoever does work on it, should be aware that those capacitors, as well as hydro in general are very dangerous to work with. The ("zap",- Shock) that you can experience from a capacitor or hydro, can be fatal.
Posted on May 30, 2010
  • 8404 Answers
SOURCE: compressor is blowing breaker, fan comes on.
You have a faulty start capacitor. The capicitor helps start the motor ... since it is not doing its job, the motor draws LOTS more power from the line popping the breaker. Have your professional RV service center service your AC.
Thanks for your interest in FixYa.com. Please remember to evaluate this response.
Posted on Jul 05, 2010
Testimonial: "I am a technical Instructor for a major import, so I know my way around HVAC. so glad to have someone who can pin point the problem I found that the motor start fuse on top of the capacitor is melted. it still has some continuity, but looks like your diagnosis will fix it."
My ac fan will not come on when i turn on my ac on my infinty g35 2005 whats the problem
If by AC Fan you mean the blower that forces air out of the vents in the dash, the problem could be a blown fuse, a bad switch, a bad fan motor, or a loose wire.
If you mean that the AC compressor under the hood never kicks in and generates cool air, it is probably low on freon.
Jul 07, 2014 | 1996 Buick Century
Why will my AC not run?
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem Air Conditioning Delray Beach
May 12, 2014 | LG Heating & Cooling
My LG Remote control AKB35551201 STOPPED WORKING
I have lg ac with fan control in remote. Model no. LSA5NF5VFC1.AN48DV1(ll) so i want new remote of my lg ac along fan control.
Jul 31, 2013 | LG Heating & Cooling
LG split unit AC works perfectly for 2 hours and then it stops blowing cool air
Check the amp draw on the condenser fan motor against the rating on the nameplate. motor may be getting weak and shuts down on thermal overload. If the amps are high you have a motor going bad, change it.
Aug 06, 2012 | LG Heating & Cooling
Working but not cooling
Check and make sure its on cooling mode and just not "fan only"
You should be able to hear the compressor start up a few seconds after the fan starts. One easy way to tell if an AC is working on cooling is it should be blowing hot air outside and cold air inside. If not, you may have a gas leak or the compressor is not starting..
Jul 14, 2011 | LG Electronic Window Air Conditioner
Model #LG LWHD1500ER The fan to cool no longer runs on the low speed. It will just humm. On "energy saving mode" the unit does not always turn on to cool. On the "cool mode" when the fan is on high it...
www.appliancefactoryparts.com/content/.../118816.pdf - United States
Above is your service and repair manual, with this you will be able to troubleshoot and repair your Aircon.
I suspect, your thermostat may have a faulty sensor?
factoidz.com/troubleshooting-your-air-conditioning-thermostat/
http://www.inspectapedia.com/heat/Thermostats.htm
Below is a DIY AC, troubleshooting how to. http://www.repairclinic.com/Air-Conditioner-Troubleshooting
Jun 26, 2010 | LG LWHD1500ER Wall/Window Air Conditioner
My LG 7000 BTU Heat / Cool Window Air Conditioner does not cool and the fan speed F1 will not work. Fan runs on F2. The heat works fine. Any suggestions?
You have a control board issue. You can get a new control board by Google searching the make and the model of the unit. There are several sites that sell them
May 24, 2010 | LG Heat cool Window Air Conditioner
Heating & Cooling Logo
93 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
