Question about MSI PM8M-V Motherboard
I have hdd sata and i want to setup win xp on it but i cant winxp can not cont
  • 748 Answers
Check your BIOS setup for the SATA interface settings. If it's set to "Native" or something to that effect, change it to "Compatible" or "IDE" or similar, and try installing XP again.
As a last resort, you may need to supply SATA drivers for your motherboard (unpacked, with all the individual files visible) during the setup, when it says something like "press [something] to supply 3rd party device driver". The problem is, that Windows expects it on a diskette...
Posted on Jul 05, 2010
  • dds ds Sep 15, 2010
    To recognise the SATA HDD in your MSI PM8M -V. First enter the bios menu, go to Integrated Peripherals, Then VIA on Chip IDE then on SATA mode Select IDE instead of RAID. There you go. your SATA HDD will now work like a IDE and it will now be recognised as IDE. you can now use it.a regular drive
    Enjoy!!
ASUS P4P800S-X SATA problem
It could be a bios thing have a look a there for a option to chage from IDE to SATA
Mar 31, 2012 | Intel ASUS P4P800S-X 848P Socket 478 DDR...
Displays no hard drive found wen installing win xp
You have to go to BIOS setup, find HDD setup, and change the value to the other one (there are only two possibilities). That will fix your problem. The problem is caused by the fact that the lap top was designed for vista, not XP. and the lap top contains SATA HDD. when installing XP pre-installation doesn't have SATA drivers, so your OS can not see the HDD. Change it in BIOS, and you trouble is gone
Nov 14, 2009 | Toshiba Satellite A200-19501F Notebook
I am tring to install win XP with sata drive and
Make sure it is listed in your system CMOS before starting the XP install. Make sure cables are correct, and the drives are not turned off in CMOS. Some setup will allow you to set the drive types to AUTO, so you can also try that.
Jun 30, 2009 | MSI 661FM3-V Motherboard
I have a sata hdd and i want to install winxp sp2 and now during partition message display how can i solve it..????
I have experenced this before. Its because the XP install you have does not have sata drivers compatable with your drive. Two possibilities.
1. sometimes with the BIOS you can change the Sata settings so that XP can see it during setup.
2. Download the sata controller drivers and during the setup. it prompts you to add extra drives with F6.
Jun 10, 2009 | Computers & Internet
Cannot Detect Hard drive Winxp On Toshiba Satelite L200
Hi ,
u can not detect HDD during installing win-xp coz in u r laptop u have SATA hard drive.
to detct hdd in setup u want to make sata netive mode diseble in COMS setup
Plz check COMS thereis sata netive mode is available ....
if this information is useful for u please rate me......
Jun 14, 2008 | Toshiba Satellite Pro A200-EZ2204X...
Sata hdd cant install
hi
go to your bios setup
go to advanced option your sata hdd is disable enable it.
if it is enable then boot your sys with bootable disk
go to dos mode.
type FDISK
Y
4 TO DISPLAY INFO OYUR PARTITION.
IF YOUR PARTITION ARE NON DOSE DELETE IT
THEN RESTART YOUR SYS.
U CAN INSTALL XP NOW.
Mar 25, 2008 | Mercury KVM800M Motherboard
A205-S6812
dear tparesh
you not write specific error message that you get
oke, let me know
thanks
cropp
Mar 17, 2008 | HP Pavilion dv6000z Notebook
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
Downgrading from vista to xp sp2
I know this problem, The HDD is a SATA disk, win XP setup cannot identify a SATA controller on it's own you need to load the driver (from a disk) so you may need to download it first. I think this is the correct link http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-51521-1&lc=en&cc=us&dlc=en&product=3369431&os=228&lang=en extract the files and burn to a CD or Floppy then run win XP setup by booting from CD you should see in the begining of win XP setup from CD it prompt you to press (I think) F2 to add RAID or SCSI Controllers, (this prompt is at the bottom of the screen) Then follow the propmts to load from the disk you made earlier. you should be able to select the controller from a list. (short list) you should then be able to continue and hopefully Win XP setup should now be able to see your HDD and give you choices about which partition (as per normal) you want to remove all partitions before installing winXP (you can then make whatever partitions you wish) Hope this helps
Aug 06, 2007 | Compaq Presario 1200XL104 Notebook
MSI PM8M-V Motherboard Logo
115 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
