Question about HP Pavilion dv7-1132nr Notebook PC
My wireless connection is not waorking. It is in red on the back panel. How o I get it to work?
    New Friend:
  • 102 Answers
CLICK ON
start menu, help and support, then on thel left you should see getting started, click on it then on the right look for wireless network overview, click on it.
now at the bottom look for a highlited called related topics,Click on it then click on connect to a wireless connection. A page will come up and follow directions
Posted on Jul 05, 2010
Will not scan for wifi
If it can see wireless networks.
  • Make sure any physical wireless switch is turned on
  • In Device Manager make sure the wireless doesn't have any driver problems (yellow ! or ? or red X), Try reinstalling drivers.
  • Open the back panel where the wireless card is and make sure the antennas are connected.
Dec 25, 2012 | Sylvania G-Netbook
Compaq presario F500. Wireless internet connection not working. Internet works when plugged into modem. D-Link wireless modem working perfectly. Constant red/orange light on next to wireless switch at...
Hi, Thanks for using fixya.
When you connect it to wireless make sure you go into control panel / network view your connection right click on local area network connection choose disable then connect to your wireless connection. Right click your wireless icon by your clock choose connect to wireless network or view available local wireless connection.
Terry
Feb 15, 2011 | HP Compaq Presario F500 F700 and G6000...
I just purchased a Belkin Surf N300 and it worked for 24 hrs. This evening I was using it and suddenly my computer shows the wireless button red, which must mean it is not turned on. I do not know why...
First uninstall the belkin setup and router monitor from control panel and dont install the cd again in computer...
then goto network connections and right click on wireless network connection icon and enable the wireless network connection...
Now check if you are able to go online...
Jan 28, 2011 | Computers & Internet
How do I switch my wireless back on? The wireless
check the "F" keys there should be a wireless signal symbol hold function and press the one with that symbol
if that doesnt work go to control panel, network connections, then look for the wireless one right click then enable
Jan 17, 2010 | Compaq Presario Notebook
After trying to set better security, it doesn't work. I don't know what I clicked now. The red light is on the globe icon.
Removed the preferred networks
In Vista :
Start -Control panel - Network and internet - network and sharing center - on the left Manage wireless networks - right click on your network - select remove
In XP
Start - control panel - network and internet connections - network connections - right click on wireless network connection - properties - click on the wireless networks tab l under preferred networks click on your network and select remove
And after that scan and connect to ur network
Jan 04, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wireless connection wont work
To check if the wireless card is bad or OK.
Go to Control Panel - Network Connections - Is the wireless network connection listed and if so is there a red X on this connection?
If so, right click on the wireless and click Repair - this may fix your problem, it forces the wireless router to issue the wireless card with a new IP address.
If it doesn't fix the problem then go to Control Panel - System - Hardware tab - Device Manager - scroll down to Network Adapters and expand and check your wireless card, is it Working and Enabled?
If has a yellow ? against it or not working then reinstall the wireless card driver.
If the wireless card is built-in check the BIOS to see if the wireless card is enabled, if not enable the wireless card and repeat the above steps.
If this doesn't fix your problem then the wireless card is faulty and you need a new wireless card. You can get a PCMCIA wireless card to replace the faulty wireless card. If the wireless card is built-in then disable the faulty wireless card in the BIOS before you install the new wireless card.
Oct 11, 2009 | HP Compaq Presario 2200 Notebook
I have a desktop that is contected to DSL through the linksys router and it connects ok. I have two wireless laptops and neither will connect as of yesterday. When I go to network connections I see a red x...
Your router is turned off that's why it says network cable is unplugged and your wireless does not work. Check if there are lights on the front panel of the router. Make sure the power adapter is plugged in
Apr 15, 2009 | Linksys Wireless-G WRT54G Router
Need help getting wireless laptop connected to internet
1. Go to Start, Control Panel, syetm.hardware, device manager. Under network adapters make sure your wireless is there. Note: there is a recall for HP laptops including the DV9000 because they eractically lose their wireless settings. If this is the case call HP tech support.
2. Assuming your wireless card is listed (not the 1394) and there are no red or yellow check marks we can now go back to control panel, network connections.
3. If wireless connection is not listed then click the task Create a new connection. This brings up Welcome to new connection wizard. At this point you should see a line that says to connect to a wireless network in range . . . If this line is there click this then select your SSID (network name). If this line is not there and you're sure the network switch is on and turned blue then you'll need to call HP.
Mar 23, 2009 | HP Pavilion dv9000z Notebook
CAN'T REACH CONTROL PANEL
Connect to the router using a wired connection and use a blank username and "admin" as a password not username.
Oct 27, 2008 | Linksys RangePlus WRT100 Wireless Router
Wireless router, laptop problems
Try to delete all the prefered networks. Right-Click Wireless Network Connection, View Available Wireless Networks. Click on Change the Order of Prefered Networks. Remove all prefered networks there and click OK. Now try to View the available wireless networks again, reconnect to your own wireless network and see if it connects fine. Post your feedback.
Jul 12, 2008 | Linksys Wireless-G WRT54G Router
HP Pavilion dv7-1132nr Notebook PC Logo
110 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
