Question about Dishwashers
I have a beko DE6340w dishwasher and it is stuck on drain and does not switch off when finished can you help please.
SOURCE: BEKO D 2731 FW Dishwasher Problem
yes man,it worked 1st time,cheers for that info.
Posted on Sep 28, 2008
  • 1462 Answers
SOURCE: Bosch dishwasher is stuck on drain cycle
cause is water in the bottom tray which operates an anti-flood switch and all machine will do is drain.
disconnect from mains
remove bottom panel and mop out water and it will work. if fault re-occurs, then you have a leak which you will have to identify
Posted on Oct 20, 2008
SOURCE: pump not draining - Haier portable dishwasher
purchase new pump at www.partsquick.com/haier
about 33 shiped must be able to replace if they sell the pump i have the same problem looking for a diagram to replace pump
Posted on Jan 05, 2009
Karthik316
  • 187 Answers
SOURCE: Brand new dishwasher, doesn't drain water and will not work now!
hi,
try this site
http://www.cookshomeappliance.com/dishwasher_troubeshooting.htm#Constant Noise During Washing or Drying
please rate my suggestion..
Posted on Apr 12, 2009
  • 128 Answers
SOURCE: Drainage
Float valve is jammed.
Look inside the machine on the floor will be a small float valve. Looks like a small upside down cup. Lift it and clear anything from underneath.
The valve is a safety feature to stop the machine from over filling. If anything gets under the valve it will jam open and stop the machine.
Not working?
Check for a clog internal or external.
Scoop as much water our as you can. Open the cover on the floor of the machine. Usually just turns and lifts out or snaps out some are screwed in. Take your time and try not to force anything. Look for a clog there.
Check for clog in the drain. The dishwasher will connect to the drain under your sink and run either directly to the drain or into your disposal unit. Remove open the connections and look for a clog. Clear if necessary.
Not the clog?
Water is pumped out by the machine via an internal pump located under the base. If it fails the water will collect until it trips the float valve. First scoop out all the water from the machine and run it again. If water comes in and it runs to the point it fills again and trips the float then either the pump or timer is faulty.
Pump check.
Remove the machine. It will be held in place by screws directly into the counter top. You may have to lower it to get it out. The front feet turn with a wrench to lower.
Turn off the water supply. Run the unit again until you get to the drain cycle.
Connect a test light or voltage tester to the terminals at the pump. Check for voltage at the pump. If you have voltage replace the pump. If no voltage the timer is faulty.
Timer problem?
Some can be replaced as a unit others are integral to the control panel. Turn style can be replaced. Touch control can not.
For more help go to my more detailed tip "Dishwasher will not run. DW101 how to fix". Or click on my profile and you will find the link there.
Hope this helped you. Please take the time to rate this tip.
Thanks,
Adrian
Posted on Mar 13, 2010
Beko 450 dishwasher not filling up
normally there is a water censor that is in the back of the machine you will need to remove the back and look for a small pipe 5mm diameter going upwards remove it blow gently into it you should hear a click and one when you release the air, if so then the switch is ok but the small metal or plastic pipe where it came from was blocked unblock the pipe return then pipe back to its position and the problem should be gone only attempt this if you are competent and get a friend to help eric
Dec 25, 2017 | Beko Dishwashers
My Beko 5411 dishwasher will not start it's cycle
There will be something stuck inside the drain pump, You only have one issue, as it is only 2 months old opening it up to unblock may affect your warranty but it's not a problem covered by warranty so they will charge you to fix it, if you decide to try yourself you need to remove the kick panel and you will be able to see the drain pump, you need to unhook it and remove the blockage from it.
Mar 05, 2012 | Beko DE2541FW 18 in. Portable Dishwasher
Dishwasher will not Drain. there is water left in the dishwasher when it finish
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Jan 25, 2011 | Whirlpool Dishwashers
Beko dishwasher not draining
Hi
Daniel
Nov 20, 2010 | Beko 24 in. D3421F Free-standing...
I have a Beko DE 2541f slimline dishwasher and it seems to have got stuck draining - have switched it off and removed power completely but it just starts draining as soon as it's switched on again. Any...
hi there.......your problem can occur when the sump of your apliance becomes flodded....this activates the anti flood switch which causes the drain pump to run....soloution is to dry out the sump or remove machine from its location...tilt it back letting excess water flow from the sump..check that all fixing screws in cabinet are secure including the air vent (mid way u the left/rt hand side of inner cabinet...
test appliance again if problem persists you will need to change the water flow meter
regards Sir Galahad
Jun 29, 2009 | Beko 24 in. D3731F Free-standing...
hi,
try this site
Apr 11, 2009 | Beko Dishwashers
Have a beko washing machine and the water will not drain! Any ideas PLEASE
hi there......the water is not draining because..(a) blocked filter or drain pump....(b)...failed drain pump...(c)...bocked outlet to sink...or blocked drain hose from machine
regards Sir Galahad
Jan 29, 2009 | Beko 24 in. D3421F Free-standing...
Beko Freestanding Dishwasher
Hi there ....this condition is ususally caused by a water leak into the sump of the dishwasher which activates a safety switch to run the drain pump..preventing the appliance from being used....Remedy...tip the dishwasher back in the head allowing excess water to exit from the sump...then with the door open check that the air vent lock ring is secure, thet the salt unit retaining ring is secure..and finally that the filter unit to base screws are secure...this done re-start and you should b fine
Jun 28, 2006 | Beko 24 in. D3731F Free-standing...
Dishwashers Logo
557 people viewed this question
Top Dishwashers Experts
