Question about Maytag Neptune MDE5500AY Electric Dryer
Heat THe dryer wont release hot air only cold
    President:
  • 1,197 Answers
Unplug the dryer and the first thing to do is check for the presence of 220 volts at the wall outlet. If you lost one leg of the 220 volts, it is possible for your dryer to run but there will not be any heat. Once you verified there is definitely 220 volts at the wall outlet, remove the rear cover. On the lower right hand side you will see a silver canister which contains the heating element. Remove the lower two wires directly from the heating element and check this for continuity. If it is good, on the left hand side of the same canister they often install a thermal safety which may have tripped. Do the same test as with the heating element. Remove the wires and test the thermal safety for continuity. If this is good, move to the blower housing on the left side of the exhaust vent and look for a white piece of plastic which has two wires on it. Remove these two wires and check this item for continuity.
you can follow this link below to find out how to test for individual components to find out what part is faulty...
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
You can also order for any replacement part from the following Websites
www.PartSelect.com
www.SearspartsDirect.com
If you found my solution of any help ... please do not forget to rate the solution
Posted on Oct 09, 2010
Blowing cold air
This model dryer has two heating elements, one for the top and one for the bottom, I suspect that the bottom element is burned out. If you want to attempt it yourself then I can send you a service manual that will walk you step by step through the whole dryer.
Dec 11, 2013 | Maytag Neptune MCE8000AY Electric Dryer
My defy tumble dryer is not getting hot just blowing cold air
Apr 21, 2011 | Dryers
Dryer does not blow hot air only cold air
Thank you for contacting Fixya.com.
Please check this bellow links to have an in-depth idea related to your query, hope it helps:-
http://www.appliance411.com/links/jump.cgi?ID=457
Please get back to us if you have any further query.
Have a nice day
Nov 29, 2010 | Whirlpool Dryers
My GE gas dryer is blowing cold air and wont blow hot air. what could possibly be the ploblem.
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 06, 2010 | Dryers
Dryer not releasing hot air
if its an all electric dryer then you may have an open heating coil or a bad contact on the timer that supplies power to the heating element .. a few dryers have a fuse that could be blown ..
if you have a gas dryer then you may have a bad solonoid that operates the gas valve .. or more likely a bad igniter .. thats a module that heats up or sparks to ignite the gas .. the igniter is a replacable item mounted near the gas flame. . the heated type fail frequently on some dryers ..
Aug 18, 2009 | Dryers
Gas dryer wont heat up, blows only cold air.what would cause this
Could be a bad hi limit thermostat. Could be a bad glowbar ignitor. Check the glowbar ignitor at the gas valve, is it glowing bright orange/red? If not. Replace the ignitor.
Jul 22, 2009 | Whirlpool Dryers
Dryer working but not blowing hot air
it sound like the heating element. look to see if it is broken
May 08, 2009 | Bosch Dryers
Dryer blowing cold air only
Check your heat sensors, one or more must be OPEN.
Mar 26, 2009 | Kenmore 84052 Dryer
Dryer will run for a second and sound three beeps and stops.
Sounds like the door switch has gone bad., but your description is confusing.
First, it takes a few minutes for you to feel the air blowing hot, particularly when the dryer is in a cold garage. The heating elements have to heat up the mass of the metal, and any clothes in the dryer.
The timer design is such that it can not speed up (the motor inside wont start running faster, due to it's electrical design.).
I am suspect that the door switch has failed for some reason, because reading between the lines, I think you are saying when you release the Start button, the dryer quits operating. If the door switch is bad, then it will cause that condition to happen.
Jan 18, 2009 | Kenmore 62802 Electric Dryer
Wont blow hot air
heating element failure 30 bucks and an hour of labor
Jan 14, 2009 | Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
55 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
