Question about HP Photosmart 2575 All-In-One Printer, Scanner, Copier
2575 paper jam
Multiple times I have followed the owners manuals directions. The screen on the ,all in one, says clear paper jam, then click ok. there is no paper stuck anywhere. Can some one help? Do I need to tash it, warn others not to buy one, what can I do? "Clear Paper Jam and hit OK" keeps displaying. There is no paper stuck that I can see. I have been able to advance an entire sheet of paper by repeatedly hiting the OK key everytime the clear paper jam message appeared. Has anyone ever seen this problem and was able to resolve the problem?
    Genius:
  • 3,422 Answers
HI,
Please check these two links out.I hope these willhelp you fix the problem.They also have some videos..
CLICK HERE
CLICK HERE
Goodluck,
Please don't forget to rate the solution.
Posted on Apr 18, 2008
  • 3,037 Answers
You could try gently shaking it and see if anything falls out.
You should also try cleaning it, first maybe with some compressed air, you may have a dirty sensor or something
Another thing you should try is unplugging it and allowing it to reset.
Please let me know how the above work out and I can give you further options to try if none of them work.
Thank you for using Fixya and Have a Great Day!
  • Benjamin Patri
    Benjamin Patri Apr 24, 2008
    Please don't forget to rate this solution as that is one of the biggest aspects of all this website works
    otherwise please let me know if you have further questions
    Thank you
My Lexmark 4600 printer has a paper jam. do not know how to unjam it.
How to clear and avoid paper jams
Follow these instructions to remove and/or avoid paper jams and misfeeds in your Lexmark X3500, X4500, X4600 & X4800 Series All-In-One.
Paper jam in the printer
Remove the paper manually
  1. Press pattlnk_10282008_1820-power-icon.gif to turn off the printer.
  2. Firmly grasp the paper, and gently pull it out.
  3. Press pattlnk_10282008_1820-power-icon.gif to turn the printer back on.
NOTE: Check inside the printer to ensure that all the paper is removed. Any small pieces of paper left in the printer will continue to cause paper jams.
Paper jam in the paper support
Paper or specialty media misfeeds
These are possible solutions if paper or specialty media misfeeds or skews, or if multiple sheets feed or stick together.
Try one or more of the following:
Check paper condition
  • Use only new, unwrinkled paper.
Check paper loading
  • Load a smaller amount of paper into the printer.
  • Load paper with the print side facing you. (If you are not sure which side is the printable side, see the instructions that came with the paper.)
Remove each page as it is printed
  • Remove each page as it exits, and let it dry completely before stacking.
Adjust the paper guides
  • When using media less than 8.5 inches wide
  • To rest against the edges of the paper or media, making sure it does not buckle
Printer does not feed paper, envelopes, or specialty media
These are possible solutions. Try one or more of the following:
Check for paper jams
  • Check for and clear any paper jams. For more information, see "Paper jam in the printer" and "Paper jam in the paper support" above.
Check media loading
  • Verify that the specialty media is loaded correctly.
  • Try loading one page, envelope, or sheet of specialty media at a time.
Check printer default and pause settings
  1. Click:
    • In Windows XP (default Start menu): Start pattlnk_10282008_1829-right-arrow.gif Printers and Faxes.
    • In Windows XP (Classic Start menu): Start pattlnk_10282008_1829-right-arrow.gif Settings pattlnk_10282008_1829-right-arrow.gif Printers and Faxes.
    • In Windows Vista (default Start Menu): pattlnk_10282008_1829-vista-start-button.gifpattlnk_10282008_1829-right-arrow.gifControl Panel pattlnk_10282008_1829-right-arrow.gif Printers (under Hardware and Sound).
    • In Windows Vista (Classic Start menu): pattlnk_10282008_1829-vista-start-button.gifpattlnk_10282008_1829-right-arrow.gif Settings pattlnk_10282008_1829-right-arrow.gif Printers.
  2. Double-click the print queue device.
  3. Click Printer.
    • Make sure no check mark appears next to Pause Printing.
    • If a check mark does not appear next to Set As Default Printer, you must select the print queue device for each file you want to print.
