Question about RCA D52W19 52" Rear Projection Television
When turning the power on to the TV, the green power indicator comes on for approximately 10 seconds then goes out. The television never comes on. Unplugging it and plugging it back in makes no difference
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please post back with the no# of blinks the green light flashes in 10 seconds so that I can further assist you.
Thanks
Rylee
Posted on Jul 05, 2010
  • fireguytom20 Jul 07, 2010
    It doesnt flash. It just stays on for 10 seconds then goes out.
    Tom
  • Rylee Smith
    Rylee Smith Jul 07, 2010
    Try to reset it, to reset the TV turn it off and wait
    for 15 minutes. After 15 minutes unplug the television power cord from the
    electrical outlet and let the television remain without power for more then 1
    minute. Plug the power cord back into the electrical outlet. If the television
    is plugged into a power surge protector, remove it from there and plug it
    directly into the wall outlet. Turn on the television. If the issue is
    resolved, then the problem is with the power surge protector and not the
    is not resolved then this might have happened due to over-voltage. Please check
    the power supply unit for swollen/ bulged capacitors and burnt wires/components
    on the power supply board.
    Please make sure to turn off and
    unplug the TV for at least 1 hour (this will drain off current from
    all components especially capacitors) before you perform any repairs. Also note
    that the TV consists of very high voltages even when it is in off condition.
    All this is only recommended if you have electrical expertise and know how to
    solder/re-solder components. Please do accept the solution if the issue is
    resolved or post a comment for further assistance.
    Thanks
    Rylee
Wd62627
It could be your power supply board.
Jul 23, 2013 | Televison & Video
My protron pltv-37c will turn on for 10 seconds the light turns green then goes to red after ten seconds
The green light indicates power is being applied. The change from green to red indicates that the power supply has failed
Oct 29, 2012 | Protron PLTV-32 Television
I need the code for sharp tv please
Configuring codes:
  1. Turn on the component that you want to set up. In the code listing find the 4-digit code numbers for your component brand.
  2. Hold the component key down until the green indicator light comes on. The green light should come on after approximately 3 seconds.
  3. Release the component key.
  4. If you are programming the DVD or CD device press the "action" key. The red indicator light will come on.
  5. Within thirty seconds, enter in a 4-digit code number. The component key lights will blink with an upward motion when a code has been successfully entered. In this case proceed to step #5. If the code has not been successfully entered, the componment lights will not blink. In this case return to strep #1 and start over.
  6. Test code by pressing "Power" key. If the component turns off, you've got the right code. Follow the same instructions to set up your other components. If the component doesn't turn off, return to step 2 and use the next 4-digit code listed. Note: If none of the codes turn your component off, try the Auto Code Scan function.
Auto Code Scan:
    The Auto Code Scan feature allows you to set up your components without having to enter in code numbers. The Jensen will do the work for you! (It may take a few minutes to find your code using this method.)
  2. Hold the component key down until the light comes on. The green light should come on after approximately 3 seconds.
  5. Press "0" - "9" The green light will blink as codes are sent.
  6. As soon as the remote turns your component off, press the "action" key. (You have 1 second in which to press the "action" key to save the code.) The component key lights will blink with an upward motion when a code has been successfully entered. The component is now programmed. To find that code, proceed to Code Readback.
  7. If none of the codes turn your component off, return to step 2 and start over.
Code Readback:
  1. Hold the component key down until the green indicator light comes on. The green light should come on after approximately 3 seconds.
  2. Release the component key.
  3. If you are programming the DVD or CD device press the "action" key. The red indicator light will come on.
  4. Press the "enter" key.
  5. Count the number of times the green light blinks. There will be four numbers, separated by a two second pause. The red light will tum off after the remote is finished reading numbers back. Make sure you write the code number below for future use!
Multi-Component Power On/Off:
    The Jensen remote has the ability to turn On/Off multiple components at once. When you perform the following steps, you can turn On/Off the TV, VCR, Satellite, Cable Box and Audio Receiver.
  1. Press the "action" key.
  2. Press the "power" key. Note: This feature does not work for DVD and CD.
Volume Priority Punch-Through:
    When you press the volume keys on the remote they will control the volume on your TV. If you have a home theater system and want the volume keys to control your receiver only, you may set your volume priority to the receiver.
  1. Hold the "RCVR" key down until the green indicator light comes on. The green light should come on after about 3 seconds.
  2. Press "RCVR" key.
  3. Press "Vol+" key. To disable the volume priority you have to set and return to the default.
    To change back to TV priority:
  3. Press "Vol-" key. The volume priority will now default to the TV volume.
hope this helps
Robb
Apr 22, 2010 | Jensen SC-570 Remote Control
Stays on for 2 seconds and switches off
A 2-2 code on that unit means over current shutdown. 95% of the time that code indicates defective convergence output IC's.
Jun 09, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Tv will not power up, shuts off after 10 second
http://serviceman.site88.net/index_files/MitsubishiTV.htm
Oct 01, 2008 | Mitsubishi WS-65857 65" Rear Projection...
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Tv won't come on
for the last 2 months my remote will not turn my television set on or off, at first i could just press the power button to shut it on and off, now i have to unplug it for approximately 10 seconds, and then replug it and press the power button to get it to come, I found out that this only works though if your TV has been plugged in for at least two hours
Jun 01, 2008 | iLO 3200 32 in. LCD Television
No Picture, Indicator Light Green
If your TV is a year old or more, chances are that the power supply is starting to fail on your TV, causing all kinds of erratic behavior up to the point of not turning on anymore.
I service these power supplies since it does not look like there are many service parts available anymore. The only way to get this TV functional again is to repair the power supply to the component level.
May 11, 2008 | Protron PLTV-32 Television
TV doesn't turn on
I bought a LG 39" flat screen 6 months ago. TV has been working great until this morning. Power comes on for about 5 seconds and then cuts off. Have checked all connections and have unplugged from wall to reset, NOTHING!! And a brand new TV!! Any help would be great!
Aug 10, 2007 | LG RU-52SZ51D 52" Rear Projection...
RCA D52W19 52" Rear Projection Television Logo
132 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
