Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
Model gu1200xtlq dishwasher can't find my manual it is 8 years old and having problems with dishes not getting clean particles left inside cups and on dishes and even inside the tub after a cycle
  • 1,531 Answers
You can go to www.frigidaire.com and input your model number in the manuels colum and you will be able to download a new manuel.
to clean you dishwasher you can use some CLR or any other kind of lime and scale remover to clean the inside and the spray arms.
if this does no good then you may need to replace the main wash motor.make sure there is enough water in the unit when it is running lack of water is a big problem with not getting dishes clean
Posted on Jul 05, 2010
Our ten year old kitchenaid dishwasher doesn't get the dishes clean. there is food particles left on dishes if we don't completely rinse our dishes. is there a cleanout filter that needs to be emptied?
Locate your dishwasher's filter. It is typically on the floor of the dishwasher. Pull out the bottom rack and look along the bottom of the dishwasher until you find it.
Use a paper towel or sponge to remove any residue or debris that has accumulated on the outside of the filter once you locate it. On some dishwashers, the filter area does not detach or open, so your hand cleaning will stop here. On other models, you can unscrew the filter housing to access the inside and clean any debris from the filter area. Simply wash out the filter using soap and water, then reassemble once cleaning is complete.
Further clean the filter area by pouring a quart of white vinegar into the bottom of the empty dishwasher. Turn to a wash cycle and allow the dishwasher to run with the vinegar cleaning the mechanisms, including the filter.
To deep-clean your dishwasher and the filter periodically, mix the following ingredients together in a bowl, then pour into the bottom of the dishwasher: 1/2 cup salt, 1/2 cup baking soda and 1 cup bleach. Let the mixture sit in the bottom of the empty dishwasher overnight. The next morning run a wash cycle, letting the bleach mixture clean and disinfect the dishwasher thoroughly.
Aug 29, 2010 | KitchenAid Dishwashers
I have a Tappan Dish washer, model TDB21ORFS5. There is a strainer in the bottom and I would like to clean it. We are getting some very small particules of food left on our top rack inside of large cups...
Refer user guide. They would have given clear instructions regarding cleaning.
If you are finding it difficult pour sufficient water in the wash chamber. When the particles float remove them manually using a small cup.
It's little bit tough exercise!!
May 20, 2010 | Dishwashers
Small food particles getting stuck
Check your drain filter and clean them. refer user manual for location
Apr 06, 2010 | GE Nautilus 24" Built-in Dishwasher
Does not clean the dishes
Hello, I can help you. With the dishwasher empty, toss in two cups of white vinegar and run the machine on its longest and hottest cycle. This will thoroughly clean the machine.
Now put in a load of dishes, be sure to run the kitchen faucet til the water is as hot as it will get and then start your machine.
Aug 11, 2009 | Dishwashers
GE profile PDW7880J Soap left on dishes and soap left in dispenser
Dishwasher - Soap Stuck in Cup If you have dishwasher detergent stuck in the soap cup after a full cycle, please check for the following conditions:
  • The water temperature should be at 120 degrees (140 degrees if your dishwasher has water heating capability). Check your water temperature Check your water temperature.
  • Make sure the soap cup is not blocked by anything.
  • Allow the dishwasher to fill and make sure it is getting a proper amount of water. The dishwasher should fill for about 90 seconds. On permatuf models, the water should measure 3/8" above the island near the center of the tub. On all other models, the water should measure about 1/2" below the heating element.
  • Check the lower spray arm for any blockage in spray holes or items that would restrict its turning.
  • Make sure the soap cup has opened at the end of the cycle.
  • Check the sump area inside the dishwasher for any restrictions.
Apr 09, 2009 | Maytag 24 in. MDBH950AWS Built-in...
Poor cleaning
I also have the same problem. My dishwasher is about the same age and there is a terrible film on everything. A vinegar rinse helps, but you can't do that everytime
Feb 04, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
No clean dishes
Internal filtersEvery dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve
Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms
There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Detergent cups
Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
If the detergent cup isn't opening, see the "The detergent cup doesn't open" section, below.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Sep 12, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Top dishes don't come clean
Dear friend,
ngfam at you service! happy to assist!
Go into the user manual and read how to properly load your dishes to get the maximum cleaning potential!
there are certain ways to load the dishwasher that allows the spry to hit all the dishes.
Second check the bottom of the dishwasher if there are food particles left on the bottom at the end of the wash!
They can be the problem if they are recirculating back onto the dishes and then drying on them when the dry cycle goes on!
Third, They sell for about 5 to 8 dollars a small box of dishwasher
cleaner that you ad and run with no dishes in it 2 times a year!
And last, there may be a problem withe the drain or pump that its not pumping out all the wash water!
If this is the case you need service to check it out before some one in your family gets violently ill..!
We sell appliances for 65 years and I recommend this nation wide Factory repair service to all my retail customers!!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 29, 2008 | GE 24 in. Profile PDW7800 Built-in...
Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
124 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
