Question about ViewSonic N3252w 32 in. LCD Television
Viewsonic Tv turns off on its own...You will be wtching tv for a bit and then it clicks off and not off off the green on button goes red you press it 2 time and it will turn back on but for less time then the last time it was on till you turn it off for an hour or so then you can get 30 min out of it again.
  • 608 Answers
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Posted on Dec 09, 2010
Programming remote control
Setup code to Viewsonic TV are: 0046 0072
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Jul 16, 2012 | Televison & Video
Viewsonic N3752w LCD TV: plug in, red light goes on, press button and green goes on but then off before any picture; seems dead, no red light or green and nothing happens when press button again. If I...
We have the same problem with ours. I'm suspecting it's the power supply board. I'm going to order a new one, swap it. That should fix it, I suppose.
Oct 04, 2010 | ViewSonic N3752w 37 in. LCD TV
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
TV not turning on.
Mine was doing that and I ordered a replacement power supply board for it and now it work. It's fairly easy to replace.
http://www.partstore.com/GetModel.aspx?MfgName=Royal+Philips+Electronics&BrandName=Philips&ModelNumber=37PF7320A37&page=16
Mar 14, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
ViewSonic N3250W Locked
Yeah, my 19 year old daughter did the same thing. I found a solution on the 2750W thread
http://www.fixya.com/support/t115143-tv_just_flashes_different_colors
Solution - just press Menu, Enter and Power buttons at once.
Jan 28, 2008 | ViewSonic N3250W Television
Power
same problem here
Dec 20, 2007 | Pioneer SD-P50A3-K TV
Viewsonic N3251 doesn't turn on right away
Solution... Call viewsonic and **** till you get a new one (diff model). Good luck, you're going to be on hold forever.
Nov 15, 2007 | ViewSonic N3251w 32 in. LCD HDTV
ViewSonic N3252w 32 in. LCD Television Logo
336 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
