Question about Toshiba Satellite L500 Series Notebook
How do I use the Security Lock Slot on my Toshiba laptop
Security lot slot
Security ?lot? slot...
Do you mean security lock slot? There is a hole at the back of the computer which takes a device called a Kingston lock which is used to secure a laptop to a desk to prevent theft.
It looks like this
Jul 06, 2014 | Toshiba Satellite L500 Series Notebook
Toshiba Sattlite, boots but black screen. Caps Lock light is on and F10& F11 key is okay.
Corrupted operating system. Start over with a restore disc and if you do not have one buy one you will need it from the factory. Re-install the whole system over again. Insert the disc in the slot and power it on select boot from DVD or CD-Rom which ever you have. Follow the onscreen instructions. John
Apr 09, 2012 | Toshiba Satellite L305-S5907 Laptop
What is the little button thing with a lock beside the power adapter port
It could be the security slot where you can connect a security cable to stop the powerbook from being stolen.
Feb 26, 2012 | Apple PowerBook G4 Mac Notebook
How do I install addition ram in my toshiba satellite laptop L30 134
  • Shut down your Toshiba L30-10S.
  • 2 Unplug the A/C adapter and disconnect all external devices.
  • 3 Turn the L30-10S over and locate the battery pack at the top edge of the computer.
  • 4 Slide the battery release switch to the bottom right of the battery to release it. Set the battery to the side.
  • 5 Locate the RAM compartment door in the center of the computer.
  • 6 Remove the four screws holding the door in place.
  • 7 Lift the RAM compartment door off to reveal the RAM slot beneath.
  • 8 Lift the clips on the ends of RAM slot to release the current module.
  • 9 Slide the module out of the slot at a 30-degree angle and set it to the side.
  • 10 Slide the new module into the slot at a 30-degree angle and press gently down until the latches lock down and hold it securely. Replace the RAM compartment door and battery, then reconnect the AC adapter and external devices.
  • Dec 31, 2010 | Toshiba Computers & Internet
    Port with rectangle symbol?
    I think that you mean the "PC card slot". It's a slot for using with some kind of external accesories. For example some could use it for a firewire card slot, so that can connect a firewire on the laptop. Here is the left side of your laptop
    In case you want here is the link for your laptop from Toshiba.
    Don't hesitate to reply at this post for further help.
    Feb 24, 2010 | Toshiba Satellite L15-S104 Notebook
    Misc card stuck in slot, how do i get it out ?
    1. Shut Down The laptop
    2. Remove the laptop Battery ( Close the Lid , turn the laptop Up side down, search for a battery Lock tab, move it to Unlock position, You can see a Lock/Unlock mark on the Laptop cover, this will eject the battery from the slot.
    3. Get a tweezers carefully pullout the memory card from the card slot, utmost care should be taken not to damage the card slot contacts
    4. After taking out the card put back the battery make sure that it is in the locked position
    5. Start the computer , try out the system
    6. Verify the memory Card reader functionality using a proper card as per the maker guidelines
    Jan 31, 2010 | Toshiba Satellite Pro A210-EZ2203X...
    Toshiba NB 100 Netbook
    There is no button? Is it magnetically held together? The security lock slot is for securing it to a table or desk with a lock cable so it can't be stolen. I would bring it back to where you bought it. It sounds like something got banged and is now malfunctioning. Can you see between the bottom and top pieces of the laptop at the front? If so try using a business card to unstick the clasp. Go from either way. Left to right or right to left. If that doesn't work apply a SMALL amount of pressure to above the clasp, right on the frame not the screen, and try the card slide again. Let me know. Hope this helped.
    Jan 11, 2009 | Computers & Internet
    Toshiba m55-s135 memory install
    Not all laptops have spots for two sticks of ram. Double check the specs but the slots should have been in the same spot.
    Jul 30, 2008 | Toshiba Satellite M55-S135 Notebook
    Toshiba Satellite L500 Series Notebook Logo
    1,438 people viewed this question
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
