My Starchoice Remote Control is acting up/ not working correctly. It's a Motorola mdl IRC-442made in Phillippines UA107. I have a second identical Remote that works fine. having two Remotes allows both my wife and myself to adjust the program & sound without having to pass a remote back & forth across the room. where can I get an identical replacement for my defective remote and how much will it cost ?
SOURCE: remote control
instructions for rca remote rcr4258 turn the device your want to program on (TV or DVD, whatever). to program it you push the component button you want to program (example: TV).
while holding down the button try your 4 digit code. when you push the first number of the code you are trying, the light will turn off. when you push in the 4th number of your code the light will turn back on if you do not have the correct code. keep holding the device button down and putting in your codes. You must keep the device button pushed. when you have put in the correct code the light will not turn back on with the 4th digit. Instead your device will turn off. The remote always retains the last code entered. Once you do this I suggest you write down the instructions or type then on your computer and save it.
Just had that problem and it worked. Hope this helps anyone who needs this info.
Posted on Apr 19, 2008
  • 88 Answers
SOURCE: I have an LG 37LC2D LCD TV that is locked.
Bad filters on the main board or a bad AUX REMOTE jack on the back of the unit (also part of the main board) are the cause of this problem.
Try plugging in any jack that will fit into the AUX REMOTE jack on the back and then pulling it back out. This may fix the problem or remove any dust that may have collected in the jack. If this jack has something plugged into it (or goes bad) the TV will no longer have remote control operation (because it thinks an external remote box is being used). If this does not work then the main board will need replaced.
Note, many repair techs will think the IR board is bad (the Infra-Red Receiver board) at the front of the TV, but this is usually not the case with this model.
Hope this helps, please rate my solution.
Posted on Jan 11, 2009
SOURCE: vx37l stopped working with FiOS remote
I read in another forum where Vizio sometimes uses Vidtech codes. I got 0205 to work on my new Vizio V037L with my Verizon FiOS remote (Phillips RC144).
Posted on Feb 19, 2009
  • 558 Answers
SOURCE: Cant program remote control..atlas 1056B01
You can try Funai and Emerson codes
Posted on Apr 06, 2009
SOURCE: can't get Satalite remote model IRC 451 to work with my tv
theres nothing much i can tell you, i searched google through maybe 5 pages, everyones having the same problems. i'll keep looking for you though
Posted on May 01, 2009
How do I get Codes and Instructions for Motor5ola pn530131-001
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier. Do a search by type in the brand name of your device at its search box. Check this link too.
May 15, 2014 | Motorola Televison & Video
I had a IRC 550 starchoice remote and it ran my panasonic home theater system but quit working so I purchased a IRC 551 and couldn't get it to run the audio Shaw suggested i try a ir 600 remote and I found...
If your home entertainment device does not respond to
the Star Choice IRC 551 IR and Star Choice URC 551 IR/
UHF Remote Controls after trying all of the codes listed
for your brand, or if your brand is not listed at all, try
searching for your code.
For example, to search for a code for your TV:
1. Turn on your TV.
7. To search for the codes of your other devices,
repeat steps 1 through 5, but substitute the
appropriate key (e.g., AUX, DVD, AUD, or SAT)
for the device you are searching for.
Jan 29, 2011 | Panasonic Home Theater System System
I have a Panasonic home theater and am looking for a code that will work with either a starchoice IRC 550 or shaw direct ir/rf 600 remote
This is the manual for the irc 550 ..and in the manual you have the codes for audio (cd ) which I believe to be the ones you need to use..They are on the end of the manual ..But ! If you read the manual carefully you see that it actually can pick-up the codes automatically if you follow certain programing procedure.described in the manual ..
Jan 28, 2011 | Panasonic Home Theater System System
Turn the TV on. Press and hold the TV button until it blinks and then release. Use the UP arrow key to scan through the codes slowly. When your TV turns off then press the ENTER key.
Aug 23, 2010 | One For All URC-3021 Remote Control
Code for a Zenith ZN530 remote
I hope this helps..
0017, 0463, 0178, 0092
Jun 08, 2010 | Zenith ZN530 Remote Control
Can't get Satalite remote model IRC 451 to work with my tv
May 01, 2009 | Proscan 32LA25Q 32 in. LCD TV
Can't find code for Motorola Starchoice sat.receiver
Hello, I just tried the same thing for about 2 hours on a buddies system. I did find on the internet to try 0000, 0001, 0002, 0003, 0004, to 0007 see if one of these work?
Mar 25, 2009 | Onkyo TX-SR606 Receiver
"denial of service": email, firefox, etc. cannot find server..
What told this was a "denial of service"?
Some hackers use DoS (above) it's considered the worst thing you can download, they can go from keylogging your PC, from taking over your pc anytime they like, and using your bandwidth which is called DDOS.
This is a very compllicated thing to get ride of,
One way you can test to see if your a victum of this is to check the port, here is how:
To open the MS Dos screen go to:
Start>Run>type "cmd" and press enter (without quotes)
All of the IRC Zombie/Bots open and maintain static connections to remote IRC chat servers whenever the host PC is connected to the Internet. Although it is possible for an IRC chat server to be configured to run on a port other than "6667", every instance I have seen has used the IRC default port of "6667".
Consequently, an active connection to an IRC server can be detected with the following command:
netstat -an | find ":6667"
Open an MS-DOS Prompt window and type the command line above, then press the "Enter" key. If a line resembling the one shown below is NOT displayed, your computer does not have an open connection to an IRC server running on the standard IRC port. If, however, you see something like this:
. . . then the only question remaining is how quickly you can disconnect your PC from the Internet!
A second and equally useful test can also be performed. Since IRC servers generally require the presence of an "Ident" server on the client machine, IRC clients almost always include a local "Ident server" to keep the remote IRC server happy. Every one of the Zombie/Bots I have examined does this. Therefore, the detection of an Ident server running in your machine would be another good cause for alarm. To quickly check for an Ident server, type the following command at an MS-DOS Prompt:
netstat -an | find ":113 "
As before, a blank line indicates that there is no Ident server running on the default Ident port of "113". (Note the "space" after the 113 and before the closing double-quote.) If, however, you see something like this:
. . . then it's probably time to pull the plug on your cable-modem!
Note that a Windows IRC client program running in the PC will generate false-positive reports since these are tests for IRC client programs. So be sure to completely exit from any known IRC client programs BEFORE performing the tests above.
Oct 18, 2007 | Dell Inspiron 2200 Notebook
Televison & Video Logo
149 people viewed this question
Top Televison & Video Experts
