Question about JVC KD-PDR30 Car CD/ MP3 Player
I believe i may have gotten some water in my JVC car stereo KD-R610, and I am wondering if there may be a way to save it? Is there a special or correct way to reset it. The radio comes on but says PROTECT. Any help would be appreciated.
  • JVC Master
  • 17,130 Answers
If you have not put on the set after the water logging then you could have been saved. Now there is a chance that the processor section have shorted circuit. please open the set, use a hair dryer and warm up to clear up all the moisture. use petrol to clean the main board do not put any petrol on the main panel or plastic.but only the PCB. after cleaning heat again till you have warrmed up and cleared all moisture. reconnect the set and test. I hope this must clear your fault or else you will be having faulty componentts that needs further continuity and voltag checks for finalising. hope my advice helps. good day
Posted on Jul 06, 2010
I have a 98 Toyota Corolla with a jvc kd-r200 and a 2007 Camry with a jvc kd-r980bts..I want to switch the two stereos, the kd-r200 to Camry and kd-r980bts to Corolla for now because the Corolla has a sub...
Yes pretty much just check the colours on the plugs line up,some companys swap them around sometimes,but 90% plug and ur done,sub prob has its own rca out put or there ll be a few less wires going to nothing when u plug in.if they have a coded security number make sure u know the code before u disconect
Jan 12, 2018 | JVC Car Audio & Video
I can not get my jvc kd-r610 on fm radio. lost the manual. help
You can download the manual from the manufacturer's web site at
http://books.jvc.com/booklist.asp?Model=kd-r610
Aug 20, 2011 | JVC AM FM CD DET FACE CAR STEREO
How do I remove the JVC KD-G635 car stereo to gain access to the rear of the unit.
u need special tools to remove the head unit if it was installed right. security purposes
Mar 19, 2011 | JVC AM FM CD DET FACE CAR STEREO
Installing Jvc KD-R610 into 02 Nissan Frontier, where I have removed older JVC. Using old harness, but blue wire labels do not match... One says "amp power" and other says "power...
well it sound like your ground wire is not connected the properly way this wire is black make sure
the other 3 are connect right are Yellow is constant power ,Red is acc.ingnition,Blue is the remote.
that would complite your conection done.
Dec 27, 2010 | JVC AM FM CD DET FACE CAR STEREO
JVC KD-R610 is stuck in Protect mode
Try disconnecting your battery, reconnecting it, and resetting your stereo. If that doesn't work, the constant power (yellow wire) or ignition wire (red wire) may have come in contact with ground or isn't properly connected. Make sure everything is connected properly and try resetting your stereo. If it is still flashing "protect", the unit needs servicing Contact JVC Customer Care Center at: 800-252-5722.
Jul 22, 2010 | JVC AM FM CD DET FACE CAR STEREO
Wired and Installed a jvc KD-R610 deck in my 95 mustang and deck will not turn on
You should verify your wiring .Also check all fuses. that is on the radio and for the power wire (red) .
May 12, 2010 | Car Audio & Video
Setting clock on a JVC KD-GS611 car stereo?
I found your manual at: http://files.lv-soft.info/Audio/jvc/kd-gs611.pdf
I cant copy the instructions but you can download, save and print this manual for future reference.
Nov 21, 2008 | JVC KD-GS611
JVC KD-PDR30 Car CD/ MP3 Player Logo
133 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
