Question about Acer 22" X223w LCD Monitor
Acer monitor won't stay on
My Acer 20" monitor has been having a problem. When I turn it on the "Acer" logo flashes for a second then disappears, followed by a quick flash of my desktop for a second and turns off. The power button stays green. I used to be able to turn the monitor on and off 10 times and it would work normal until I turned it off again.
  • Acer Master
  • 5,218 Answers
That looks like an inverter problem. If the monitor is still under warranty, contact the manufacturer (3 years for both parts and labor if purchased new). Otherwise, open up the back of the monitor and remove the shielding. Look for scorch marks, soot or leaking or bulging capacitors (look like cylinders on tripods). You could just replace the capacitors and the resistor that acted as a fuse. However, for $50-150, depending on the inverter, you can replace the entire part (unplug the wires for the backlight(s) and other connections and swap them).
You can also check the inverter by looking for the high frequency EM put out by the unit. Some high end multimeters will measure this (as will an oscilliscope). Hold the multimeter probes a fraction of an inch apart about an inch above the board (with the multimeter set to read frequency). If the inverter is good (and the frequency is reasonably close to the multimeter's range) you will see either a 1 or a value (kHz). If the inverter is bad or too far out of range, you will see a result near zero.
Once you have the monitor open, record the part number on the board with the damage, including the REV number if any. Search that part online (lcdparts.net and other sites have parts for monitors). Get the correct unit if possible. Some sites sell universal inverters and those can be used. However, you may find the controls reversed (up to lower brightness).
I hope this helps.
(a backlight issue would have resulted in a slow fading of the image or the screen looking red/pink.)
Posted on Jul 05, 2010
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Acer Master
  • 848 Answers
Acer monitor won't stay on? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
715G2892 2 3 Acer PWTVAC21MQDL Power Supply for X223W
Posted on Nov 18, 2014
My acer AL2416w monitor turns on to a black screen
I have 2 Acer AL2416W monitors that i have been using for 2 years. There has been a handful of times i would turn my computer on in the morning and the screen would be black and Acer would lightly flash on the monitor 1 time. Typically a restart would take care of the problem. Last week the monitor blacked out and i can't get it to work. Any suggestions?? I switched ports on the computer to verify it wasn't the video card and tried new DVI cables to verify it wasn't those? Is this fixable??
Sep 06, 2009 | AcerView 77E 17" CRT Monitor
I have an Acer H243H widescreen monitor; it has speakers built in. My problem is that the Volume controls constantly show up on the screen and I am unable to get it to go away and stay gone. The touch...
When this occurs with mine, I power down the PC through windows and the monitor using the lower right power button, let bot sit for 10 - 20 seconds, then power on the PC and switch on the monitor a second or two later and the icon disappears.
Before I did this I found it would eventually disappear.
Acer support claim the H243H is a touchscreen unit, that's what the icon is all about, buy you must have Vista to use it, not XP.
Jul 15, 2009 | Acer Computers & Internet
ACER 22" monitor flashes on at PC startup, then goes black
Your monitor has a bad INVERTER, look on eBay.
Jun 27, 2009 | Computers & Internet
Two monitors blank, but on
<table x:str="" style="border-collapse: collapse; width: 124pt;" border="0" cellpadding="0" cellspacing="0" width="165"><col style="width: 124pt;" width="165"> <tr style="height: 14.25pt;" height="19"> <td style="height: 14.25pt; width: 124pt;" height="19" width="165">http://www.wholesaleeshop.com.au/LCD-Monitor/10.4-inch.php</td> </tr></table><br />I wish you problem can be solution. <table x:str="" style="border-collapse: collapse; width: 54pt;" border="0" cellpadding="0" cellspacing="0" width="72"><col style="width: 54pt;" width="72"> <tr style="height: 14.25pt;" height="19"> <td style="height: 14.25pt; width: 54pt;" height="19" width="72">&lt;a href="http://www.wholesaleeshop.com.au/LCD-Monitor/10.4-inch.php"&gt;10.4 inch LCD Monitor&lt;/a&gt;</td> </tr></table>
Mar 24, 2009 | Acer AL2216WBD LCD Monitor
At power up tv displays Acer logo then goes to black
will not turn off power with out unplugin it
Mar 01, 2009 | Televison & Video
My monitor turns itself off
If it's only a few months old then send it back under warranty.
The fault you have is the inverter circuit.
Hope that helps. =)
Apr 12, 2008 | Acer AL2032WD 20" LCD Monitor
Monitor repeatedly flashes Acer logo and computer display in cycles
We had the same problem with the 17" we bought in Aug. Sent it back for repair. Acer sent it back without fixing the problem. Started doing it again in Nov. This time I called a supervisor and they sent me a new monitor. Well yesterday it started doing the same thing. You can fix it temp buy unplugging it and holding down the on-off switch for 30 seconds. Please let me know if you have a better fix.
Dec 13, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Acer 22" X223w LCD Monitor Logo
1,279 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
