Question about Danby DAC5071M Thru-Wall/Window Air Conditioner
No Cold Air
My AC is only a year old, and seems to be humming louder than it did in the previous summer season. It is also not blowing any cold air. Instead it seems to just blow in the air from outside, not cooling it at all. I have tried shutting it off and letting the motor cool, but this doesn't help at all.
    Habit-Forming:
  • 159 Answers
No cool air = No gas. Gas leakeage. Refill with gas and change silica filter.
Posted on Dec 16, 2014
  • 29 Answers
It sounds as though the compressor is stalled or seized. if its seized a new will be required! If its stalled it may be down to a failed capacitor, if you have a voltmeter test for voltage at the compressor.
When shutting off leave it off for a good 24 hrs
All the best
Posted on Jul 05, 2010
What is going on with our Goodman unit?
If your going to pay that much just have them put in a new unit. It is not that much more and you can get free financing. All the repairman can do is guess and keep putting in new parts till it works. Had a new unit put in and it still didn't work found out it was a bad thermostat. But at lest we don't have the repair bills or high electric bill anymore so it paid for its self in saved money.
Jul 21, 2014 | Goodman Heating & Cooling
Not staying cool
sounds like it is either low on Freon or the compressor is going out. The blowing ice cold is an indicator that it may be freezing up because the low Freon. when it stops blowing cold, turn it to fan only mode and see if it gets colder again. If that is the case then the unit is low on freon and freezing up. I know that sounds confusing but that is how AC works. The low freon pressure means the gas is expanding too fast and the air flow cannot take up the cold from the evaporator fast enough. Turning the compressor off and keeping the fan on will alow the room air to take up the cold.
Apr 22, 2014 | Frigidaire FAM157S1A Air Conditioner
Heating and air
My first thought was low coolant, but with the added point about the ac I'm leaning toward a blend door problem under the dash.
Feb 27, 2014 | 2007 Suzuki Grand Vitara
2005 chevy equinox only blows cold ac out of passenger side
check the air vent of passenger side for any obstruction and secondly keep your thermostat full towards cold side make sure the ventilator is fully closed position and rotate the air selection knob clockwise and anti clock wise two three times than set it at the required position mainly your air selector seems to be malfunctioning there is nothing wrong with the ac
Aug 14, 2012 | 2005 Chevrolet Equinox
AC blowing warm
Is it that hot in Sedona. I live in Tucson and thats hot. Have your freon recharged. You can buy the refrigerant at Checker or AutoZone. How do you like our Governor. She really made the national news.
Apr 25, 2010 | 2005 Kia Sedona
Furnace unit to be louder now than last season
Check your air filter, make sure all registers are open full and there is no restriction in all ducts. Could be an unbalanced fan, clean the squirll cage fan with a brush and vacuum.
Jan 09, 2010 | Heating & Cooling
2 year old Coleman Mach III tapping and not blowing cold air:
Make sure the condensor fan is blowing through the condensor on the roof. It sounds like the compressor is fighting high head pressures after running a bit.. After so many attepts, or if it suceeds in operating the load trips the circuit breaker.. Make sure the condensor is clean and air is passes through it from the fan. Just for clarifiication the condensor is the coil that gets hot and the evaporator is the coil yat create the cold air. Good Luck, and if you will, let me know how it turns out. Good Luck. Ned
Sep 19, 2009 | Dometic Rooftop RV Air Conditioner
Air conditioning failure
The most probable cause is that you have a leak in your A/C system..and it needs to be serviced with R134A and a can of red dye added so the leak can be found..i hope this helps ya...Keith
Jun 27, 2009 | 2002 BMW 5 Series
Ac and heater work great but go off. Then Ac blows Hot / heater cold air
I got a bigger coat to wear! while I find time to look into it further. I appreciate knowing there is more help available and will try the Primo Asist plan later. thank you louie
Nov 03, 2008 | 2001 Honda Insight
Intermittent AC and Heat w/ long gaps of hot(for AC) or cold(for heat) air
I had similar problem on my 2001 Insight. Had to replace some cooling system hoses eaten by rodents... Works like a champ again.
Danby DAC5071M Thru-Wall/Window Air Conditioner Logo
175 people viewed this question
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
mintvl
Level 1 Expert
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
