Question about GE DBXR463GDWW Gas Dryer
The knob on the right just turns (no clicking) so it does not seem to be selecting a time. now dryer wont start.
  • 259 Answers
Check your timer knob. On these GE dryers I have found a lot of times the knob cracks where the stem of the timer goes in and the resistance of the timer will make ti slip internally rather than turning the knob. If the knob appears to be ok, then I would say you definitely have a bad timer on your hands.
Timer is part number WE4M271 and runs around $100 from marcone's
Knob is
WE1M654 and is around 18$
Good ;uck with this!!
Posted on Jul 06, 2010
Kenmore gas dryer model 84152 wont start
-Make sure turn select knob to correct position.
-try again.
Good luck
Mai
Dec 16, 2013 | Kenmore 800 7982 Dryer
My dryer's cotton/time dry/wrinkle free option know turns freely. Dryer will not start.
Take the other knob from the other switch nd put it in that place. It should turn then . You will be able to turn it on by a pair of pliers until you get a replacement knk.
Feb 22, 2013 | Dryers
On the Kenmore 70 series, can the buzzer be disconnected? Our 5 month old gets startled each time that damn dryer buzzes (It seems like it last forever!)
Hi, did you try turning the buzzer off with the knob on the right side of the operation panel (which is also used as the start button)? If you turn that knob to the left, it should turn off the buzzer.
If it still buzzes, the switch behind that knob may be faulty. You can get at it by removing the panel at the rear of the dryer (6 screws) and then you can test it and adjust its internal contacts if need be.
Hope that helps!
Mar 03, 2010 | Kenmore 98702 Stacked Washer/Dryer
My timer is not working. the turner is turning to loose. it does not click while turning. the start button does not begin.
Common problem with the GE dryers is the start button will crack and will not catch the stem. Try changing the start knob over with the heat selection knob and see if you can start then.
Feb 01, 2010 | GE Dryers
Electrolux dryer stuck in demo mode
To deactivate the demo mode:
Turn cycle knob to last cycle on right. Press start to save cycle position.
Press cancel to turn machine off.
Within 10 seconds, wake unit by pressing start once, immediately press and hold cancel and right most key under the display together for a minimum 6 seconds.
“DEMO MODE” will no longer be shown in the display.
May 24, 2009 | Electrolux EWED65H Dryer
Dryer just stopped working. Turned knob to desired time and pushed start, nothing happens. When knob is on OFF position and I push the start button, it makes the regular BUZZ sound - times up, clothes...
Remove and inspect the timer knob for a crack or missing tension clamp.
Carefully place it back on the timer shaft while paying attention to the (D) shape in the knob and the shaft.
If they are aligned correctly notice where the position arrow is pointing, ie; off---run--etc.
You may well need a new knob.
Feb 21, 2009 | Dryers
Kenmore 90 series electric dryer
check the door swithch first.. won't start if its shot....
tthen look to motor start relay...??
May 04, 2008 | Kenmore 62602 Electric Dryer
How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
GE DBXR463GDWW Gas Dryer Logo
457 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
