Question about Whirlpool LGR7646E Dryer
My whirlpool gas dryer is no longer heating. Could it be a fuse? Or more likely an elelment?
  • 1,531 Answers
Gas dryer does not have an element
it could be the one of the thermal fuses that has gone bad as well as the ignitor. if the ignitor is not pulling enough current it will not open the gas valve in order to light the gas.
Posted on Jul 05, 2010
Gas Dryer no longer putting out heat.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 14, 2010 | Whirlpool GEQ9858J Dryer
Whirlpool lgr7648pq0 gas dryer no longer heating; just blowing air; no exhaust issues;
More than likely you have a burned up heating element. There is a remote possibility that you have a blown circuit breaker or fuse in your house. The blower is wired for and only requires 120 volts but the heater element requires 220 volt service. Usually there are two circuit breakers in your house breaker or fuse panel that provide power for the dryer. One of them may be tripped/blown and the other one may be ok..still on...and providing power to the blower. So...check to make sure there is not a blown fuse or circuit breaker tripped. This is the easy solution if it applies but probably the heating element is bad and will need replacing.
Sep 01, 2009 | Whirlpool LGR5636L Gas Dryer
Gas Dryer won't produce heat
Hi, thanks for the inquiry.
It's most likely a thermal fuse. Basically, the voltage has to go through the fuse before it goes to the ignitor.
It should only cost you about $90 to repair if a technician comes out to fix a fuse.
I wouldn't try to repair it unless you have some knowledge of electrics. If your dryer is less than 12 years old, I would recommend you fix it. Hope this helps.
Best of luck :)
Aug 25, 2009 | Whirlpool Dryers
My gas whirlpool dryer won't heat. Cool air does
Hi
Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 06, 2009 | Whirlpool Dryers
Whirlpool gas dryer. Only few min.( less than 5min) heat work.
there is a thermal fuse inside the dryer it is a one time fuse also there is an ignitor that could be bad
Jul 03, 2009 | Whirlpool WGD5300S Dryer
I have a lgr5636 that is no longer blowing hot air. is there some type of fuse that needs to be replaced or is it the valve
may be your fuse or could also be your heating element..need to apply a test light to fuse [once removed] before replacinbg heating element
Jun 17, 2009 | Whirlpool LGV4634JQ Gas Dryer
Gas Dryer quit heating today
Just click below;
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Hope it may help you;
Regards;
VOTIT
Jan 28, 2009 | Whirlpool LGR8648 Gas Dryer
Whirlpool gas dryer will not heat up?
How do I take apart a kenmore gas front load dryer, to get to the fuses, heating element etc. Model # 417.91042000. Please Help... Thank-you
Nov 10, 2008 | Whirlpool Dryers
Dryer doesn't get hot or turn off.
yes very possible timer but my guess on the times i seen the problem would be the heating element are the thermo fuse on the elemnt canister when the heater does not come on the timer will not move ck the heater and the fuses on the heater canister it will fix your problem
Feb 28, 2008 | Whirlpool LER4600 Electric Dryer
Dryers Logo
120 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