Banner paper jams
There are many possible solutions. Try one or more of the following:
Clear banner paper jams
  2. Remove the jammed banner paper from the printer.
Review banner printing checklist
  • Use only the number of sheets needed for the banner.
  • Select the following settings to enable the printer to feed paper continuously without jamming:
    1. With a document open, click File pattlnk_10282008_1829-right-arrow.gif Print.
    2. Click Properties, Preferences, Options, or Setup.
    3. Select the Paper Setup tab.
    4. From the Paper Size area, select Banner.
    5. Select Letter Banner or A4 Banner as the paper size.
    6. Select Portrait or Landscape.
    7. Click OK.
    8. Click OK or Print.
Regards,
Ron
Mar 26, 2011 | Lexmark 4600 Multi Function Printer Option...
Cannot clear paper jam
Paper Jams in the Automatic Document Feeder
If you're loading legal-size paper, insert only 10 sheets at a time to prevent paper feeding problems.
If paper jams inside the ADF, clear the jam and reload the paper as follows:
1.
Open the ADF cover and remove any jammed paper.
Caution:
Do not try to remove the paper without opening the ADF cover first, or you could damage the mechanism.
2.
Press OK, then select Yes and press OK to clear any messages on the display screen.
3.
Reload the paper. Make sure the corners of the paper are not bent, folded, or curled up.
Jan 11, 2011 | Epson WorkForce 600 All-In-One InkJet...
HP 2575 printer - paper jam message
Resetting the product may help with some false error messages. Press power button to turn printer off, unplug the power cord, wait a few seconds, plug it back in, press power button to turn printer back on. Any luck?
Dec 13, 2009 | HP Photosmart 2575 All-In-One InkJet...
I have a 'paper jam error' displayed on my HP PhotoSmart 2575 printer screen which I cannot clear, even after removing the paper and pressing OK. In addition, I have reloaded software and this has been...
A few things to check would be to open your printer and make sure there are no little ripped pieces of paper in the system which could be causing it to keep faulting. Also try unplugging it while its powered on and let it sit for 8-10 minutes and see if that doesn't reset it. Hope this helps let me know if more trouble shooting is necessary.
Jul 12, 2009 | HP Photosmart 2575 All-In-One InkJet...
Clearing paper jam
Solution Use the following instructions to clear a paper jam from the HP All-in-One.
  1. Press in the tab on the rear clean-out door to remove the door. CAUTION: Clearing a paper jam from the top or front of the HP All-in-One can damage the print mechanism. Whenever possible, access and clear paper jams through the rear clean-out door. Figure 1: Pressing the tab and opening the rear clean-out door c00444711.gif
  2. Gently pull the paper out of the rollers. CAUTION: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the HP All-in-One. If you do not remove all the pieces of paper from the HP All-in-One, more paper jams are might occur.
  3. Replace the rear clean-out door and gently push it forward until it snaps into place.
  4. On the HP All-in-One control panel, press OK to continue the current job. NOTE: If the paper is still jammed, see the onscreen Troubleshooting Help that came with the HP Image Zone software.
  5. If the jam occurs again, check to make sure the paper type in the printer matches the paper type set in the printer driver properties
May 09, 2008 | HP Photosmart 2575 All-In-One InkJet...
2575 paper jam
This worked for me. If "Paper Jam" error message continues to appear after jam has been cleared, turn off power to printer. Navigate to Control Panel - Printers, right click on HP Photosmart 2570 series icon, click on Delete on drop down menu. This deletes printer from your system. Turn on power to printer. Printer will re-install (may need original installation disc, may not). "Paper Jam" error message should no longer appear.
Mar 27, 2008 | HP Photosmart 2575 All-In-One Printer,...
HP 2575 Paper Jam
CLICK ON O.K. PRINTER WILL CLEAR ITSELF, BECAUSE THERE IS NOTHING IN JAM.
Mar 27, 2008 | HP Photosmart 2575 All-In-One InkJet...
HP Photosmart 2575 All-In-One Printer, Scanner, Copier Logo
133 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
