Question about Panasonic PT-50LC13 50" Rear Projection HDTV
WERE exactly is the Lamp in my T.V ?
WERE exactly is the Lamp in my T.V i want to know if you guys can give me a diagram of my T.V or tell me were it is because my LAMP must be replaced
  • 58 Answers
You must remove the plastic cover from the front and just left of center there is a panel covering the lamp with a single screw. Under that the lamp is also held in with a single screw. Pull on the handle firmly to remove lamp. Replace with TY-LA1000 bulb.
Posted on Jul 05, 2010
Hi can one of you guys give me a wiring diagram or skematic of the cooling fan, the relay and the tempurature sensor for the 1991 beretta gt i know where every thin is i just need a diagram or pic of how...
Sorry i have a lot of them but not a91 berretta .Keep Trying or you can try going to the dealer and ask at the parts window they most of the time if you know exactly what you want will give you a print out of the system olny takes a munite
Jan 28, 2011 | Chevrolet Beretta Cars & Trucks
Panasonic PT-61LCZ7 is a Lemon I purchased this TV on 11/23/07 The first lamp assembly was replaced on 5/21/08 the second lamp assembly was replaced on 2/19/09 and now it is 10/16/10 and it is out again....
I have the exact problem with the exact model! I'm getting ready to garbage it and I would if the darn thing didn't cost me over $2500 to buy. Do what I did..call panasonic 1-800 number, tell them your story, then tell them you want it forwarded to the top guys, they will give you a referance number and tell you someone will call you back, hopefully the "big" guys will pay for the next lamp, I'm going to ask for a new tv of comparable value...I've had it with these guys! Hope this helps
Oct 16, 2010 | Panasonic PT-61LCZ70 Television
I have my samsung almost for 3 years. and cahnge the original lamp after that i replaced the lamps 3 times more.i dont kwon is normal. but i think is something else. thank god i dont pay anything for the...
use only original samsung lamp with the housing and socket attatched.
The lamp door switch may be intermittent,so you are temporarily fixing it by open and closing the door. The ballast can cause the failure as well. Avoid short period off and on times as turning the set back on in intervals less than an hour will cause microscopic cracks in the glass because the lamp needs too cool down to room temp before it is restarted for ultimate life........I hope this helps!!
Jun 03, 2010 | Samsung DLP HL-P5663W 56" TV
I just turned it on for the first time & its telling me to boot-I Dont know how or what to do!
This seems that there is no operating system in ur PC Desktop. what I suggest you that is get it checked with some service guy because unless we understand the exact problem its not possible give the solution.
Regards
Feb 22, 2010 | Computers & Internet
Please describe the exact location of the fuel pressure regulator 2000 gmc jimmy sle 2wd 4.3 v6
give these guys a call they sells only GM-parts Schram auto & truck parts and they should be able to tell you 1-800-292-1032 and they website is www.schramauto.com you can also stop by your local GM-dealership in the parts department and they be able to print you off pictures and diagrams showing you for the most part its under the hood in the fuses box wish you the best of luck Michigan Man.
Jan 07, 2010 | GMC Jimmy Cars & Trucks
Does anyone know where I could buy some 1985 Eldorado Crondelay top Curtasy lights? You know the ones on the outside?
Check your Cadillac dealer first. eventhogh these guys are going to tell you GM has discountued them they know whos got rvrn in the after markey as they fix the cars they sell and their very proud to tell you so they'll maybe even help you find them as their that proud. The vender will give you a proud price too as they made them for GM and their not got the order now and custom one offs cost but for the right money they'll make what you'll pay for. Most of them whent out in the first few years from new as the replacementones will do too. Check Year one
Aug 16, 2009 | 1985 Cadillac Eldorado
Need to reset lamp timer
The lamp timer expiring would not shutdown the unit typically. Purchase a replacement lamp and included will be the instructions to both replace the lamp and reset the timer.
Dan
Apr 15, 2009 | Mitsubishi ES100U Multimedia Projector
I own a 2005 Impala, but, in error, I purchased a 2000 Impala High Beam Flasher. The 2005 and 2000 Impala have differant head lamp plugs. I am pretty sure you cannot give me exact wire-to-wire matching I...
Bulldogsecurity.com is a great site and gives wiring diagrams for all makes/models of vehicles. The other person is right, it would be best to purchase the proper part for your vehicle.
Dec 14, 2008 | 2002 Chevrolet Impala
Samsung DLP HL-P5063W. . .no lamp!
You will need to have it diagnosed if you do not have the service manual, or the knowledge of how these circuits work. I can tell you to replace this or that but it would be a guess! You need to start measuring the voltages on the ballast circuit, as I have seen door switches, fan sensors, heat sensors cause all of your symptoms as well. Good Luck
Jul 24, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
90 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
