I have a document in the print queue that I cannot delete. The document will not print and it will not let me print anything else. It says "command error" and I do not know what to do. Basically my printer is locked up until I can remove this one document. I removed several others, but this one will not delete. HELP!
  • larrydr Dec 21, 2008
    I have a print in que tried to delete but will not remove document
    Genius:
  • 3,587 Answers
Try this tip first
Posted on Apr 18, 2008
What to do if after canceling the printing in queue document its status is still showing deleting ?
Give it a few minutes. Sometimes it takes awhile to delete the document.
If that fails, turn off the printer, wait a minute, then turn it back on. The document should be deleted.
Jun 29, 2015 | Office Equipment & Supplies
I cancelled a document while it was printing and it is still in my queue days later as deleting and it wont let me print anything else or restart that print job.
The best way to delete the print job is to turn the printer off, then disconnect the cable from the printer to the computer. Turn the printer on with the cables off, and go to your computer and delete the document, Then once it's deleted, turn the printer off again, and then hook the cable back up. Then turn the printer back on. That should do it.
Good Luck
Mark
Sep 13, 2014 | HP deskjet 3940 color inkjet printer -...
Brother mfc8460n stopped printing anything....no warning and no appearance of anything being wrong. I don't know where to look; have 2 documents in queue.
The first of those documents is probably corrupted and causing the printer to stop working. Delete all jobs from the queue, turn the printer off, then back on again and try a different document. If it works, then the document is corrupted and you need to try saving it in a different format before printing it again.
Mar 05, 2011 | Brother MFC-8460N All-In-One Printer
What do I do when there is a document frozen for printing on the printer. I have shut both the printer and the computer off to restart it. I have also tried cancelling the frozen document as well as...
Not sure if this helps, but you should first try to tell the system to delete or cancel all print packages. What is typically happening is that there is a problem with the first item in the queue, and all the others behind it or listed below it won't print eighter - by deleting the troublesome print, it may take time but it should clear - HP would often do that, but totally shutting down cold was the only way to clear the queue. When both the PC and printer did a cold boot, then the queue would be clear. If not then maybe check with the manu of your printer for their advice
Nov 06, 2017 | Dell Photo 964 All-In-One InkJet Printer
Printer keeps printing page after page of meaningless symbols.
Did you have document in queue?If you have delete all documents in queue and restart the computer.Then restart printer.Wait to document in queue deleting.If you haven't documents in queue reinstall the drivers.First delete old, reset computer and install new.
Nov 04, 2009 | HP DeskJet 940c InkJet Printer
I have a pdf document to print and it doesn't print it, and in the window box for the printer it says that 1 document is in queue (which I don't understand what queue means) and if I try to cancel the...
How large (how many pages) is the PDF document?
Try printing only the first page.
Then try only 5 pages at a time.
The queue is the disk area where the document (in print-out form) is held until the printer can service it (print it). This is known as "background printing".
Oct 07, 2009 | HP DeskJet F380 All-In-One Printer
Three weeks ago, I purchased a Black (No.4) and a Colour (No.5) Valuepack Cartridges for my Lexmark X2690 All-In-One printer from Refresh Cartridges/UK. After installing both cartridges, I printed a Test...
ok what should do is when you finish printing one page wait for some few mins before printing another page ok. that could help or unistall and reinstall your printer again and apply this method i just showed you. thanks
Jul 02, 2009 | Lexmark X2690 All-In-One InkJet Printer
Can't delete document from printer queue. Can't print anything.
I've had this problem several times, and the only solution is to restart your system. Once rebooted, the printer will continue printing your other documents
Jun 07, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
Docs in queue won't cancel so I can print another document
turn of the printer and unlug the data cable.
go to start>>printer and faxes, open the printer queue and deleted the job.
plug in the data cable and turn on the printer
Jan 29, 2009 | HP LaserJet 1020 Printer
It Just Wont Print
Have you tried installing the HP Print Diagnostic Utility?
This utility fixes some of the basic issues with the printer /computer.
Download/Install and follow the onscreen instructions to run the utility and restart the computer when prompted.
I hope this tool resolves your issue.
gud luck.
Oct 26, 2008 | HP PSC 1315 All-In-One InkJet Printer
330 people viewed this question
jasbo
jasbo
