Question about Refrigerators
I dont know what to set my refigerator temperature setting knob to everything is freezing
  • Anonymous Nov 28, 2008
    bosch upright deep freezer - cannot reduce temperature to 18
    Scholar:
  • 149 Answers
Ok 1 it hottest and 7 or 9 is the coldest set it at 5 or 6
Posted on Apr 21, 2008
  • Alexander  Figueroa
    Alexander Figueroa Apr 23, 2008
    if it keeps freezing suspect a bad thermostat and verify that freezer fan runs.
    also verify defrost element... and if your unit uses a defrost timer, check that too make sure that the wheel turns without problem if an adaptive defrost board, suspect it faulty.
How do I unstick the temperature control knob in my freezer? It will not budge. My freezer is over freezing and my refrigerator is not cooling properly.
It is possible that water or the moisture in your freezer has frozen the knob so it feels stuck, so the couple of ways you can fix it is, 1 unplug the freezer, let it defrost and when it warm the knob should loosen up. 2 if you dont want to do the first cuz of food and whatnot what i would do is get a wrench that can fit the knob, put a wash cloth over the knob so dont scratch it all up and grab it with the wrench and try to twist it that way. And 3 take that part of the fridge apart, take off the covers or see if you can open up that area and try to take the knob completely off, and if its like every other knob ive ever seen, once you get the plastic knob off there will be a metal pin that has a flat side that lines up with the plastic knob, take pliers or wrench and try to spin that little pin
Oct 01, 2016 | Refrigerators
What temperature should i have my top half fridge of my hotpoint fridge/ freezer as it is too cold and everything is freezing
A good setting is in the middle of the thermostat range. For example, if you have numbers from 1 to 9, 5 would be a good number. If this setting continues to freeze, look for a bad thermostat or temperature thermistor.
Oct 01, 2014 | Refrigerators
Haier minifridge freezing everything
My mini-fridge did a similar thing, until I realized that managed to put on the wrong temperature knob. It was technically backwards. They may have done this to you. I mean, it is a longshot, but try putting it on the highest setting to see if that helps. If it does not, you're most likely dealing with a faulty knob that's not actually changing the settings on the thermostat.
Apr 10, 2014 | Haier Refrigerators
Refigerator freezes everything regardless of temperature setting
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Sep 01, 2011 | Danby Refrigerators
WE BOUGHT A 25 CUBIC AMANA REFIGERATOR AND WOULD LIKE TO KNOW WHAT TEMPERATURE SHOULD THE REFIGERATOR BE AT. OURS WAS SET AT 4 BY THE INSTALLER, BUT I HAVE NOTICED THAT OUR MILK IS SPOILING BEFORE THE...
Depending on which is the lower temp settting I would say you are correct I would set it to a higher no.Assuming the higher no.is a colder setting and not vice versa try 5 for a day or so and test the milk by drinking it and see if it is much colder but not freezing.if npot cold enough go to 6
Mar 07, 2010 | Refrigerators
Temperature of the refigerator recently got colder
I believe your auto damper may be defective and stuck open, Let me send you the service nanual and a page to go toand look it over. The auto damper has a thermostat coil inside and sometimes the probe leaks the freon out of its pigtail leaving the damper stuck open oe closed and some time frost will cause them to stick.
Jan 04, 2010 | Jenn-Air JCD2389G Side by Side...
My oven burns everything.
Use a 'oven thermometer' in the oven and determine the 'actual temperature' in the oven. Your knob setting is off (not calibrated) and the oven is hotter than the control knob setting.
Sep 16, 2009 | Ovens
EVERYTHING FREEZES!
Probably need to replace that temperature control. Also check damper. If manual, set to where less air is going to fridge.
Sep 24, 2017 | Amana ARB224RCW Bottom Freezer...
My refigerator and freezer are not cooling enough
Is the fan in the freezer running?? Is there frost on back panel of freezer??
Oct 03, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
203 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
