Question about Malibu ML200RT - Low Voltage Power Pack -200 Watt - With Timer - Plastic Ho
The timer stopped working
I installed the timer approximately 3 years ago and just recently, the timer stopped working.
You need to pull apart gear housing - the final shaft has no bushing and seizes sometimes - take apart use emery cloth to remove corrosion and re-lube with heavy grease - good for a few more years - I've done mine several times now.
Posted on Jul 28, 2010
TB25-LMP replaced but TV will not work
Sounds like the ballast is having an issue. The ballast is easially replaced and should be available from www.tvcircuitboards.com
Feb 10, 2013 | Toshiba 56HMX195 52" HDTV DLP Projection...
My outdoor low voltage lighting is blinking on/off - cycles on/off every 2 seconds (approximately) - this is not an issue of the photo sensor picking up light from the installed lights. Colder than us
1) Most photocell timers have 1 year limited warranty, but unclear who carries warranty without knowing brand.
Do not buy expensive timers with photoeye unless purchased at local store where ez exchange can be made for several years.
Copy following link to help identify timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Moonray
2) Buy Intermatic-Malibu power pack with 5 year limited warranty:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
3) Set power pack to ON position (or override position) and then plug power pack into cheap 3-prong wall timer, for example timer with optional dawn-dusk or remote control sold at Lowes and Home Depot.
http://waterheatertimer.org/pdf/Woods-49554-TM16-manual.pdf
4) Add comment and describe timer in detail for more possible help
Dec 27, 2012 | Yamaha Xv 250 Virago S Motorcycles
Timer starts and stops whithin 3 seconds, how do I adjust the run time to operate as normal?
Most likely the timer has suffer failure, for example the small gears wear out, or motor begins to slow down and then motor overheats causing motor failure.
Might try resetting the timer by turning Frequency Knob to Reset, and then reprogram:
Copy following link for more recent timer manuals that may not apply to older timer:
http://waterheatertimer.org/pdf/Raindrip-R672-single-timer.pdf
Jun 28, 2012 | Raindrip Hardware & Accessories
Wacky electrical problem in 2002 dodge caravan
Hi
Check for wires rubbing against brake pedal linkage under the dash.
Apr 01, 2009 | 2002 Dodge Caravan
No Display on my Samsung 204B monitor
If you know how to open it up and get to the power supply you will find three capacitors 2-820uf and 1-330 @ 25vdc 105o.they will have puffed up tops replace them. FYI the monitor has a 3 year warranty.
Dec 12, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
Jun 11, 2008 | GE DBXR463EBWW Electric Dryer
Malibu ML200RT - Low Voltage Power Pack -200 Watt - With Timer - Plastic Ho Logo
103 people viewed this question
Top Malibu Hardware & Accessories Experts
Gene Haynes
Scott Jelt
Scott Jelt
jdthefixer
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
