Question about Dell Latitude C610 Notebook
Power system problem
My battery is dead, so I've been trying to run my C610 off of AC power until I can afford to replace the battery. However, lately the laptop doesn't seem to be drawing power from its adapter. I have to jiggle the laptop end of the plug towards the left and hold it in that position with something in order for me to power the laptop on.
I suspect that I have a bad power system, and need to replace my motherboard, but want to make sure before I spend the money to replace a part that may or may not be broken. Anyone else have issues like this?
Both of these answers are correct. The problem is exposing the bad component so that it may be heated to induce solder flow or for the offending connector to be replaced. You may wish to inspect the solder joints and do a continuity test before performing any work. You will want to visually see that the solder has flowed properly and that there are no cracks or divits in the joint. You will also want to examine the solder to see that it is nice and shiny, almost a mirror image if it is solder that contains lead. In most cases such as computer boards, the components are placed using solder paste and then ran through a flow soldering machine that melts the paste. Once all of the flux bubbles to the surface, the solder paste hardens and the excess flux is removed in a cleaning an ultra-sonic cleaning tank using dry chemicals to clean the boards. Here is where the problem begins. Not every board is hand inpsected, most are inspected using machine vision. 1 out of X many in a batch are inspected and tested by a QC inspector depending the established production standard.
The problem here is getting the case apart to inspect the components.on the board.
Good Luck.
Posted on Apr 22, 2008
    Brigadier General:
  • 6,966 Answers
I beg to differ. I believe that there is no need to replace the motherboard. It would seem that your concern is a simple case of cold solder on the power jack of the laptop. This is easily fixed with reapplying heat through a soldering iron and a little bit of lead. What would be more challenging is the disassembly and exposing the bottom part of the board where the jacks are soldered.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 18, 2008
  • 112 Answers
If the computer is running then I would guess the female plug is broken on the motherboard. You can get a new one and install it yourself if you know how. Its just a matter of openning the case and removing the bad plug and installing the new one. Reinstall the case and you should have the problem looked after.
Hi i need help plz, i've my laptop do not power when i plug the ac adapter ther' is no ligth
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
May 23, 2011 | Dell Inspiron 2200 Notebook
I have an HP Pavillion dv9910us laptop running Windows 7 32bit... It has been running fine, as usual. Lately I have had a lot of problems, however, with resuming from sleep or hibernation, it powers up but...
WHY NOT GET IT FIXED.?
NOT ONCE RUN IT WITH NO BATTERY AT ALL.!!!
FAIL NOW?, BAD POWER PACK IF BIOS IS DEAD
WORKS NOT, BATTERY IS DEAD SHORTED , BAD.
EASY NO?
ALSO KNOW SLEEP MODE! facts of life.
Only works if all driver on laptop are correct at hp.com
or it will fail for sleep.
or virus infected.
turn off sleep mode (ac/ and batter) under powers settings CP
work now>? i bet does, (battery out)
new power pack but why do that, take out the battery first
laptops need no battery and with no battery it can run perfect
does it.?????????????????? (ac wall power good sure)
Mar 01, 2017 | HP Pavilion DV9910US Notebook
My c610 wont power on propertly it just turn on 4 solid green lights for 10 sec and then powers off
Hi. You have a no power issue there. Try draining the power from the laptop by removing the battery and ac adapter. Press and hold the power button for 10 seconds and connect the ac adapter again. Now power on the system. If it powers on, you fixed it. If it didn't power back on, You might have to replace your motherboard.
Jul 17, 2010 | Dell Latitude C610 Notebook
Dell 1525 won't run on ac but will on generic battery
Dell systems will not charge the battery without a Dell Branded AC adapter connected to the system (The BIOS looks for the adapter ID and disables the battery charger if not ID'd)
It appears, that since the system will not power on with either AC adapter, that there is a problem with the power connection of the system. You can replace the power board
http://cgi.ebay.com/DeLL-Inspiron-1525-1526-Power-Jack-Board-48-4W006-011_W0QQitemZ380212346664QQcmdZViewItemQQptZMotherboards?hash=item58866bff28#ht_953wt_1165
if that fails to resolve next is the motherboard
http://shop.ebay.com/i.html?_nkw=dell+inspiron+1525+motherboard&_sacat=0&_dmpt=Laptop_Adapters_Chargers&_odkw=dell+inspiron+1525+charger+board&_osacat=0&_trksid=p3286.c0.m270.l1311
Mar 14, 2010 | Dell Inspiron 1525 Notebook
Laptop won't staart up.
Yes, it should run off AC power even if the battery is removed. Sounds like either the motherboard or your AC adaptor might be failing. I would start by trying the AC adaptor with another dell to verify it it's not dead.
Good luck,
Raf
Nov 09, 2009 | Dell Inspiron 5160 Notebook
Dell c610 powers off. then to restart you have to
sound like a short the system is fail safe to prevent more damage so repair or replace
Oct 31, 2009 | Dell Latitude C610 Notebook
Dell c610 will not turn on
Forgeet the CMOS battery, worthless exercise. Most likely from what you describe it is a bad motherboard, and on a system that old I'd say replace not repair. If you want to fix it, mothebroards are $50 to 100 for that model on EBay
Jun 03, 2009 | Dell Latitude C610 Notebook
Thinkpad R60 auto-restarted when shutting down
try pulling the battery out for a day running on ac only
Jan 06, 2009 | IBM ThinkPad R60 Notebook
Battery troubles
go to ebay to look for cd dvd rom replacement.
It is best to take computer to a computer shop to have cmos battery replaced because the computer has to be disassemled to access motherboard.
If the main battery has never been replace most likely its bad most laptop batteries have short lives.
on the otherhand with expense in mind you may want to price a new laptop from walmart they start arond 499.00 brand new
Jan 16, 2008 | Dell Latitude C610 Notebook
Dell Latitude C610 Notebook Logo
49 people viewed this question
Alun Cox
